Date/Time: Sun, 05 May 2024 05:10:24 +0000
Scrambled when changing tick sizes
View Count: 450
[2021-05-05 05:21:29] |
User393615 - Posts: 3 |
Hi team I trade on Binance and I just started researching DOM and I can see the value of using your software. When I go to increase the tick size however it pops up scrambled (image below) and then it reverts back to the 0.01 tick. 0.1 tick will be impossible to trade off. Can you please advise me what to do? I will definitely be paying for this if I can get it working properly. Matt |
example1.png / V - Attached On 2021-05-05 05:21:00 UTC - Size: 97.18 KB - 164 views Attachment Deleted. |
[2021-05-05 08:34:44] |
Sierra_Chart Engineering - Posts: 14224 |
Uncheck Auto Set from Data Feed: Chart Settings: Auto Set from Data Feed (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) And then adjust to scaling as required to reduce the range to eliminate the overlap: The Chart DOM Scale Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-07 05:11:58] |
thanks for your response. I've tried follow the steps as per the link you provided me here The Chart DOM Scale When I Autoscale it doesn't work. However interactive scale range unscrambles it as per the image attached. How can I just get one total value for that tick size now? Sorry I'm very untechy I'd love to get this working though.. |
[2021-05-07 05:58:44] |
Refer to this Chart Setting: Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-07 06:10:12] |
thanks so much that worked. How about the other columns though? (Pulling and stacking for example)
[2021-05-07 06:55:51] |
Those columns do not yet support that setting.
