Date/Time: Mon, 29 Apr 2024 01:31:29 +0000
Data lagging
View Count: 370
[2021-05-05 08:11:25] |
User334949 - Posts: 3 |
Hello i have 2 data providers. Have you noticed lagging on denali data feed yesterday? I dont know if its from my side but most of the time i was 5, 10 seconds behind compere to rithmic.
[2021-05-05 08:38:10] |
Sierra_Chart Engineering - Posts: 14126 |
That is a lot. You should not experience that degree of a lag. Refer to: Prices / Data Falling Behind: 4.12 - Sierra Chart Exchange Data Feeds We recommend using high compression. Another thing to do is to reconnect to the data feed to switch to a different server and see if that helps. We do have a server in London. Instructions: File Menu: Procedure to Reconnect to the Data and Trade Servers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
