Date/Time: Thu, 02 May 2024 11:38:05 +0000
Denali
View Count: 427
[2021-05-28 16:06:32] |
User460561 - Posts: 5 |
Hi guys. Somehow I got lost on this topic of CQG vs. Denali Feed. So, I'm currently on CQG as you know. Do I need to switch over to Denali or can I stick to live real-time streaming with CQG? What's the issue with CQG ( I understand there is some issue from what I'm hearing )? I don't care either way, just want to know what's up and what I need to do... Thank you. |
[2021-05-28 16:30:17] |
Sierra_Chart Engineering - Posts: 14173 |
For what exchanges do you need market data for?
[2021-05-28 17:37:57] |
CME primarily
[2021-05-31 07:41:54] |
We definitely do recommend using the Denali Exchange Data Feed especially with its superior historical data as compared to CQG. You can try it, next month at no cost. There is no cost for the exchange fee and then you can use the evaluate package feature to the change to the package which includes it (in your case service package 11), for 30 days: https://www.sierrachart.com/UserControlPanel.php?page=EvaluatePackage Here are the instructions to use the Denali Exchange Data Feed: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* Wait until June 1 before proceeding. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-05-31 07:42:25
[2021-06-01 11:59:56] |
Will I be able to continue live trading when I select package 11 and then switch to the feed?
[2021-06-01 14:09:10] |
Yes. But you do not need to change the service from CQG. Refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
