Date/Time: Mon, 06 May 2024 04:49:23 +0000
Chart Settings
View Count: 423
[2021-05-31 16:45:30] |
User508912 - Posts: 22 |
I need to figure out how to apply saved tpo charts settings to analyze a new stock chart.
[2021-05-31 17:06:07] |
John - SC Support - Posts: 31379 |
There are a few options. 1. Saved study defaults. Refer to the following: Chart Studies: Using Custom Default Study Settings 2. Study Collections. This would probably work best for what you are doing. Refer to the following: Study Collections 3. Copy chart with TPO and change symbol. Refer to the following: Chart Menu: Duplicate Chart (Chart menu) And the following: Changing the Symbol of a Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
