Date/Time: Fri, 03 May 2024 21:12:01 +0000
Realtime DATA
View Count: 395
[2021-06-03 19:06:49] |
tunwirwas - Posts: 1 |
Hello, as I can see, the market datas do not really run " in realtime ", but are late.. What settings do I have to make to really get this data in 1: 1 real time ? I thought, that account "Active Service: 10 - Standard + Denali Data Feed" is real time ... FDAXM21 FGBLM21 ESM21 6EM21 6BM21 CLN21 GCM21 HEM21 best regards Martin H. |
[2021-06-03 22:31:09] |
FDAXM21
These are EUREX symbols and require that you activate the EUREX exchange.FGBLM21 The other symbols are part of the CME group, and you do have the right exchange fee activated, however: The reason you are not getting real-time data from the CME Group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees. Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees If you do not have a funded trading account or one with a supported trading service, then refer to this solution: Easy Solution to CME Funded Trading Account Requirement We recommend using the above solution in any case to avoid this problem in the future. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
