Date/Time: Thu, 16 May 2024 00:44:59 +0000
Symbol, Chart Number, etc disappeared from Region Data Lines
View Count: 481
[2021-06-10 16:53:30] |
User464833 - Posts: 13 |
The title describes it well, I don't know how, but I just realized I don't have that information anymore. How do I get that info back? Thanks http://www.sierrachart.com/image.php?Image=1623343896307.png |
[2021-06-11 16:20:40] |
John - SC Support - Posts: 31666 |
Refer to the following: Working With Charts: Region Data Line / Chart Header For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-11 20:09:14] |
Hi John, thanks for answering. I have already seen and done that, amongst other things, with no luck. Global Settings >> Customize Chart Header - Standard >> Add: Symbol - Bar Period - Chart # -----> CHECKED Chart >> Chart Settings >> Advanced Settings 2 >> Region Data Lines >> All Visible -----> CHECKED |
[2021-06-11 20:30:18] |
I'm not even sure how you have what is displayed there. Get us a copy of that chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-11 20:57:47] |
I have just realized that the TPO study is the problem. If I remove it, it gets solved, but I don't know what setting is causing that. I am sending the chartbook, thanks |
Support.Cht - Attached On 2021-06-11 20:54:13 UTC - Size: 5.25 KB - 182 views Attachment Deleted. |
[2021-06-11 21:25:41] |
It's the Study Short Name, as it overwrites the symbol information in the Chart Header. Refer to the information here: Chart Studies: Settings and Inputs Tab >> Short Name For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-11 21:32:47] |
Solved! Thank you for your time John
