Date/Time: Wed, 17 Jun 2026 13:26:07 +0000
My dom re-centering keyboard shortcuts isn't working.
View Count: 3589
| [2013-03-22 02:03:15] |
| tr726 - Posts: 30 |
| [2013-03-22 03:48:19] |
Does the command for this on the Trade menu work? If so, try resetting the keyboard shortcut you have set through Global Settings >> Customize Keyboard Shortcuts and restarting Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2013-03-22 19:54:01] |
| tr726 - Posts: 30 |
what is the trade menu? other keyboard shortcuts are working.
| [2013-03-22 19:59:29] |
The Trade menu is what you see on the main Sierra Chart window or on a detached chart or Trade DOM.
| [2013-03-22 20:09:40] |
| tr726 - Posts: 30 |
yes that re-center is working
| [2013-03-22 20:11:47] |
The only other advice is this: Reset the keyboard shortcut you have set through Global Settings >> Customize Keyboard Shortcuts and restart Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2013-04-24 13:58:45] |
| tr726 - Posts: 30 |
Im still having problems with re-centering my dom via keyboard shortcuts. I've reloaded and restarted several times. The re-centering works 20% of the time...
| [2013-04-24 18:38:27] |
We see why this occurs and it will be resolved in the next release. However, really it sounds like what you want to use is just double-clicking on the price scale to re-center it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-24 18:39:24
| [2013-04-25 12:54:02] |
| tr726 - Posts: 30 |
double click works fine on that selected dom only. what I'm looking for is all of the doms to re-center when i depress my short cut key. like i said before it works @ 20% of the time.
| [2013-05-15 15:40:28] |
| tr726 - Posts: 30 |
This STILL doesn't work correctly! When I click on my keyboard short cut my tradeDOMs do not recenter. When will this be resolved??
| [2013-05-15 15:45:46] |
This most definitely has been resolved. There must be some other issue. Maybe the keyboard shortcut is not functioning. Or you need to reset the scale by right clicking on the scale of numbers and selecting Reset. This is because you have changed it with Interactive Scale Move or Interactive Scale Range. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2013-05-15 16:24:16] |
| tr726 - Posts: 30 |
It's good that I'm aware of the process now, that I'm informed. I will see if this works. thx...
Date Time Of Last Edit: 2013-05-15 16:33:52
