Date/Time: Mon, 06 May 2024 05:01:05 +0000
CME DATA
View Count: 373
[2021-06-07 06:29:35] |
User752442 - Posts: 36 |
... don't receive CME Data this morning!?
[2021-06-07 06:43:42] |
Tell us one symbol you are not receiving data for and then follow the instructions below. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-07 06:48:28] |
EPM21
[2021-06-07 06:53:42] |
Ok, but we need to see the Message Log to understand the problem is. Instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-07 06:55:22] |
Software version: 2270 64-bit | 2021-06-07 08:49:56.478 Primary Thread ID: 4732 | 2021-06-07 08:49:56.478 Usage end date: 2021-12-07 | 2021-06-07 08:49:56.478 Enabled for: Advanced Features 2. | 2021-06-07 08:49:56.478 Enabled for: Sierra Chart Historical Data Service. | 2021-06-07 08:49:56.478 Enabled for: Denali Real-Time Exchange Data Feed. | 2021-06-07 08:49:56.478 Enabled for: Delayed Denali Exchange Data Feed. | 2021-06-07 08:49:56.478 Enabled for exchange2: CME | 2021-06-07 08:49:56.478 Enabled for exchange2: EUREX EOBI | 2021-06-07 08:49:56.478 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-06-07 08:49:56.478 Current selected Data/Trading service: CQG WebAPI | 2021-06-07 08:49:56.478 Custom symbol settings values: disabled | 2021-06-07 08:49:56.478 Chart Update Interval: 250 | 2021-06-07 08:49:56.478 Intraday Data Storage Time Unit: 0 | 2021-06-07 08:49:56.478 Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2021-06-07 08:49:56.478 2021-06-07 06:49:56 Local computer time in UTC | 2021-06-07 08:49:56.478 2021-06-07 08:49:56 Local computer time in SC Time Zone | 2021-06-07 08:49:56.478 2021-06-07 06:22:17 Server time in UTC | 2021-06-07 08:49:56.478 Local computer UTC time and Server UTC time difference: 3 seconds. | 2021-06-07 08:49:56.478 Program path: C:\SierraChart\ | 2021-06-07 08:49:56.478 Data Files path: D:\Sierrachart\Data\ | 2021-06-07 08:49:56.478 OS Version Number: 10.0 | 2021-06-07 08:49:56.478 Locale Setting: C | 2021-06-07 08:49:56.478 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2021-06-07 08:49:56.478 Allowed protected custom studies: | 2021-06-07 08:49:56.478 File >> Disconnect selected. | 2021-06-07 08:50:31.319 CQG WebAPI | Sending Web API Logoff message. | 2021-06-07 08:50:31.329 CQG WebSocket socket (1) | CloseSocket call. | 2021-06-07 08:50:31.329 CQG WebSocket socket (1) | Max send buffers used during socket life: 4 | 2021-06-07 08:50:31.329 CQG WebSocket socket (1) | Max send buffer size during socket life: 371 | 2021-06-07 08:50:31.329 CQG WebSocket | WebSocket closed. | 2021-06-07 08:50:31.329 CQG WebAPI | WebSocket closed. | 2021-06-07 08:50:31.329 CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-06-07 08:50:31.329 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-07 08:50:31.330 DTC Client socket (7) | CloseSocket call. | 2021-06-07 08:50:31.330 DTC Client socket (7) | Max send buffers used during socket life: 3 | 2021-06-07 08:50:31.330 DTC Client socket (7) | Max send buffer size during socket life: 495 | 2021-06-07 08:50:31.330 DTC Client socket (7) | Shutdown started. Waiting for graceful close. | 2021-06-07 08:50:31.330 SC Data - All Services | Disconnected from the server. | 2021-06-07 08:50:31.330 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-07 08:50:31.330 DTC Client socket (6) | CloseSocket call. | 2021-06-07 08:50:31.330 DTC Client socket (6) | Shutdown started. Waiting for graceful close. | 2021-06-07 08:50:31.331 SC Data - All Services | Disconnected from the server. | 2021-06-07 08:50:31.331 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2021-06-07 08:50:31.331 DTC Client socket (5) | CloseSocket call. | 2021-06-07 08:50:31.331 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-07 08:50:31.331 SC DTC Data with Market Depth | Disconnected from the server. | 2021-06-07 08:50:31.331 CQG WebAPI | Disconnected. | 2021-06-07 08:50:31.331 DTC Client socket (6) | Socket gracefully closed by remote side. | 2021-06-07 08:50:31.355 DTC Client socket (6) | Closed. | 2021-06-07 08:50:31.355 CQG WebSocket socket (1) | Write has completed. Shutdown being performed. | 2021-06-07 08:50:31.366 CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-07 08:50:31.366 DTC Client socket (5) | Socket gracefully closed by remote side. | 2021-06-07 08:50:31.440 DTC Client socket (5) | Closed. | 2021-06-07 08:50:31.440 CQG WebAPI | Connecting to server api.cqg.com | 2021-06-07 08:50:34.530 CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-06-07 08:50:34.530 CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. | 2021-06-07 08:50:34.668 CQG WebSocket socket (2) | New receive buffer size: 5242880 | 2021-06-07 08:50:34.668 CQG WebSocket socket (2) | Connecting to IP: 195.166.124.165. | 2021-06-07 08:50:34.668 CQG WebSocket | Opening WebSocket. | 2021-06-07 08:50:34.702 CQG WebSocket | Sending WebSocket handshake. | 2021-06-07 08:50:34.702 CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-06-07 08:50:34.808 CQG WebSocket | Server header | Connection: upgrade | 2021-06-07 08:50:34.808 CQG WebSocket | Server header | Sec-WebSocket-Accept: UQawBUmZWjOdt0T3iTJY63aW/pc= | 2021-06-07 08:50:34.808 CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2021-06-07 08:50:34.808 CQG WebSocket | Server header | Upgrade: websocket | 2021-06-07 08:50:34.808 CQG WebSocket | Server header | | 2021-06-07 08:50:34.808 CQG WebSocket | Web socket state is now open. | 2021-06-07 08:50:34.808 CQG WebAPI | WebSocket connected. | 2021-06-07 08:50:34.808 CQG WebAPI | Sending market data logon message. | 2021-06-07 08:50:34.808 CQG WebAPI | Base Time: 2021-06-06T14:21:07. 2021-06-06 14:21:07 | 2021-06-07 08:50:35.394 CQG WebAPI | Logon successful. Session Token = FTO2vuEX+Y4jSXiSihddcgzc/BY/Pqd0PzvIWGgUtzopduw1CcHniT5GZZT4CcQR6EfmjR+iDpq | 2021-06-07 08:50:35.394 CQG WebAPI | Connected to server complete. | 2021-06-07 08:50:35.394 Triggering next historical data download in queue. | 2021-06-07 08:50:35.394 Triggering next historical data download in queue. | 2021-06-07 08:50:35.394 Triggering next historical data download in queue. | 2021-06-07 08:50:35.394 Triggering next historical data download in queue. | 2021-06-07 08:50:35.394 Updated verified funded futures trading account ending date to: 2021-07-07 06:50:35 | 2021-06-07 08:50:35.395 Mapping F.US.DDM21 to FDAX202106_FUT_EUREX. Service code: eurex | 2021-06-07 08:50:35.395 SC Data - All Services | Starting real-time market data updates for: F.US.DDM21 (FDAX202106_FUT_EUREX). ID: 1 Service code: eurex | 2021-06-07 08:50:35.395 SC Data - All Services | Connecting to the server ds24.sierracharts.com. Port 10048 | 2021-06-07 08:50:35.395 CQG WebAPI | Sending symbol resolution request for F.US.DDM21. ID: 821206 | 2021-06-07 08:50:35.395 SC Data - All Services | Requesting security definition data for: F.US.DDM21 (FDAX202106_FUT_EUREX). ID: 1 | 2021-06-07 08:50:35.395 Added historical Intraday data request for F.US.DDM21 to the queue. | 2021-06-07 08:50:35.396 Intraday data recording state for symbol F.US.DDM21 is set to download 'Pending'. | 2021-06-07 08:50:35.396 F.US.DDM21 [C][M] 10 Sec #3 | Started historical data download for additional symbol F.US.DDM21. Download ID: 23 | 2021-06-07 08:50:35.396 DTC Client socket (3) | Creating socket. | 2021-06-07 08:50:35.396 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-06-07 08:50:35.396 DTC Client socket (3) | Connecting to IP: 80.81.77.132. | 2021-06-07 08:50:35.396 CQG WebAPI | Sending Trade Accounts request message. | 2021-06-07 08:50:35.403 No download requests in the queue to start downloads for. | 2021-06-07 08:50:35.403 Delaying start of download for F.US.DDM21 | 2021-06-07 08:50:35.403 No download requests in the queue to start downloads for. | 2021-06-07 08:50:35.403 No download requests in the queue to start downloads for. | 2021-06-07 08:50:35.403 SC Data - All Services | Network connection to server complete. | 2021-06-07 08:50:35.466 SC Data - All Services | Starting socket receive thread. | 2021-06-07 08:50:35.466 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-07 08:50:35.466 CQG WebAPI | Brokerage name: AMP. Account Name: 108540 | 2021-06-07 08:50:35.492 CQG WebAPI | Sending collateral subscribe request. | 2021-06-07 08:50:35.492 CQG WebAPI | Received symbol resolution report for symbol F.US.DDM21. Search Symbol: F.US.DDM21. Request ID: 821206. Contract ID: 1. | 2021-06-07 08:50:35.492 Mapping F.US.DSXM21 to FESX202106_FUT_EUREX. Service code: eurex | 2021-06-07 08:50:35.517 SC Data - All Services | Starting real-time market data updates for: F.US.DSXM21 (FESX202106_FUT_EUREX). ID: 2 Service code: eurex | 2021-06-07 08:50:35.517 CQG WebAPI | Sending symbol resolution request for F.US.DSXM21. ID: 821209 | 2021-06-07 08:50:35.517 SC Data - All Services | Requesting security definition data for: F.US.DSXM21 (FESX202106_FUT_EUREX). ID: 2 | 2021-06-07 08:50:35.517 Requesting market depth updates for: F.US.DSXM21 if supported. | 2021-06-07 08:50:35.517 Separate subscription for market depth updates not supported. F.US.DSXM21 | 2021-06-07 08:50:35.517 Added historical Intraday data request for F.US.DSXM21 to the queue. | 2021-06-07 08:50:35.517 Intraday data recording state for symbol F.US.DSXM21 is set to download 'Pending'. | 2021-06-07 08:50:35.517 Triggering next historical data download in queue. | 2021-06-07 08:50:35.517 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-07 08:50:35.537 SC Data - All Services | Sending logon request message. | 2021-06-07 08:50:35.537 Requesting market depth updates for: F.US.DDM21 if supported. | 2021-06-07 08:50:35.538 Separate subscription for market depth updates not supported. F.US.DDM21 | 2021-06-07 08:50:35.538 CQG WebAPI | Received symbol resolution report for symbol F.US.DSXM21. Search Symbol: F.US.DSXM21. Request ID: 821209. Contract ID: 2. | 2021-06-07 08:50:35.553 Mapping F.US.DBM21 to FGBL202106_FUT_EUREX. Service code: eurex | 2021-06-07 08:50:35.559 SC Data - All Services | Starting real-time market data updates for: F.US.DBM21 (FGBL202106_FUT_EUREX). ID: 3 Service code: eurex | 2021-06-07 08:50:35.559 CQG WebAPI | Sending symbol resolution request for F.US.DBM21. ID: 821210 | 2021-06-07 08:50:35.559 SC Data - All Services | Requesting security definition data for: F.US.DBM21 (FGBL202106_FUT_EUREX). ID: 3 | 2021-06-07 08:50:35.559 Requesting market depth updates for: F.US.DBM21 if supported. | 2021-06-07 08:50:35.559 Separate subscription for market depth updates not supported. F.US.DBM21 | 2021-06-07 08:50:35.559 Added historical Intraday data request for F.US.DBM21 to the queue. | 2021-06-07 08:50:35.559 Intraday data recording state for symbol F.US.DBM21 is set to download 'Pending'. | 2021-06-07 08:50:35.559 Triggering next historical data download in queue. | 2021-06-07 08:50:35.559 Mapping F.US.JY6M21 to 6JM21. Service code: cme | 2021-06-07 08:50:35.564 SC Data - All Services | Starting real-time market data updates for: F.US.JY6M21 (6JM21). ID: 4 Service code: cme | 2021-06-07 08:50:35.564 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2021-06-07 08:50:35.564 CQG WebAPI | Sending symbol resolution request for F.US.JY6M21. ID: 821211 | 2021-06-07 08:50:35.564 SC Data - All Services | Requesting security definition data for: F.US.JY6M21 (6JM21). ID: 4 | 2021-06-07 08:50:35.564 Requesting market depth updates for: F.US.JY6M21 if supported. | 2021-06-07 08:50:35.564 Separate subscription for market depth updates not supported. F.US.JY6M21 | 2021-06-07 08:50:35.564 Added historical Intraday data request for F.US.JY6M21 to the queue. | 2021-06-07 08:50:35.564 Intraday data recording state for symbol F.US.JY6M21 is set to download 'Pending'. | 2021-06-07 08:50:35.564 Triggering next historical data download in queue. | 2021-06-07 08:50:35.564 DTC Client socket (4) | Creating socket. | 2021-06-07 08:50:35.565 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-07 08:50:35.565 DTC Client socket (4) | Connecting to IP: 216.1.90.130. | 2021-06-07 08:50:35.565 CQG WebAPI | Received symbol resolution report for symbol F.US.DBM21. Search Symbol: F.US.DBM21. Request ID: 821210. Contract ID: 3. | 2021-06-07 08:50:35.618 CQG WebAPI | Received symbol resolution report for symbol F.US.JY6M21. Search Symbol: F.US.JY6M21. Request ID: 821211. Contract ID: 4. | 2021-06-07 08:50:35.618 Mapping F.US.EPM21 to ESM21. Service code: cme | 2021-06-07 08:50:35.618 SC Data - All Services | Starting real-time market data updates for: F.US.EPM21 (ESM21). ID: 5 Service code: cme | 2021-06-07 08:50:35.618 CQG WebAPI | Sending symbol resolution request for F.US.EPM21. ID: 821212 | 2021-06-07 08:50:35.618 SC Data - All Services | Requesting security definition data for: F.US.EPM21 (ESM21). ID: 5 | 2021-06-07 08:50:35.618 Requesting market depth updates for: F.US.EPM21 if supported. | 2021-06-07 08:50:35.630 Separate subscription for market depth updates not supported. F.US.EPM21 | 2021-06-07 08:50:35.630 Added historical Intraday data request for F.US.EPM21 to the queue. | 2021-06-07 08:50:35.630 Intraday data recording state for symbol F.US.EPM21 is set to download 'Pending'. | 2021-06-07 08:50:35.630 Triggering next historical data download in queue. | 2021-06-07 08:50:35.630 CQG WebAPI | Received symbol resolution report for symbol F.US.EPM21. Search Symbol: F.US.EPM21. Request ID: 821212. Contract ID: 5. | 2021-06-07 08:50:35.669 SC Data - All Services | Network connection to server complete. | 2021-06-07 08:50:35.686 SC Data - All Services | Starting socket receive thread. | 2021-06-07 08:50:35.686 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-07 08:50:35.686 Mapping F.US.NIYM21 to NIYM21. Service code: cme | 2021-06-07 08:50:35.799 SC Data - All Services | Starting real-time market data updates for: F.US.NIYM21 (NIYM21). ID: 6 Service code: cme | 2021-06-07 08:50:35.799 CQG WebAPI | Sending symbol resolution request for F.US.NIYM21. ID: 821213 | 2021-06-07 08:50:35.799 SC Data - All Services | Requesting security definition data for: F.US.NIYM21 (NIYM21). ID: 6 | 2021-06-07 08:50:35.799 Requesting market depth updates for: F.US.NIYM21 if supported. | 2021-06-07 08:50:35.799 Separate subscription for market depth updates not supported. F.US.NIYM21 | 2021-06-07 08:50:35.799 Added historical Intraday data request for F.US.NIYM21 to the queue. | 2021-06-07 08:50:35.799 Intraday data recording state for symbol F.US.NIYM21 is set to download 'Pending'. | 2021-06-07 08:50:35.799 Triggering next historical data download in queue. | 2021-06-07 08:50:35.799 Mapping F.US.EU6M21 to 6EM21. Service code: cme | 2021-06-07 08:50:35.816 SC Data - All Services | Starting real-time market data updates for: F.US.EU6M21 (6EM21). ID: 7 Service code: cme | 2021-06-07 08:50:35.816 CQG WebAPI | Sending symbol resolution request for F.US.EU6M21. ID: 821214 | 2021-06-07 08:50:35.816 SC Data - All Services | Requesting security definition data for: F.US.EU6M21 (6EM21). ID: 7 | 2021-06-07 08:50:35.816 Requesting market depth updates for: F.US.EU6M21 if supported. | 2021-06-07 08:50:35.816 Separate subscription for market depth updates not supported. F.US.EU6M21 | 2021-06-07 08:50:35.816 Added historical Intraday data request for F.US.EU6M21 to the queue. | 2021-06-07 08:50:35.816 Intraday data recording state for symbol F.US.EU6M21 is set to download 'Pending'. | 2021-06-07 08:50:35.816 Triggering next historical data download in queue. | 2021-06-07 08:50:35.816 CQG WebAPI | Received symbol resolution report for symbol F.US.NIYM21. Search Symbol: F.US.NIYM21. Request ID: 821213. Contract ID: 6. | 2021-06-07 08:50:35.842 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-07 08:50:35.842 SC Data - All Services | Sending logon request message. | 2021-06-07 08:50:35.842 CQG WebAPI | Received symbol resolution report for symbol F.US.EU6M21. Search Symbol: F.US.EU6M21. Request ID: 821214. Contract ID: 7. | 2021-06-07 08:50:35.850 SC Data - All Services | Received logon response. | 2021-06-07 08:50:35.866 SC Data - All Services | Server Name: SC Realtime Server. | 2021-06-07 08:50:35.866 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-07 08:50:35.866 SC Data - All Services | Successfully connected. | 2021-06-07 08:50:35.866 SC Data - All Services | Trading is not supported. | 2021-06-07 08:50:35.866 SC Data - All Services | Restarting real-time data updates for symbol: F.US.DBM21 -> FGBL202106_FUT_EUREX. Market Depth data restarted. | 2021-06-07 08:50:35.866 SC Data - All Services | Restarting real-time data updates for symbol: F.US.DDM21 -> FDAX202106_FUT_EUREX. Market Depth data restarted. | 2021-06-07 08:50:35.866 SC Data - All Services | Restarting real-time data updates for symbol: F.US.DSXM21 -> FESX202106_FUT_EUREX. Market Depth data restarted. | 2021-06-07 08:50:35.866 SC Data - All Services | Clearing market depth for F.US.DBM21 | 2021-06-07 08:50:36.005 SC Data - All Services | Received security definition for symbol F.US.DBM21 | 2021-06-07 08:50:36.005 Opened cached Depth file: D:\Sierrachart\Data\MarketDepthData\F.US.DBM21.2021-06-07.depth | 2021-06-07 08:50:36.005 SC Data - All Services | Clearing market depth for F.US.DDM21 | 2021-06-07 08:50:36.005 Opened cached Depth file: D:\Sierrachart\Data\MarketDepthData\F.US.DDM21.2021-06-07.depth | 2021-06-07 08:50:36.005 SC Data - All Services | Received security definition for symbol F.US.DDM21 | 2021-06-07 08:50:36.005 SC Data - All Services | Clearing market depth for F.US.DSXM21 | 2021-06-07 08:50:36.006 SC Data - All Services | Received security definition for symbol F.US.DSXM21 | 2021-06-07 08:50:36.006 Opened cached Depth file: D:\Sierrachart\Data\MarketDepthData\F.US.DSXM21.2021-06-07.depth | 2021-06-07 08:50:36.006 Mapping F.US.ENQM21 to NQM21. Service code: cme | 2021-06-07 08:50:36.110 SC Data - All Services | Starting real-time market data updates for: F.US.ENQM21 (NQM21). ID: 8 Service code: cme | 2021-06-07 08:50:36.110 CQG WebAPI | Sending symbol resolution request for F.US.ENQM21. ID: 821215 | 2021-06-07 08:50:36.110 SC Data - All Services | Requesting security definition data for: F.US.ENQM21 (NQM21). ID: 8 | 2021-06-07 08:50:36.110 Added historical Intraday data request for F.US.ENQM21 to the queue. | 2021-06-07 08:50:36.110 Intraday data recording state for symbol F.US.ENQM21 is set to download 'Pending'. | 2021-06-07 08:50:36.110 Triggering next historical data download in queue. | 2021-06-07 08:50:36.110 CQG WebAPI | Received symbol resolution report for symbol F.US.ENQM21. Search Symbol: F.US.ENQM21. Request ID: 821215. Contract ID: 8. | 2021-06-07 08:50:36.187 Using Bid/Ask average for last trade price for US30 | 2021-06-07 08:50:36.187 SC DTC Data with Market Depth | Starting real-time market data updates for: US30. ID: 9 Service code: fxcm | 2021-06-07 08:50:36.187 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2021-06-07 08:50:36.187 SC DTC Data with Market Depth | Requesting security definition data for: US30. ID: 9 | 2021-06-07 08:50:36.187 Added historical Intraday data request for US30 to the queue. | 2021-06-07 08:50:36.187 Intraday data recording state for symbol US30 is set to download 'Pending'. | 2021-06-07 08:50:36.187 Triggering next historical data download in queue. | 2021-06-07 08:50:36.187 DTC Client socket (5) | Creating socket. | 2021-06-07 08:50:36.188 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-07 08:50:36.188 DTC Client socket (5) | Connecting to IP: 192.81.56.146. | 2021-06-07 08:50:36.188 Using Bid/Ask average for last trade price for USOil | 2021-06-07 08:50:36.191 SC DTC Data with Market Depth | Starting real-time market data updates for: USOil. ID: 10 Service code: fxcm | 2021-06-07 08:50:36.191 SC DTC Data with Market Depth | Requesting security definition data for: USOil. ID: 10 | 2021-06-07 08:50:36.191 Added historical Intraday data request for USOil to the queue. | 2021-06-07 08:50:36.191 Intraday data recording state for symbol USOil is set to download 'Pending'. | 2021-06-07 08:50:36.191 Triggering next historical data download in queue. | 2021-06-07 08:50:36.191 Mapping F.US.DDH21 to FDAX202103_FUT_EUREX. Service code: eurex | 2021-06-07 08:50:36.247 SC Data - All Services | Starting real-time market data updates for: F.US.DDH21 (FDAX202103_FUT_EUREX). ID: 11 Service code: eurex | 2021-06-07 08:50:36.247 CQG WebAPI | Sending symbol resolution request for F.US.DDH21. ID: 821216 | 2021-06-07 08:50:36.247 SC Data - All Services | Requesting security definition data for: F.US.DDH21 (FDAX202103_FUT_EUREX). ID: 11 | 2021-06-07 08:50:36.247 Requesting market depth updates for: F.US.DDH21 if supported. | 2021-06-07 08:50:36.247 Added historical Intraday data request for F.US.DDH21 to the queue. | 2021-06-07 08:50:36.247 Intraday data recording state for symbol F.US.DDH21 is set to download 'Pending'. | 2021-06-07 08:50:36.247 Triggering next historical data download in queue. | 2021-06-07 08:50:36.247 SC DTC Data with Market Depth | Network connection to server complete. | 2021-06-07 08:50:36.299 SC DTC Data with Market Depth | Starting socket receive thread. | 2021-06-07 08:50:36.299 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-07 08:50:36.299 CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-07 08:50:36.353 Symbol Error - F.US.DDH21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-07 08:50:36.353 Opened cached Depth file: D:\Sierrachart\Data\MarketDepthData\F.US.DDH21.2021-06-07.depth | 2021-06-07 08:50:36.365 SC Data - All Services | Clearing market depth for F.US.DDH21 | 2021-06-07 08:50:36.365 SC Data - All Services | Real-time data for symbol F.US.DDH21 is currently unavailable. | 2021-06-07 08:50:36.365 SC Data - All Services | Received security definition for symbol F.US.DDH21 | 2021-06-07 08:50:36.365 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2021-06-07 08:50:36.437 SC DTC Data with Market Depth | Sending logon request message. | 2021-06-07 08:50:36.437 SC Data - All Services | Received logon response. | 2021-06-07 08:50:36.692 SC Data - All Services | Server Name: SC Realtime Server. | 2021-06-07 08:50:36.692 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-07 08:50:36.692 SC Data - All Services | Successfully connected. | 2021-06-07 08:50:36.692 SC Data - All Services | Trading is not supported. | 2021-06-07 08:50:36.692 SC Data - All Services | Restarting real-time data updates for symbol: F.US.ENQM21 -> NQM21 | 2021-06-07 08:50:36.692 SC Data - All Services | Restarting real-time data updates for symbol: F.US.EPM21 -> ESM21. Market Depth data restarted. | 2021-06-07 08:50:36.692 SC Data - All Services | Restarting real-time data updates for symbol: F.US.EU6M21 -> 6EM21. Market Depth data restarted. | 2021-06-07 08:50:36.692 SC Data - All Services | Restarting real-time data updates for symbol: F.US.JY6M21 -> 6JM21. Market Depth data restarted. | 2021-06-07 08:50:36.692 SC Data - All Services | Restarting real-time data updates for symbol: F.US.NIYM21 -> NIYM21. Market Depth data restarted. | 2021-06-07 08:50:36.692 SC Data - All Services | Clearing market depth for F.US.EPM21 | 2021-06-07 08:50:37.032 SC Data - All Services | Received security definition for symbol F.US.ENQM21 | 2021-06-07 08:50:37.032 SC Data - All Services | Received security definition for symbol F.US.EPM21 | 2021-06-07 08:50:37.032 Opened cached Depth file: D:\Sierrachart\Data\MarketDepthData\F.US.EPM21.2021-06-07.depth | 2021-06-07 08:50:37.032 SC Data - All Services | Clearing market depth for F.US.EU6M21 | 2021-06-07 08:50:37.032 Opened cached Depth file: D:\Sierrachart\Data\MarketDepthData\F.US.EU6M21.2021-06-07.depth | 2021-06-07 08:50:37.033 SC Data - All Services | Received security definition for symbol F.US.EU6M21 | 2021-06-07 08:50:37.033 SC Data - All Services | Clearing market depth for F.US.JY6M21 | 2021-06-07 08:50:37.033 Opened cached Depth file: D:\Sierrachart\Data\MarketDepthData\F.US.JY6M21.2021-06-07.depth | 2021-06-07 08:50:37.033 SC Data - All Services | Received security definition for symbol F.US.JY6M21 | 2021-06-07 08:50:37.033 SC Data - All Services | Clearing market depth for F.US.NIYM21 | 2021-06-07 08:50:37.033 Opened cached Depth file: D:\Sierrachart\Data\MarketDepthData\F.US.NIYM21.2021-06-07.depth | 2021-06-07 08:50:37.033 SC Data - All Services | Received security definition for symbol F.US.NIYM21 | 2021-06-07 08:50:37.033 SC DTC Data with Market Depth | Received logon response. | 2021-06-07 08:50:37.156 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2021-06-07 08:50:37.156 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2021-06-07 08:50:37.156 SC DTC Data with Market Depth | Successfully connected. | 2021-06-07 08:50:37.156 SC DTC Data with Market Depth | Trading is not supported. | 2021-06-07 08:50:37.156 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: US30 | 2021-06-07 08:50:37.156 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USOil | 2021-06-07 08:50:37.156 SC DTC Data with Market Depth | Received security definition for symbol US30 | 2021-06-07 08:50:37.389 SC DTC Data with Market Depth | Received security definition for symbol USOil | 2021-06-07 08:50:37.389 CQG WebAPI | Sending positions subscribe request. RequestID: 821217 | 2021-06-07 08:50:40.400 CQG WebAPI | Sending orders subscribe request. RequestID: 821218 | 2021-06-07 08:50:40.400 HD Request # 23 | Downloading Intraday chart data for F.US.DDM21 to the file F.US.DDM21.scid. Service: eurex | 2021-06-07 08:50:41.169 HD Request # 23 | Download start date-time: 2021-06-07 08:50:28.000000. File last date-time: 2021-06-07 08:50:28.742000 | 2021-06-07 08:50:41.169 HD Request # 23 | Using server: ds14.sierracharts.com port 10149 | 2021-06-07 08:50:41.170 Socket (6) | Creating socket. | 2021-06-07 08:50:41.170 Socket (6) | New receive buffer size: 5242880 | 2021-06-07 08:50:41.170 Socket (6) | Connecting to IP: 157.90.1.40. | 2021-06-07 08:50:41.170 HD Request # 23 | Setting DTC encoding to Binary VLS | 2021-06-07 08:50:41.223 HD Request # 23 | Sending historical data logon request message. | 2021-06-07 08:50:41.223 HD Request # 23 | Requesting Intraday data. Start date-time: 2021-06-07 08:50:28. Record interval: 0. Symbol: FDAX202106_FUT_EUREX | 2021-06-07 08:50:41.365 HD Request # 23 | Decompressing data. | 2021-06-07 08:50:41.393 HD Request # 23 | Receiving Intraday data for F.US.DDM21 starting at 2021-06-07 08:50:28.742000 | 2021-06-07 08:50:41.394 Socket (6) | CloseSocket call. | 2021-06-07 08:50:41.394 Historical data download thread signaled to stop. | 2021-06-07 08:50:41.394 HD Request # 23 | Received 1 record from 2021-06-07 08:50:28.742000 to 2021-06-07 08:50:28.742000 (0.0 seconds) and wrote 0 records for F.US.DDM21 | 2021-06-07 08:50:41.394 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-06-07 08:50:41.394 HD Request # 23 | Add time&sales data | Remembered last file record date-time: 2021-06-07 06:50:28.742000 | 2021-06-07 08:50:41.394 HD Request # 23 | Completion time: 0s | 2021-06-07 08:50:41.394 HD Request # 23 | Intraday data download complete for F.US.DDM21. Unique request ID: 23 | 2021-06-07 08:50:41.394 Removing historical data download ID 23. | 2021-06-07 08:50:41.394 Real-time Intraday chart data file updates started for F.US.DDM21 | 2021-06-07 08:50:41.394 Intraday chart data file opened for F.US.DDM21 | 2021-06-07 08:50:41.394 HD Request # 23 | Enabling Intraday chart updating for symbol. | 2021-06-07 08:50:41.394 F.US.DDM21 [C][M] 10 Sec #3 | Historical data download for additional symbol F.US.DDM21 with ID 23 has completed. | 2021-06-07 08:50:41.394 Triggering next historical data download in queue. | 2021-06-07 08:50:41.394 HD Request # 24 | Downloading Intraday chart data for F.US.DSXM21 to the file F.US.DSXM21.scid. Service: eurex | 2021-06-07 08:50:41.395 HD Request # 24 | Download start date-time: 2021-06-07 08:50:21.000000. File last date-time: 2021-06-07 08:50:21.024000 | 2021-06-07 08:50:41.395 HD Request # 24 | Using server: ds24.sierracharts.com port 10150 | 2021-06-07 08:50:41.395 Socket (8) | Creating socket. | 2021-06-07 08:50:41.395 Socket (8) | New receive buffer size: 5242880 | 2021-06-07 08:50:41.395 Socket (8) | Connecting to IP: 80.81.77.132. | 2021-06-07 08:50:41.395 Socket (6) | Socket gracefully closed by remote side. | 2021-06-07 08:50:41.432 Socket (6) | Closed. | 2021-06-07 08:50:41.432 HD Request # 24 | Setting DTC encoding to Binary VLS | 2021-06-07 08:50:41.452 HD Request # 24 | Sending historical data logon request message. | 2021-06-07 08:50:41.452 HD Request # 24 | Requesting Intraday data. Start date-time: 2021-06-07 08:50:21. Record interval: 0. Symbol: FESX202106_FUT_EUREX | 2021-06-07 08:50:41.584 HD Request # 24 | Decompressing data. | 2021-06-07 08:50:41.620 HD Request # 24 | Receiving Intraday data for F.US.DSXM21 starting at 2021-06-07 08:50:21.024000 | 2021-06-07 08:50:41.620 Socket (8) | CloseSocket call. | 2021-06-07 08:50:41.620 Socket (8) | Shutdown started. Waiting for graceful close. | 2021-06-07 08:50:41.621 Socket (8) | Socket gracefully closed by remote side. | 2021-06-07 08:50:41.643 Socket (8) | Closed. | 2021-06-07 08:50:41.643 Historical data download thread signaled to stop. | 2021-06-07 08:50:41.785 HD Request # 24 | Received 1 record from 2021-06-07 08:50:21.024000 to 2021-06-07 08:50:21.024000 (0.0 seconds) and wrote 0 records for F.US.DSXM21 | 2021-06-07 08:50:41.785 HD Request # 24 | Add time&sales data | Remembered last file record date-time: 2021-06-07 06:50:21.024000 | 2021-06-07 08:50:41.785 Added 7 Time and Sales records to Intraday data file for F.US.DSXM21 after download. | 2021-06-07 08:50:41.786 HD Request # 24 | Timestamp of first Intraday data file record written: 2021-06-07 08:50:38.498000 | 2021-06-07 08:50:41.786 HD Request # 24 | Completion time: 0s | 2021-06-07 08:50:41.786 HD Request # 24 | Intraday data download complete for F.US.DSXM21. Unique request ID: 24 | 2021-06-07 08:50:41.786 Removing historical data download ID 24. | 2021-06-07 08:50:41.786 Real-time Intraday chart data file updates started for F.US.DSXM21 | 2021-06-07 08:50:41.786 Intraday chart data file opened for F.US.DSXM21 | 2021-06-07 08:50:41.786 HD Request # 24 | Enabling Intraday chart updating for symbol. | 2021-06-07 08:50:41.786 Triggering next historical data download in queue. | 2021-06-07 08:50:41.786 HD Request # 25 | Downloading Intraday chart data for F.US.DBM21 to the file F.US.DBM21.scid. Service: eurex | 2021-06-07 08:50:41.786 HD Request # 25 | Download start date-time: 2021-06-07 08:50:04.000000. File last date-time: 2021-06-07 08:50:04.111000 | 2021-06-07 08:50:41.786 HD Request # 25 | Using server: ds14.sierracharts.com port 10149 | 2021-06-07 08:50:41.786 Socket (6) | Creating socket. | 2021-06-07 08:50:41.786 Socket (6) | New receive buffer size: 5242880 | 2021-06-07 08:50:41.786 Socket (6) | Connecting to IP: 157.90.1.40. | 2021-06-07 08:50:41.786 HD Request # 25 | Setting DTC encoding to Binary VLS | 2021-06-07 08:50:41.848 HD Request # 25 | Sending historical data logon request message. | 2021-06-07 08:50:41.848 HD Request # 25 | Requesting Intraday data. Start date-time: 2021-06-07 08:50:04. Record interval: 0. Symbol: FGBL202106_FUT_EUREX | 2021-06-07 08:50:41.871 HD Request # 25 | Decompressing data. | 2021-06-07 08:50:41.899 HD Request # 25 | Receiving Intraday data for F.US.DBM21 starting at 2021-06-07 08:50:04.111000 | 2021-06-07 08:50:41.899 Socket (6) | CloseSocket call. | 2021-06-07 08:50:41.899 Historical data download thread signaled to stop. | 2021-06-07 08:50:41.900 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-06-07 08:50:41.900 HD Request # 25 | Received 1 record from 2021-06-07 08:50:04.111000 to 2021-06-07 08:50:04.111000 (0.0 seconds) and wrote 0 records for F.US.DBM21 | 2021-06-07 08:50:41.900 HD Request # 25 | Add time&sales data | Remembered last file record date-time: 2021-06-07 06:50:04.111000 | 2021-06-07 08:50:41.900 HD Request # 25 | Completion time: 0s | 2021-06-07 08:50:41.900 HD Request # 25 | Intraday data download complete for F.US.DBM21. Unique request ID: 25 | 2021-06-07 08:50:41.900 Removing historical data download ID 25. | 2021-06-07 08:50:41.900 Real-time Intraday chart data file updates started for F.US.DBM21 | 2021-06-07 08:50:41.900 Intraday chart data file opened for F.US.DBM21 | 2021-06-07 08:50:41.900 HD Request # 25 | Enabling Intraday chart updating for symbol. | 2021-06-07 08:50:41.900 Triggering next historical data download in queue. | 2021-06-07 08:50:41.900 Delaying start of download for F.US.JY6M21 | 2021-06-07 08:50:41.900 Socket (6) | Socket gracefully closed by remote side. | 2021-06-07 08:50:41.924 Socket (6) | Closed. | 2021-06-07 08:50:41.924 HD Request # 26 | Downloading Intraday chart data for F.US.JY6M21 to the file F.US.JY6M21.scid. Service: cme | 2021-06-07 08:50:42.172 HD Request # 26 | Download start date-time: 2021-06-07 08:50:03.000000. File last date-time: 2021-06-07 08:50:03.756001 | 2021-06-07 08:50:42.173 HD Request # 26 | Using server: ds23.sierracharts.com port 10150 | 2021-06-07 08:50:42.173 Socket (6) | Creating socket. | 2021-06-07 08:50:42.173 Socket (6) | New receive buffer size: 5242880 | 2021-06-07 08:50:42.173 Socket (6) | Connecting to IP: 216.1.90.130. | 2021-06-07 08:50:42.173 HD Request # 26 | Setting DTC encoding to Binary VLS | 2021-06-07 08:50:42.428 HD Request # 26 | Sending historical data logon request message. | 2021-06-07 08:50:42.428 HD Request # 26 | Requesting Intraday data. Start date-time: 2021-06-07 08:50:03. Record interval: 0. Symbol: 6JM21 | 2021-06-07 08:50:43.000 HD Request # 26 | Decompressing data. | 2021-06-07 08:50:43.118 HD Request # 26 | Receiving Intraday data for F.US.JY6M21 starting at 2021-06-07 08:50:03.567000 | 2021-06-07 08:50:43.118 Socket (6) | CloseSocket call. | 2021-06-07 08:50:43.119 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-06-07 08:50:43.119 Historical data download thread signaled to stop. | 2021-06-07 08:50:43.145 HD Request # 26 | Timestamp of first Intraday data file record written: 2021-06-07 08:50:38.128000 | 2021-06-07 08:50:43.145 HD Request # 26 | Received 14 records from 2021-06-07 08:50:03.567000 to 2021-06-07 08:50:38.128006 (34.6 seconds) and wrote 7 records for F.US.JY6M21 | 2021-06-07 08:50:43.145 HD Request # 26 | Add time&sales data | Remembered last file record date-time: 2021-06-07 06:50:38.128006 | 2021-06-07 08:50:43.149 Added 3 Time and Sales records to Intraday data file for F.US.JY6M21 after download. | 2021-06-07 08:50:43.149 HD Request # 26 | Completion time: 1s | 2021-06-07 08:50:43.149 HD Request # 26 | Intraday data download complete for F.US.JY6M21. Unique request ID: 26 | 2021-06-07 08:50:43.149 Removing historical data download ID 26. | 2021-06-07 08:50:43.149 Real-time Intraday chart data file updates started for F.US.JY6M21 | 2021-06-07 08:50:43.149 Intraday chart data file opened for F.US.JY6M21 | 2021-06-07 08:50:43.149 HD Request # 26 | Enabling Intraday chart updating for symbol. | 2021-06-07 08:50:43.149 Triggering next historical data download in queue. | 2021-06-07 08:50:43.149 HD Request # 27 | Downloading Intraday chart data for F.US.EPM21 to the file F.US.EPM21.scid. Service: cme | 2021-06-07 08:50:43.149 HD Request # 27 | Download start date-time: 2021-06-07 08:50:24.000000. File last date-time: 2021-06-07 08:50:24.985009 | 2021-06-07 08:50:43.149 HD Request # 27 | Using server: ds21.sierracharts.com port 10149 | 2021-06-07 08:50:43.149 Socket (8) | Creating socket. | 2021-06-07 08:50:43.150 Socket (8) | New receive buffer size: 5242880 | 2021-06-07 08:50:43.150 Socket (8) | Connecting to IP: 216.1.90.129. | 2021-06-07 08:50:43.150 Socket (6) | Socket gracefully closed by remote side. | 2021-06-07 08:50:43.238 Socket (6) | Closed. | 2021-06-07 08:50:43.238 HD Request # 27 | Setting DTC encoding to Binary VLS | 2021-06-07 08:50:43.392 HD Request # 27 | Sending historical data logon request message. | 2021-06-07 08:50:43.392 HD Request # 27 | Requesting Intraday data. Start date-time: 2021-06-07 08:50:24. Record interval: 0. Symbol: ESM21 | 2021-06-07 08:50:43.963 HD Request # 27 | Decompressing data. | 2021-06-07 08:50:44.078 HD Request # 27 | Receiving Intraday data for F.US.EPM21 starting at 2021-06-07 08:50:24.985000 | 2021-06-07 08:50:44.079 Socket (8) | CloseSocket call. | 2021-06-07 08:50:44.079 Socket (8) | Shutdown started. Waiting for graceful close. | 2021-06-07 08:50:44.079 Historical data download thread signaled to stop. | 2021-06-07 08:50:44.079 HD Request # 27 | Timestamp of first Intraday data file record written: 2021-06-07 08:50:34.356000 | 2021-06-07 08:50:44.079 HD Request # 27 | Received 34 records from 2021-06-07 08:50:24.985000 to 2021-06-07 08:50:37.853010 (12.9 seconds) and wrote 24 records for F.US.EPM21 | 2021-06-07 08:50:44.079 HD Request # 27 | Add time&sales data | Remembered last file record date-time: 2021-06-07 06:50:37.853010 | 2021-06-07 08:50:44.083 Added 13 Time and Sales records to Intraday data file for F.US.EPM21 after download. | 2021-06-07 08:50:44.083 HD Request # 27 | Completion time: 1s | 2021-06-07 08:50:44.083 HD Request # 27 | Intraday data download complete for F.US.EPM21. Unique request ID: 27 | 2021-06-07 08:50:44.083 Removing historical data download ID 27. | 2021-06-07 08:50:44.083 Real-time Intraday chart data file updates started for F.US.EPM21 | 2021-06-07 08:50:44.083 Intraday chart data file opened for F.US.EPM21 | 2021-06-07 08:50:44.083 HD Request # 27 | Enabling Intraday chart updating for symbol. | 2021-06-07 08:50:44.083 Triggering next historical data download in queue. | 2021-06-07 08:50:44.083 HD Request # 28 | Downloading Intraday chart data for F.US.NIYM21 to the file F.US.NIYM21.scid. Service: cme | 2021-06-07 08:50:44.083 HD Request # 28 | Download start date-time: 2021-06-07 08:50:02.000000. File last date-time: 2021-06-07 08:50:02.320000 | 2021-06-07 08:50:44.083 HD Request # 28 | Using server: ds23.sierracharts.com port 10150 | 2021-06-07 08:50:44.083 Socket (6) | Creating socket. | 2021-06-07 08:50:44.083 Socket (6) | New receive buffer size: 5242880 | 2021-06-07 08:50:44.083 Socket (6) | Connecting to IP: 216.1.90.130. | 2021-06-07 08:50:44.083 Socket (8) | Socket gracefully closed by remote side. | 2021-06-07 08:50:44.198 Socket (8) | Closed. | 2021-06-07 08:50:44.198 HD Request # 28 | Setting DTC encoding to Binary VLS | 2021-06-07 08:50:44.331 HD Request # 28 | Sending historical data logon request message. | 2021-06-07 08:50:44.331 HD Request # 28 | Requesting Intraday data. Start date-time: 2021-06-07 08:50:02. Record interval: 0. Symbol: NIYM21 | 2021-06-07 08:50:44.447 HD Request # 28 | Decompressing data. | 2021-06-07 08:50:44.563 HD Request # 28 | Receiving Intraday data for F.US.NIYM21 starting at 2021-06-07 08:50:02.320000 | 2021-06-07 08:50:44.565 Socket (6) | CloseSocket call. | 2021-06-07 08:50:44.565 Historical data download thread signaled to stop. | 2021-06-07 08:50:44.565 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-06-07 08:50:44.565 HD Request # 28 | Received 1 record from 2021-06-07 08:50:02.320000 to 2021-06-07 08:50:02.320000 (0.0 seconds) and wrote 0 records for F.US.NIYM21 | 2021-06-07 08:50:44.565 HD Request # 28 | Add time&sales data | Remembered last file record date-time: 2021-06-07 06:50:02.320000 | 2021-06-07 08:50:44.565 HD Request # 28 | Completion time: 0s | 2021-06-07 08:50:44.565 HD Request # 28 | Intraday data download complete for F.US.NIYM21. Unique request ID: 28 | 2021-06-07 08:50:44.565 Removing historical data download ID 28. | 2021-06-07 08:50:44.565 Real-time Intraday chart data file updates started for F.US.NIYM21 | 2021-06-07 08:50:44.565 Intraday chart data file opened for F.US.NIYM21 | 2021-06-07 08:50:44.565 HD Request # 28 | Enabling Intraday chart updating for symbol. | 2021-06-07 08:50:44.565 Triggering next historical data download in queue. | 2021-06-07 08:50:44.565 HD Request # 29 | Downloading Intraday chart data for F.US.EU6M21 to the file F.US.EU6M21.scid. Service: cme | 2021-06-07 08:50:44.565 HD Request # 29 | Download start date-time: 2021-06-07 08:50:22.000000. File last date-time: 2021-06-07 08:50:22.800000 | 2021-06-07 08:50:44.565 HD Request # 29 | Using server: ds21.sierracharts.com port 10149 | 2021-06-07 08:50:44.565 Socket (8) | Creating socket. | 2021-06-07 08:50:44.565 Socket (8) | New receive buffer size: 5242880 | 2021-06-07 08:50:44.565 Socket (8) | Connecting to IP: 216.1.90.129. | 2021-06-07 08:50:44.565 Socket (6) | Socket gracefully closed by remote side. | 2021-06-07 08:50:44.683 Socket (6) | Closed. | 2021-06-07 08:50:44.683 HD Request # 29 | Setting DTC encoding to Binary VLS | 2021-06-07 08:50:44.807 HD Request # 29 | Sending historical data logon request message. | 2021-06-07 08:50:44.807 HD Request # 29 | Requesting Intraday data. Start date-time: 2021-06-07 08:50:22. Record interval: 0. Symbol: 6EM21 | 2021-06-07 08:50:44.925 HD Request # 29 | Decompressing data. | 2021-06-07 08:50:45.042 HD Request # 29 | Receiving Intraday data for F.US.EU6M21 starting at 2021-06-07 08:50:22.800000 | 2021-06-07 08:50:45.042 Socket (8) | CloseSocket call. | 2021-06-07 08:50:45.042 Socket (8) | Shutdown started. Waiting for graceful close. | 2021-06-07 08:50:45.042 Historical data download thread signaled to stop. | 2021-06-07 08:50:45.078 HD Request # 29 | Timestamp of first Intraday data file record written: 2021-06-07 08:50:34.297000 | 2021-06-07 08:50:45.078 HD Request # 29 | Received 2 records from 2021-06-07 08:50:22.800000 to 2021-06-07 08:50:34.297000 (11.5 seconds) and wrote 1 record for F.US.EU6M21 | 2021-06-07 08:50:45.078 HD Request # 29 | Add time&sales data | Remembered last file record date-time: 2021-06-07 06:50:34.297000 | 2021-06-07 08:50:45.081 Added 6 Time and Sales records to Intraday data file for F.US.EU6M21 after download. | 2021-06-07 08:50:45.081 HD Request # 29 | Completion time: 1s | 2021-06-07 08:50:45.081 HD Request # 29 | Intraday data download complete for F.US.EU6M21. Unique request ID: 29 | 2021-06-07 08:50:45.081 Removing historical data download ID 29. | 2021-06-07 08:50:45.081 Real-time Intraday chart data file updates started for F.US.EU6M21 | 2021-06-07 08:50:45.081 Intraday chart data file opened for F.US.EU6M21 | 2021-06-07 08:50:45.081 HD Request # 29 | Enabling Intraday chart updating for symbol. | 2021-06-07 08:50:45.081 Triggering next historical data download in queue. | 2021-06-07 08:50:45.081 HD Request # 30 | Downloading Intraday chart data for F.US.ENQM21 to the file F.US.ENQM21.scid. Service: cme | 2021-06-07 08:50:45.081 HD Request # 30 | Download start date-time: 2021-06-07 08:50:28.000000. File last date-time: 2021-06-07 08:50:28.822000 | 2021-06-07 08:50:45.081 HD Request # 30 | Using server: ds23.sierracharts.com port 10150 | 2021-06-07 08:50:45.082 Socket (6) | Creating socket. | 2021-06-07 08:50:45.082 Socket (6) | New receive buffer size: 5242880 | 2021-06-07 08:50:45.082 Socket (6) | Connecting to IP: 216.1.90.130. | 2021-06-07 08:50:45.082 Socket (8) | Socket gracefully closed by remote side. | 2021-06-07 08:50:45.162 Socket (8) | Closed. | 2021-06-07 08:50:45.162 HD Request # 30 | Setting DTC encoding to Binary VLS | 2021-06-07 08:50:45.332 HD Request # 30 | Sending historical data logon request message. | 2021-06-07 08:50:45.332 HD Request # 30 | Requesting Intraday data. Start date-time: 2021-06-07 08:50:28. Record interval: 0. Symbol: NQM21 | 2021-06-07 08:50:45.449 HD Request # 30 | Decompressing data. | 2021-06-07 08:50:45.567 HD Request # 30 | Receiving Intraday data for F.US.ENQM21 starting at 2021-06-07 08:50:28.328000 | 2021-06-07 08:50:45.567 Socket (6) | CloseSocket call. | 2021-06-07 08:50:45.568 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-06-07 08:50:45.568 Historical data download thread signaled to stop. | 2021-06-07 08:50:45.568 HD Request # 30 | Timestamp of first Intraday data file record written: 2021-06-07 08:50:29.986000 | 2021-06-07 08:50:45.568 HD Request # 30 | Received 16 records from 2021-06-07 08:50:28.328000 to 2021-06-07 08:50:37.853000 (9.5 seconds) and wrote 14 records for F.US.ENQM21 | 2021-06-07 08:50:45.568 HD Request # 30 | Add time&sales data | Remembered last file record date-time: 2021-06-07 06:50:37.853000 | 2021-06-07 08:50:45.572 Added 2 Time and Sales records to Intraday data file for F.US.ENQM21 after download. | 2021-06-07 08:50:45.572 HD Request # 30 | Completion time: 0s | 2021-06-07 08:50:45.572 HD Request # 30 | Intraday data download complete for F.US.ENQM21. Unique request ID: 30 | 2021-06-07 08:50:45.572 Removing historical data download ID 30. | 2021-06-07 08:50:45.572 Real-time Intraday chart data file updates started for F.US.ENQM21 | 2021-06-07 08:50:45.572 Intraday chart data file opened for F.US.ENQM21 | 2021-06-07 08:50:45.572 HD Request # 30 | Enabling Intraday chart updating for symbol. | 2021-06-07 08:50:45.572 Triggering next historical data download in queue. | 2021-06-07 08:50:45.572 HD Request # 31 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2021-06-07 08:50:45.572 HD Request # 31 | Download start date-time: 2021-06-07 08:50:25.000000. File last date-time: 2021-06-07 08:50:25.093000 | 2021-06-07 08:50:45.572 HD Request # 31 | Using server: ds12.sierracharts.com port 10149 | 2021-06-07 08:50:45.572 Socket (8) | Creating socket. | 2021-06-07 08:50:45.572 Socket (8) | New receive buffer size: 5242880 | 2021-06-07 08:50:45.572 Socket (8) | Connecting to IP: 204.15.197.14. | 2021-06-07 08:50:45.573 Socket (6) | Socket gracefully closed by remote side. | 2021-06-07 08:50:45.688 Socket (6) | Closed. | 2021-06-07 08:50:45.688 HD Request # 31 | Setting DTC encoding to Binary VLS | 2021-06-07 08:50:45.840 HD Request # 31 | Sending historical data logon request message. | 2021-06-07 08:50:45.840 HD Request # 31 | Requesting Intraday data. Start date-time: 2021-06-07 08:50:25. Record interval: 0. Symbol: US30 | 2021-06-07 08:50:46.484 HD Request # 31 | Decompressing data. | 2021-06-07 08:50:46.592 HD Request # 31 | Receiving Intraday data for US30 starting at 2021-06-07 08:50:25.080000 | 2021-06-07 08:50:46.593 Socket (8) | CloseSocket call. | 2021-06-07 08:50:46.593 Socket (8) | Shutdown started. Waiting for graceful close. | 2021-06-07 08:50:46.594 Historical data download thread signaled to stop. | 2021-06-07 08:50:46.594 HD Request # 31 | Timestamp of first Intraday data file record written: 2021-06-07 08:50:34.462000 | 2021-06-07 08:50:46.594 HD Request # 31 | Received 10 records from 2021-06-07 08:50:25.080000 to 2021-06-07 08:50:41.923000 (16.8 seconds) and wrote 8 records for US30 | 2021-06-07 08:50:46.594 HD Request # 31 | Add time&sales data | Remembered last file record date-time: 2021-06-07 06:50:41.923000 | 2021-06-07 08:50:46.597 Added 1 Time and Sales records to Intraday data file for US30 after download. | 2021-06-07 08:50:46.597 HD Request # 31 | Completion time: 1s | 2021-06-07 08:50:46.597 HD Request # 31 | Intraday data download complete for US30. Unique request ID: 31 | 2021-06-07 08:50:46.597 Removing historical data download ID 31. | 2021-06-07 08:50:46.597 Real-time Intraday chart data file updates started for US30 | 2021-06-07 08:50:46.597 Intraday chart data file opened for US30 | 2021-06-07 08:50:46.597 HD Request # 31 | Enabling Intraday chart updating for symbol. | 2021-06-07 08:50:46.597 Triggering next historical data download in queue. | 2021-06-07 08:50:46.597 HD Request # 32 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2021-06-07 08:50:46.597 HD Request # 32 | Download start date-time: 2021-06-07 08:50:23.000000. File last date-time: 2021-06-07 08:50:23.332000 | 2021-06-07 08:50:46.597 HD Request # 32 | Using server: ds4.sierracharts.com port 10150 | 2021-06-07 08:50:46.597 Socket (6) | Creating socket. | 2021-06-07 08:50:46.598 Socket (6) | New receive buffer size: 5242880 | 2021-06-07 08:50:46.598 Socket (6) | Connecting to IP: 192.81.56.146. | 2021-06-07 08:50:46.598 Socket (8) | Socket gracefully closed by remote side. | 2021-06-07 08:50:46.706 Socket (8) | Closed. | 2021-06-07 08:50:46.706 HD Request # 32 | Setting DTC encoding to Binary VLS | 2021-06-07 08:50:46.822 HD Request # 32 | Sending historical data logon request message. | 2021-06-07 08:50:46.822 HD Request # 32 | Requesting Intraday data. Start date-time: 2021-06-07 08:50:23. Record interval: 0. Symbol: USOil | 2021-06-07 08:50:47.455 Opened cached Intraday file: D:\Sierrachart\Data\F.US.EPM21.scid. Thread ID: 10568 | 2021-06-07 08:50:47.480 HD Request # 32 | Decompressing data. | 2021-06-07 08:50:47.561 HD Request # 32 | Receiving Intraday data for USOil starting at 2021-06-07 08:50:23.452000 | 2021-06-07 08:50:47.562 Socket (6) | CloseSocket call. | 2021-06-07 08:50:47.562 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-06-07 08:50:47.562 Historical data download thread signaled to stop. | 2021-06-07 08:50:47.562 HD Request # 32 | Timestamp of first Intraday data file record written: 2021-06-07 08:50:23.452000 | 2021-06-07 08:50:47.562 HD Request # 32 | Received 21 records from 2021-06-07 08:50:23.452000 to 2021-06-07 08:50:40.569000 (17.1 seconds) and wrote 21 records for USOil | 2021-06-07 08:50:47.562 HD Request # 32 | Add time&sales data | Remembered last file record date-time: 2021-06-07 06:50:40.569000 | 2021-06-07 08:50:47.565 Added 4 Time and Sales records to Intraday data file for USOil after download. | 2021-06-07 08:50:47.565 HD Request # 32 | Completion time: 1s | 2021-06-07 08:50:47.566 HD Request # 32 | Intraday data download complete for USOil. Unique request ID: 32 | 2021-06-07 08:50:47.566 Removing historical data download ID 32. | 2021-06-07 08:50:47.566 Real-time Intraday chart data file updates started for USOil | 2021-06-07 08:50:47.566 Intraday chart data file opened for USOil | 2021-06-07 08:50:47.566 HD Request # 32 | Enabling Intraday chart updating for symbol. | 2021-06-07 08:50:47.566 Triggering next historical data download in queue. | 2021-06-07 08:50:47.566 HD Request # 33 | Downloading Intraday chart data for F.US.DDH21 to the file F.US.DDH21.scid. Service: eurex | 2021-06-07 08:50:47.566 HD Request # 33 | Download start date-time: 2021-03-19 13:00:00.000000. File last date-time: 2021-03-19 13:00:00.009000 | 2021-06-07 08:50:47.566 HD Request # 33 | Using server: ds14.sierracharts.com port 10149 | 2021-06-07 08:50:47.566 Socket (8) | Creating socket. | 2021-06-07 08:50:47.566 Socket (8) | New receive buffer size: 5242880 | 2021-06-07 08:50:47.566 Socket (8) | Connecting to IP: 157.90.1.40. | 2021-06-07 08:50:47.566 HD Request # 33 | Setting DTC encoding to Binary VLS | 2021-06-07 08:50:47.615 HD Request # 33 | Sending historical data logon request message. | 2021-06-07 08:50:47.615 HD Request # 33 | Requesting Intraday data. Start date-time: 2021-03-19 13:00:00. Record interval: 0. Symbol: FDAX202103_FUT_EUREX | 2021-06-07 08:50:47.638 HD Request # 33 | Decompressing data. | 2021-06-07 08:50:47.660 HD Request # 33 | Receiving Intraday data for F.US.DDH21 starting at 2021-03-19 13:00:00.007000 | 2021-06-07 08:50:47.661 Socket (8) | CloseSocket call. | 2021-06-07 08:50:47.661 Socket (8) | Shutdown started. Waiting for graceful close. | 2021-06-07 08:50:47.661 Historical data download thread signaled to stop. | 2021-06-07 08:50:47.667 HD Request # 33 | Received 2 records from 2021-03-19 13:00:00.007000 to 2021-03-19 13:00:00.009000 (0.0 seconds) and wrote 0 records for F.US.DDH21 | 2021-06-07 08:50:47.667 HD Request # 33 | Add time&sales data | Remembered last file record date-time: 2021-03-19 12:00:00.009000 | 2021-06-07 08:50:47.668 HD Request # 33 | Completion time: 0s | 2021-06-07 08:50:47.668 HD Request # 33 | Intraday data download complete for F.US.DDH21. Unique request ID: 33 | 2021-06-07 08:50:47.668 Removing historical data download ID 33. | 2021-06-07 08:50:47.668 Real-time Intraday chart data file updates started for F.US.DDH21 | 2021-06-07 08:50:47.668 Intraday chart data file opened for F.US.DDH21 | 2021-06-07 08:50:47.668 HD Request # 33 | Enabling Intraday chart updating for symbol. | 2021-06-07 08:50:47.668 Triggering next historical data download in queue. | 2021-06-07 08:50:47.668 No download requests in the queue to start downloads for. | 2021-06-07 08:50:47.668 Socket (6) | Socket gracefully closed by remote side. | 2021-06-07 08:50:47.671 Socket (6) | Closed. | 2021-06-07 08:50:47.671 Socket (8) | Socket gracefully closed by remote side. | 2021-06-07 08:50:47.685 Socket (8) | Closed. | 2021-06-07 08:50:47.685 Opened cached Intraday file: D:\Sierrachart\Data\F.US.DBM21.scid. Thread ID: 10568 | 2021-06-07 08:50:52.539 Opened cached Intraday file: D:\Sierrachart\Data\F.US.JY6M21.scid. Thread ID: 10568 | 2021-06-07 08:50:52.539 Opened cached Intraday file: D:\Sierrachart\Data\US30.scid. Thread ID: 10568 | 2021-06-07 08:50:52.539 Opened cached Intraday file: D:\Sierrachart\Data\USOil.scid. Thread ID: 10568 | 2021-06-07 08:50:52.539 Opened cached Intraday file: D:\Sierrachart\Data\F.US.EU6M21.scid. Thread ID: 10568 | 2021-06-07 08:50:57.593 Opened cached Intraday file: D:\Sierrachart\Data\F.US.ENQM21.scid. Thread ID: 10568 | 2021-06-07 08:50:57.593 Opened cached Intraday file: D:\Sierrachart\Data\F.US.DDM21.scid. Thread ID: 10568 | 2021-06-07 08:51:02.632 Opened cached Intraday file: D:\Sierrachart\Data\F.US.DSXM21.scid. Thread ID: 10568 | 2021-06-07 08:51:22.806 |
[2021-06-07 06:57:41] |
... CME_Data is still missing after reconnection |
[2021-06-07 07:02:59] |
.. I am now receiving data, but the candles (chart) are not displayed
[2021-06-07 07:10:21] |
... if i use copy of chart then it be okay so then i copying all CME charts
[2021-06-07 07:55:31] |
Sierra_Chart Engineering - Posts: 14238 |
If there is missing data in the chart, follow the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart If a chart is not updating or completely blank, then refer to: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
