Date/Time: Mon, 06 May 2024 22:47:37 +0000
Micro BTC for Transact
View Count: 558
[2021-05-12 07:49:22] |
User361939 - Posts: 158 |
Hello, Now MicroBitcoin is available for Transact but prize/quatation is very differt. How we can get corret prize? Comparision chart from Tradingview (screen4) and how it look like now in Transact (screen5) Best Regards Date Time Of Last Edit: 2021-05-12 07:57:06
Screenshot_4.png / V - Attached On 2021-05-12 07:48:38 UTC - Size: 109.7 KB - 165 views Screenshot_5.png / V - Attached On 2021-05-12 07:48:45 UTC - Size: 63.86 KB - 159 views |
[2021-05-12 15:01:00] |
John - SC Support - Posts: 31412 |
Do you have the Real-Time Price Multiplier or Historical Price Multiplier set to something other than 1? Refer to the following: Chart Settings: Real-Time Price Multiplier (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) If those values are 1, then you need to delete the data and redownload, as something is simply not right. Refer to the following: Edit Menu: Edit >> Delete All Data And Download If that does not fix it, then you would need to ask TransAct about the data. Or switch to using the Denali Exchange Data Feed. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-15 09:51:56] |
Issue was with Data. It almost ok now. |
