Date/Time: Mon, 06 May 2024 10:29:53 +0000
not log in
View Count: 480
[2021-05-04 16:30:32] |
Nivp - Posts: 1 |
Reading Internal Order ID file. | 2021-05-04 02:47:34.556 Reading Trade Orders file. | 2021-05-04 02:47:34.750 Reading Trade Positions file. | 2021-05-04 02:47:34.759 Reading Trade Account Data files. | 2021-05-04 02:47:34.761 UDPListener (1492). Port 22903 | Listening on UDP port 22903. | 2021-05-04 02:47:34.837 Software version: 2225 64-bit | 2021-05-04 02:47:34.841 Primary Thread ID: 3476 | 2021-05-04 02:47:34.841 Usage end date: 2021-06-04 | 2021-05-04 02:47:34.841 Enabled for: Sierra Chart Historical Data Service. | 2021-05-04 02:47:34.841 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2021-05-04 02:47:34.841 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-05-04 02:47:34.841 Current selected Data/Trading service: TransAct WS | 2021-05-04 02:47:34.841 Custom symbol settings values: disabled | 2021-05-04 02:47:34.841 Chart Update Interval: 40 | 2021-05-04 02:47:34.841 Intraday Data Storage Time Unit: 0 | 2021-05-04 02:47:34.841 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-05-04 02:47:34.841 2021-05-04 06:47:34 Local computer time in UTC | 2021-05-04 02:47:34.841 2021-05-04 02:47:34 Local computer time in SC Time Zone | 2021-05-04 02:47:34.841 2021-05-04 06:47:33 Server time in UTC | 2021-05-04 02:47:34.841 Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-05-04 02:47:34.841 Program path: C:\SierraChart\SierraChartTransActMA\ | 2021-05-04 02:47:34.841 Data Files path: C:\SierraChart\SierraChartTransActMA\Data\ | 2021-05-04 02:47:34.841 OS Version Number: 10.0 | 2021-05-04 02:47:34.846 Locale Setting: C | 2021-05-04 02:47:34.846 DLLs: UserContributedStudies_64.dll | 2021-05-04 02:47:34.846 Allowed protected custom studies: | 2021-05-04 02:47:34.846 Created the DTC Protocol server. | 2021-05-04 02:47:34.848 DTC Protocol Server listening on port 11099. | 2021-05-04 02:47:34.850 Created the DTC Protocol historical data server. | 2021-05-04 02:47:34.850 HD Server Manager | Listening on port 11098 | 2021-05-04 02:47:34.851 Checking for new symbol settings. Requested symbol settings MD5 for service code transact.trading. Request ID: 1. | 2021-05-04 02:47:34.852 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:47:34.916 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2021-05-04 02:47:34.999 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2021-05-04 02:47:34.999 Received 5 login tokens. | 2021-05-04 02:47:35.226 Symbol settings MD5 received. Request ID: 1. | 2021-05-04 02:47:35.376 Symbol settings are up-to-date for transact.trading. | 2021-05-04 02:47:35.376 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:47:41.440 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:47:41.440 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2021-05-04 02:47:41.441 Auth Websocket socket (1) | New receive buffer size: 5242880 | 2021-05-04 02:47:41.441 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:47:41.441 Auth Websocket | Opening WebSocket. | 2021-05-04 02:47:41.613 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:47:41.613 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:47:42.116 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:47:42.116 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:47:42.116 Auth Websocket | Server header | Sec-WebSocket-Accept: kJQTBJ14yYFnmwTqqyjqJz6rcmw= | 2021-05-04 02:47:42.117 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:47:42.117 Auth Websocket | Server header | | 2021-05-04 02:47:42.117 Auth Websocket | Web socket state is now open. | 2021-05-04 02:47:42.117 TransAct WS | Sending account logon message. | 2021-05-04 02:47:42.117 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:47:42.346 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:47:42.346 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:47:42.346 TransAct WS | Session key cleared | 2021-05-04 02:47:42.529 Auth Websocket socket (1) | CloseSocket call. | 2021-05-04 02:47:42.529 Auth Websocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:47:42.529 Auth Websocket | WebSocket closed. | 2021-05-04 02:47:42.529 TransAct WS | Disconnected. | 2021-05-04 02:47:42.529 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:47:42.529 Auth Websocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:47:42.540 Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2021-05-04 02:47:42.552 Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:47:42.552 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:47:43.529 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:47:43.529 Auth Websocket socket (2) | Creating socket. Using TLS 1.2. | 2021-05-04 02:47:43.529 Auth Websocket socket (2) | New receive buffer size: 5242880 | 2021-05-04 02:47:43.529 Auth Websocket socket (2) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:47:43.529 Auth Websocket | Opening WebSocket. | 2021-05-04 02:47:43.694 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:47:43.694 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:47:44.202 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:47:44.202 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:47:44.202 Auth Websocket | Server header | Sec-WebSocket-Accept: f30dzb6xAO231DgbNUEqUQBrpxs= | 2021-05-04 02:47:44.202 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:47:44.202 Auth Websocket | Server header | | 2021-05-04 02:47:44.202 Auth Websocket | Web socket state is now open. | 2021-05-04 02:47:44.202 TransAct WS | Sending account logon message. | 2021-05-04 02:47:44.202 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:47:44.420 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:47:44.420 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:47:44.420 TransAct WS | Session key cleared | 2021-05-04 02:47:44.435 Auth Websocket socket (2) | CloseSocket call. | 2021-05-04 02:47:44.435 Auth Websocket socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:47:44.435 Auth Websocket | WebSocket closed. | 2021-05-04 02:47:44.435 TransAct WS | Disconnected. | 2021-05-04 02:47:44.435 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:47:44.435 Auth Websocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:47:44.435 Auth Websocket socket (2) | Write has completed. Shutdown being performed. | 2021-05-04 02:47:44.435 Auth Websocket socket (2) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:47:44.435 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:47:45.435 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:47:45.435 Auth Websocket socket (3) | Creating socket. Using TLS 1.2. | 2021-05-04 02:47:45.436 Auth Websocket socket (3) | New receive buffer size: 5242880 | 2021-05-04 02:47:45.436 Auth Websocket socket (3) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:47:45.436 Auth Websocket | Opening WebSocket. | 2021-05-04 02:47:45.602 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:47:45.602 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:47:46.102 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:47:46.102 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:47:46.102 Auth Websocket | Server header | Sec-WebSocket-Accept: iV/HKSQZHkg9ibwj+gRNL6gYbQ8= | 2021-05-04 02:47:46.102 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:47:46.102 Auth Websocket | Server header | | 2021-05-04 02:47:46.102 Auth Websocket | Web socket state is now open. | 2021-05-04 02:47:46.102 TransAct WS | Sending account logon message. | 2021-05-04 02:47:46.102 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:47:46.316 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:47:46.316 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:47:46.316 TransAct WS | Session key cleared | 2021-05-04 02:47:46.342 Auth Websocket socket (3) | CloseSocket call. | 2021-05-04 02:47:46.342 Auth Websocket socket (3) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:47:46.342 Auth Websocket | WebSocket closed. | 2021-05-04 02:47:46.342 TransAct WS | Disconnected. | 2021-05-04 02:47:46.342 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:47:46.342 Auth Websocket socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:47:46.342 Auth Websocket socket (3) | Write has completed. Shutdown being performed. | 2021-05-04 02:47:46.343 Auth Websocket socket (3) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:47:46.343 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:47:47.342 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:47:47.342 Auth Websocket socket (4) | Creating socket. Using TLS 1.2. | 2021-05-04 02:47:47.342 Auth Websocket socket (4) | New receive buffer size: 5242880 | 2021-05-04 02:47:47.343 Auth Websocket socket (4) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:47:47.343 Auth Websocket | Opening WebSocket. | 2021-05-04 02:47:47.507 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:47:47.507 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:47:48.010 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:47:48.010 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:47:48.010 Auth Websocket | Server header | Sec-WebSocket-Accept: 9miN08nV3ZsA2jW4COqKpVkq1ok= | 2021-05-04 02:47:48.010 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:47:48.010 Auth Websocket | Server header | | 2021-05-04 02:47:48.010 Auth Websocket | Web socket state is now open. | 2021-05-04 02:47:48.010 TransAct WS | Sending account logon message. | 2021-05-04 02:47:48.010 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:47:48.226 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:47:48.226 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:47:48.226 TransAct WS | Session key cleared | 2021-05-04 02:47:48.232 Auth Websocket socket (4) | CloseSocket call. | 2021-05-04 02:47:48.232 Auth Websocket socket (4) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:47:48.232 Auth Websocket | WebSocket closed. | 2021-05-04 02:47:48.232 TransAct WS | Disconnected. | 2021-05-04 02:47:48.232 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:47:48.232 Auth Websocket socket (4) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:47:48.232 Auth Websocket socket (4) | Write has completed. Shutdown being performed. | 2021-05-04 02:47:48.232 Auth Websocket socket (4) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:47:48.232 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:47:49.232 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:47:49.232 Auth Websocket socket (5) | Creating socket. Using TLS 1.2. | 2021-05-04 02:47:49.233 Auth Websocket socket (5) | New receive buffer size: 5242880 | 2021-05-04 02:47:49.234 Auth Websocket socket (5) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:47:49.234 Auth Websocket | Opening WebSocket. | 2021-05-04 02:47:49.409 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:47:49.409 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:47:49.939 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:47:49.939 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:47:49.939 Auth Websocket | Server header | Sec-WebSocket-Accept: BC43I1PHGWc9SZ3s2n+XS/3kv6o= | 2021-05-04 02:47:49.939 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:47:49.939 Auth Websocket | Server header | | 2021-05-04 02:47:49.939 Auth Websocket | Web socket state is now open. | 2021-05-04 02:47:49.939 TransAct WS | Sending account logon message. | 2021-05-04 02:47:49.939 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:47:50.171 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:47:50.171 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:47:50.171 TransAct WS | Session key cleared | 2021-05-04 02:47:50.184 Auth Websocket socket (5) | CloseSocket call. | 2021-05-04 02:47:50.184 Auth Websocket socket (5) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:47:50.184 Auth Websocket | WebSocket closed. | 2021-05-04 02:47:50.184 TransAct WS | Disconnected. | 2021-05-04 02:47:50.184 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:47:50.184 Auth Websocket socket (5) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:47:50.185 Auth Websocket socket (5) | Write has completed. Shutdown being performed. | 2021-05-04 02:47:50.185 Auth Websocket socket (5) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:47:50.185 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:47:51.185 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:47:51.185 Auth Websocket socket (6) | Creating socket. Using TLS 1.2. | 2021-05-04 02:47:51.186 Auth Websocket socket (6) | New receive buffer size: 5242880 | 2021-05-04 02:47:51.186 Auth Websocket socket (6) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:47:51.186 Auth Websocket | Opening WebSocket. | 2021-05-04 02:47:51.362 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:47:51.362 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:47:51.888 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:47:51.888 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:47:51.888 Auth Websocket | Server header | Sec-WebSocket-Accept: vhrQFXFqJoecDRuef+bHV8YWFzw= | 2021-05-04 02:47:51.888 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:47:51.888 Auth Websocket | Server header | | 2021-05-04 02:47:51.888 Auth Websocket | Web socket state is now open. | 2021-05-04 02:47:51.888 TransAct WS | Sending account logon message. | 2021-05-04 02:47:51.888 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:47:52.172 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:47:52.172 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:47:52.172 TransAct WS | Session key cleared | 2021-05-04 02:47:52.185 Auth Websocket socket (6) | CloseSocket call. | 2021-05-04 02:47:52.185 Auth Websocket socket (6) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:47:52.185 Auth Websocket | WebSocket closed. | 2021-05-04 02:47:52.185 TransAct WS | Disconnected. | 2021-05-04 02:47:52.185 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:47:52.186 Auth Websocket socket (6) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:47:52.186 Auth Websocket socket (6) | Write has completed. Shutdown being performed. | 2021-05-04 02:47:52.186 Auth Websocket socket (6) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:47:52.186 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:47:53.201 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:47:53.201 Auth Websocket socket (7) | Creating socket. Using TLS 1.2. | 2021-05-04 02:47:53.201 Auth Websocket socket (7) | New receive buffer size: 5242880 | 2021-05-04 02:47:53.202 Auth Websocket socket (7) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:47:53.202 Auth Websocket | Opening WebSocket. | 2021-05-04 02:47:53.371 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:47:53.371 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:47:53.884 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:47:53.884 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:47:53.884 Auth Websocket | Server header | Sec-WebSocket-Accept: vF3LozEtDYg3vESy8MQ2YyJMleU= | 2021-05-04 02:47:53.884 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:47:53.884 Auth Websocket | Server header | | 2021-05-04 02:47:53.884 Auth Websocket | Web socket state is now open. | 2021-05-04 02:47:53.884 TransAct WS | Sending account logon message. | 2021-05-04 02:47:53.884 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:47:54.105 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:47:54.105 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:47:54.105 TransAct WS | Session key cleared | 2021-05-04 02:47:54.123 Auth Websocket socket (7) | CloseSocket call. | 2021-05-04 02:47:54.123 Auth Websocket socket (7) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:47:54.123 Auth Websocket | WebSocket closed. | 2021-05-04 02:47:54.123 TransAct WS | Disconnected. | 2021-05-04 02:47:54.123 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:47:54.123 Auth Websocket socket (7) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:47:54.124 Auth Websocket socket (7) | Write has completed. Shutdown being performed. | 2021-05-04 02:47:54.124 Auth Websocket socket (7) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:47:54.125 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:47:55.123 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:47:55.123 Auth Websocket socket (8) | Creating socket. Using TLS 1.2. | 2021-05-04 02:47:55.123 Auth Websocket socket (8) | New receive buffer size: 5242880 | 2021-05-04 02:47:55.124 Auth Websocket socket (8) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:47:55.124 Auth Websocket | Opening WebSocket. | 2021-05-04 02:47:55.289 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:47:55.289 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:47:55.788 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:47:55.788 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:47:55.788 Auth Websocket | Server header | Sec-WebSocket-Accept: GpwxY+yeL3p/QPQVuDmSgYr4nKk= | 2021-05-04 02:47:55.788 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:47:55.789 Auth Websocket | Server header | | 2021-05-04 02:47:55.789 Auth Websocket | Web socket state is now open. | 2021-05-04 02:47:55.789 TransAct WS | Sending account logon message. | 2021-05-04 02:47:55.789 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:47:56.125 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:47:56.125 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:47:56.125 TransAct WS | Session key cleared | 2021-05-04 02:47:56.178 Auth Websocket socket (8) | CloseSocket call. | 2021-05-04 02:47:56.178 Auth Websocket socket (8) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:47:56.178 Auth Websocket | WebSocket closed. | 2021-05-04 02:47:56.178 TransAct WS | Disconnected. | 2021-05-04 02:47:56.178 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:47:56.178 Auth Websocket socket (8) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:47:56.179 Auth Websocket socket (8) | Write has completed. Shutdown being performed. | 2021-05-04 02:47:56.179 Auth Websocket socket (8) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:47:56.179 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:47:57.170 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:47:57.170 Auth Websocket socket (9) | Creating socket. Using TLS 1.2. | 2021-05-04 02:47:57.170 Auth Websocket socket (9) | New receive buffer size: 5242880 | 2021-05-04 02:47:57.170 Auth Websocket socket (9) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:47:57.170 Auth Websocket | Opening WebSocket. | 2021-05-04 02:47:57.341 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:47:57.341 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:47:57.830 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:47:57.830 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:47:57.830 Auth Websocket | Server header | Sec-WebSocket-Accept: /F2uUsJnV+I0itJyabzKkHezA1I= | 2021-05-04 02:47:57.830 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:47:57.830 Auth Websocket | Server header | | 2021-05-04 02:47:57.830 Auth Websocket | Web socket state is now open. | 2021-05-04 02:47:57.830 TransAct WS | Sending account logon message. | 2021-05-04 02:47:57.830 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:47:58.042 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:47:58.042 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:47:58.042 TransAct WS | Session key cleared | 2021-05-04 02:47:58.060 Auth Websocket socket (9) | CloseSocket call. | 2021-05-04 02:47:58.060 Auth Websocket socket (9) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:47:58.060 Auth Websocket | WebSocket closed. | 2021-05-04 02:47:58.060 TransAct WS | Disconnected. | 2021-05-04 02:47:58.060 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:47:58.060 Auth Websocket socket (9) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:47:58.061 Auth Websocket socket (9) | Write has completed. Shutdown being performed. | 2021-05-04 02:47:58.061 Auth Websocket socket (9) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:47:58.061 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:47:59.060 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:47:59.060 Auth Websocket socket (10) | Creating socket. Using TLS 1.2. | 2021-05-04 02:47:59.061 Auth Websocket socket (10) | New receive buffer size: 5242880 | 2021-05-04 02:47:59.062 Auth Websocket socket (10) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:47:59.062 Auth Websocket | Opening WebSocket. | 2021-05-04 02:47:59.226 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:47:59.226 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:47:59.722 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:47:59.722 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:47:59.722 Auth Websocket | Server header | Sec-WebSocket-Accept: 6MUO3FfFvutS825sKpZNdaEZXzc= | 2021-05-04 02:47:59.722 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:47:59.722 Auth Websocket | Server header | | 2021-05-04 02:47:59.722 Auth Websocket | Web socket state is now open. | 2021-05-04 02:47:59.722 TransAct WS | Sending account logon message. | 2021-05-04 02:47:59.722 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:47:59.938 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:47:59.938 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:47:59.938 TransAct WS | Session key cleared | 2021-05-04 02:47:59.951 Auth Websocket socket (10) | CloseSocket call. | 2021-05-04 02:47:59.951 Auth Websocket socket (10) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:47:59.951 Auth Websocket | WebSocket closed. | 2021-05-04 02:47:59.951 TransAct WS | Disconnected. | 2021-05-04 02:47:59.951 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:47:59.951 Auth Websocket socket (10) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:47:59.951 Auth Websocket socket (10) | Write has completed. Shutdown being performed. | 2021-05-04 02:47:59.951 Auth Websocket socket (10) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:47:59.951 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:00.952 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:00.956 Auth Websocket socket (11) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:00.956 Auth Websocket socket (11) | New receive buffer size: 5242880 | 2021-05-04 02:48:00.956 Auth Websocket socket (11) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:00.957 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:01.126 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:01.126 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:01.638 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:01.638 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:01.638 Auth Websocket | Server header | Sec-WebSocket-Accept: dzkEVMCRx6SIWPfrc4oMQoozG/I= | 2021-05-04 02:48:01.638 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:01.638 Auth Websocket | Server header | | 2021-05-04 02:48:01.638 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:01.638 TransAct WS | Sending account logon message. | 2021-05-04 02:48:01.638 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:01.854 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:01.854 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:01.854 TransAct WS | Session key cleared | 2021-05-04 02:48:01.856 Auth Websocket socket (11) | CloseSocket call. | 2021-05-04 02:48:01.856 Auth Websocket socket (11) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:01.856 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:01.856 TransAct WS | Disconnected. | 2021-05-04 02:48:01.856 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:01.856 Auth Websocket socket (11) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:01.856 Auth Websocket socket (11) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:01.857 Auth Websocket socket (11) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:01.857 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:02.857 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:02.857 Auth Websocket socket (12) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:02.858 Auth Websocket socket (12) | New receive buffer size: 5242880 | 2021-05-04 02:48:02.858 Auth Websocket socket (12) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:02.858 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:03.043 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:03.043 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:03.679 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:03.679 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:03.679 Auth Websocket | Server header | Sec-WebSocket-Accept: 5QOy0jKakbEydBldLEARb4xnGc4= | 2021-05-04 02:48:03.679 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:03.679 Auth Websocket | Server header | | 2021-05-04 02:48:03.679 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:03.679 TransAct WS | Sending account logon message. | 2021-05-04 02:48:03.679 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:03.913 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:03.913 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:03.913 TransAct WS | Session key cleared | 2021-05-04 02:48:03.921 Auth Websocket socket (12) | CloseSocket call. | 2021-05-04 02:48:03.921 Auth Websocket socket (12) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:03.921 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:03.921 TransAct WS | Disconnected. | 2021-05-04 02:48:03.922 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:03.922 Auth Websocket socket (12) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:03.929 Auth Websocket socket (12) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:03.931 Auth Websocket socket (12) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:03.931 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:04.920 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:04.920 Auth Websocket socket (13) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:04.920 Auth Websocket socket (13) | New receive buffer size: 5242880 | 2021-05-04 02:48:04.920 Auth Websocket socket (13) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:04.920 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:05.090 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:05.090 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:05.601 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:05.601 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:05.602 Auth Websocket | Server header | Sec-WebSocket-Accept: aYkj7973sYXUkoya5GpNxILj49Q= | 2021-05-04 02:48:05.602 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:05.602 Auth Websocket | Server header | | 2021-05-04 02:48:05.602 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:05.602 TransAct WS | Sending account logon message. | 2021-05-04 02:48:05.602 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:05.822 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:05.822 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:05.822 TransAct WS | Session key cleared | 2021-05-04 02:48:05.842 Auth Websocket socket (13) | CloseSocket call. | 2021-05-04 02:48:05.842 Auth Websocket socket (13) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:05.842 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:05.842 TransAct WS | Disconnected. | 2021-05-04 02:48:05.842 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:05.842 Auth Websocket socket (13) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:05.842 Auth Websocket socket (13) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:05.842 Auth Websocket socket (13) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:05.843 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:06.842 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:06.842 Auth Websocket socket (14) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:06.842 Auth Websocket socket (14) | New receive buffer size: 5242880 | 2021-05-04 02:48:06.842 Auth Websocket socket (14) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:06.842 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:07.004 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:07.004 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:07.505 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:07.505 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:07.505 Auth Websocket | Server header | Sec-WebSocket-Accept: uK09z1ef5yR+HMVXkCvAnZmmWvc= | 2021-05-04 02:48:07.505 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:07.505 Auth Websocket | Server header | | 2021-05-04 02:48:07.505 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:07.505 TransAct WS | Sending account logon message. | 2021-05-04 02:48:07.505 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:07.715 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:07.715 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:07.715 TransAct WS | Session key cleared | 2021-05-04 02:48:07.716 Auth Websocket socket (14) | CloseSocket call. | 2021-05-04 02:48:07.716 Auth Websocket socket (14) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:07.716 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:07.716 TransAct WS | Disconnected. | 2021-05-04 02:48:07.716 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:07.716 Auth Websocket socket (14) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:07.716 Auth Websocket socket (14) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:07.717 Auth Websocket socket (14) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:07.717 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:08.717 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:08.717 Auth Websocket socket (15) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:08.717 Auth Websocket socket (15) | New receive buffer size: 5242880 | 2021-05-04 02:48:08.717 Auth Websocket socket (15) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:08.717 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:08.880 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:08.880 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:09.388 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:09.388 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:09.388 Auth Websocket | Server header | Sec-WebSocket-Accept: GlzSsHlFOcT30MloxRZ3Y52SkZA= | 2021-05-04 02:48:09.388 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:09.388 Auth Websocket | Server header | | 2021-05-04 02:48:09.388 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:09.388 TransAct WS | Sending account logon message. | 2021-05-04 02:48:09.388 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:09.598 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:09.598 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:09.598 TransAct WS | Session key cleared | 2021-05-04 02:48:09.607 Auth Websocket socket (15) | CloseSocket call. | 2021-05-04 02:48:09.607 Auth Websocket socket (15) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:09.607 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:09.607 TransAct WS | Disconnected. | 2021-05-04 02:48:09.607 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:09.607 Auth Websocket socket (15) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:09.607 Auth Websocket socket (15) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:09.608 Auth Websocket socket (15) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:09.608 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:10.607 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:10.607 Auth Websocket socket (16) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:10.608 Auth Websocket socket (16) | New receive buffer size: 5242880 | 2021-05-04 02:48:10.608 Auth Websocket socket (16) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:10.608 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:10.768 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:10.768 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:11.261 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:11.261 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:11.261 Auth Websocket | Server header | Sec-WebSocket-Accept: +ppyIXvgjuM+1Vp0RQtEQzDLgu0= | 2021-05-04 02:48:11.261 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:11.261 Auth Websocket | Server header | | 2021-05-04 02:48:11.261 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:11.261 TransAct WS | Sending account logon message. | 2021-05-04 02:48:11.261 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:11.472 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:11.472 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:11.472 TransAct WS | Session key cleared | 2021-05-04 02:48:11.483 Auth Websocket socket (16) | CloseSocket call. | 2021-05-04 02:48:11.483 Auth Websocket socket (16) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:11.483 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:11.483 TransAct WS | Disconnected. | 2021-05-04 02:48:11.483 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:11.483 Auth Websocket socket (16) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:11.484 Auth Websocket socket (16) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:11.485 Auth Websocket socket (16) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:11.485 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:12.498 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:12.498 Auth Websocket socket (17) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:12.498 Auth Websocket socket (17) | New receive buffer size: 5242880 | 2021-05-04 02:48:12.499 Auth Websocket socket (17) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:12.499 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:12.660 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:12.660 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:13.155 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:13.155 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:13.155 Auth Websocket | Server header | Sec-WebSocket-Accept: 3Ym5Uejek8aE7pvaUeeqMOK6I8Y= | 2021-05-04 02:48:13.155 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:13.155 Auth Websocket | Server header | | 2021-05-04 02:48:13.155 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:13.155 TransAct WS | Sending account logon message. | 2021-05-04 02:48:13.155 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:13.372 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:13.372 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:13.372 TransAct WS | Session key cleared | 2021-05-04 02:48:13.389 Auth Websocket socket (17) | CloseSocket call. | 2021-05-04 02:48:13.389 Auth Websocket socket (17) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:13.389 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:13.389 TransAct WS | Disconnected. | 2021-05-04 02:48:13.389 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:13.389 Auth Websocket socket (17) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:13.391 Auth Websocket socket (17) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:13.391 Auth Websocket socket (17) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:13.392 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:14.403 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:14.403 Auth Websocket socket (18) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:14.404 Auth Websocket socket (18) | New receive buffer size: 5242880 | 2021-05-04 02:48:14.404 Auth Websocket socket (18) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:14.404 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:14.581 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:14.581 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:15.174 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:15.174 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:15.174 Auth Websocket | Server header | Sec-WebSocket-Accept: 60/mrpKJu9nl6L3e8kS0vPFwnkg= | 2021-05-04 02:48:15.174 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:15.174 Auth Websocket | Server header | | 2021-05-04 02:48:15.174 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:15.174 TransAct WS | Sending account logon message. | 2021-05-04 02:48:15.174 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:15.385 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:15.385 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:15.385 TransAct WS | Session key cleared | 2021-05-04 02:48:15.404 Auth Websocket socket (18) | CloseSocket call. | 2021-05-04 02:48:15.404 Auth Websocket socket (18) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:15.404 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:15.404 TransAct WS | Disconnected. | 2021-05-04 02:48:15.405 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:15.405 Auth Websocket socket (18) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:15.410 Auth Websocket socket (18) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:15.410 Auth Websocket socket (18) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:15.410 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:16.404 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:16.404 Auth Websocket socket (19) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:16.405 Auth Websocket socket (19) | New receive buffer size: 5242880 | 2021-05-04 02:48:16.405 Auth Websocket socket (19) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:16.405 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:16.644 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:16.644 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:17.324 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:17.324 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:17.324 Auth Websocket | Server header | Sec-WebSocket-Accept: BR34mzhEfqfB5BwqzRjg5Eg9Eh0= | 2021-05-04 02:48:17.324 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:17.324 Auth Websocket | Server header | | 2021-05-04 02:48:17.324 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:17.324 TransAct WS | Sending account logon message. | 2021-05-04 02:48:17.324 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:17.577 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:17.577 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:17.577 TransAct WS | Session key cleared | 2021-05-04 02:48:17.592 Auth Websocket socket (19) | CloseSocket call. | 2021-05-04 02:48:17.592 Auth Websocket socket (19) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:17.592 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:17.592 TransAct WS | Disconnected. | 2021-05-04 02:48:17.592 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:17.592 Auth Websocket socket (19) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:17.592 Auth Websocket socket (19) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:17.592 Auth Websocket socket (19) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:17.592 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:18.591 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:18.591 Auth Websocket socket (20) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:18.591 Auth Websocket socket (20) | New receive buffer size: 5242880 | 2021-05-04 02:48:18.592 Auth Websocket socket (20) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:18.592 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:18.767 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:18.767 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:19.299 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:19.299 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:19.299 Auth Websocket | Server header | Sec-WebSocket-Accept: u78Ue4m/nu4YMbgxqWlJZFpzR4s= | 2021-05-04 02:48:19.299 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:19.299 Auth Websocket | Server header | | 2021-05-04 02:48:19.299 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:19.299 TransAct WS | Sending account logon message. | 2021-05-04 02:48:19.299 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:19.622 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:19.622 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:19.622 TransAct WS | Session key cleared | 2021-05-04 02:48:19.638 Auth Websocket socket (20) | CloseSocket call. | 2021-05-04 02:48:19.638 Auth Websocket socket (20) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:19.638 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:19.638 TransAct WS | Disconnected. | 2021-05-04 02:48:19.638 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:19.638 Auth Websocket socket (20) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:19.639 Auth Websocket socket (20) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:19.639 Auth Websocket socket (20) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:19.639 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:20.638 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:20.638 Auth Websocket socket (21) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:20.639 Auth Websocket socket (21) | New receive buffer size: 5242880 | 2021-05-04 02:48:20.639 Auth Websocket socket (21) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:20.639 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:20.904 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:20.904 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:21.397 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:21.397 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:21.397 Auth Websocket | Server header | Sec-WebSocket-Accept: Xrl0ub5sHAAC/yYVQVIdwuZotxE= | 2021-05-04 02:48:21.397 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:21.397 Auth Websocket | Server header | | 2021-05-04 02:48:21.397 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:21.397 TransAct WS | Sending account logon message. | 2021-05-04 02:48:21.397 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:21.611 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:21.611 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:21.611 TransAct WS | Session key cleared | 2021-05-04 02:48:21.638 Auth Websocket socket (21) | CloseSocket call. | 2021-05-04 02:48:21.638 Auth Websocket socket (21) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:21.638 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:21.638 TransAct WS | Disconnected. | 2021-05-04 02:48:21.638 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:21.638 Auth Websocket socket (21) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:21.638 Auth Websocket socket (21) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:21.639 Auth Websocket socket (21) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:21.639 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:22.638 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:22.638 Auth Websocket socket (22) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:22.639 Auth Websocket socket (22) | New receive buffer size: 5242880 | 2021-05-04 02:48:22.639 Auth Websocket socket (22) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:22.639 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:22.803 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:22.803 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:23.297 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:23.297 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:23.297 Auth Websocket | Server header | Sec-WebSocket-Accept: w9kALdWxXRObvMv9wGp9vF+b2AA= | 2021-05-04 02:48:23.297 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:23.297 Auth Websocket | Server header | | 2021-05-04 02:48:23.297 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:23.297 TransAct WS | Sending account logon message. | 2021-05-04 02:48:23.297 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:23.511 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:23.511 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:23.511 TransAct WS | Session key cleared | 2021-05-04 02:48:23.529 Auth Websocket socket (22) | CloseSocket call. | 2021-05-04 02:48:23.529 Auth Websocket socket (22) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:23.529 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:23.529 TransAct WS | Disconnected. | 2021-05-04 02:48:23.529 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:23.529 Auth Websocket socket (22) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:23.530 Auth Websocket socket (22) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:23.530 Auth Websocket socket (22) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:23.530 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:24.528 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:24.528 Auth Websocket socket (23) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:24.529 Auth Websocket socket (23) | New receive buffer size: 5242880 | 2021-05-04 02:48:24.529 Auth Websocket socket (23) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:24.529 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:24.705 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:24.705 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:25.318 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:25.318 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:25.319 Auth Websocket | Server header | Sec-WebSocket-Accept: Vykokx7JvxsXLWjw+wqdRwHtIW0= | 2021-05-04 02:48:25.319 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:25.319 Auth Websocket | Server header | | 2021-05-04 02:48:25.319 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:25.319 TransAct WS | Sending account logon message. | 2021-05-04 02:48:25.319 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:25.553 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:25.553 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:25.553 TransAct WS | Session key cleared | 2021-05-04 02:48:25.560 Auth Websocket socket (23) | CloseSocket call. | 2021-05-04 02:48:25.560 Auth Websocket socket (23) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:25.560 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:25.560 TransAct WS | Disconnected. | 2021-05-04 02:48:25.560 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:25.560 Auth Websocket socket (23) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:25.562 Auth Websocket socket (23) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:25.563 Auth Websocket socket (23) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:25.564 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:26.561 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:26.561 Auth Websocket socket (24) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:26.561 Auth Websocket socket (24) | New receive buffer size: 5242880 | 2021-05-04 02:48:26.562 Auth Websocket socket (24) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:26.562 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:26.732 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:26.732 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:27.271 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:27.271 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:27.271 Auth Websocket | Server header | Sec-WebSocket-Accept: /PEvMxGXI6D6gdERTa0hSAknR8I= | 2021-05-04 02:48:27.271 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:27.271 Auth Websocket | Server header | | 2021-05-04 02:48:27.271 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:27.271 TransAct WS | Sending account logon message. | 2021-05-04 02:48:27.271 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:27.491 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:27.491 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:27.491 TransAct WS | Session key cleared | 2021-05-04 02:48:27.497 Auth Websocket socket (24) | CloseSocket call. | 2021-05-04 02:48:27.497 Auth Websocket socket (24) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:27.497 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:27.497 TransAct WS | Disconnected. | 2021-05-04 02:48:27.497 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:27.497 Auth Websocket socket (24) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:27.498 Auth Websocket socket (24) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:27.498 Auth Websocket socket (24) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:27.498 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:28.498 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:28.498 Auth Websocket socket (25) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:28.498 Auth Websocket socket (25) | New receive buffer size: 5242880 | 2021-05-04 02:48:28.498 Auth Websocket socket (25) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:28.498 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:28.667 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:28.667 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:29.165 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:29.165 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:29.165 Auth Websocket | Server header | Sec-WebSocket-Accept: 4MZ4ivEAzbYRLdQWZL5DqWTMLng= | 2021-05-04 02:48:29.165 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:29.165 Auth Websocket | Server header | | 2021-05-04 02:48:29.165 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:29.165 TransAct WS | Sending account logon message. | 2021-05-04 02:48:29.165 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:29.375 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:29.375 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:29.375 TransAct WS | Session key cleared | 2021-05-04 02:48:29.388 Auth Websocket socket (25) | CloseSocket call. | 2021-05-04 02:48:29.388 Auth Websocket socket (25) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:29.388 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:29.388 TransAct WS | Disconnected. | 2021-05-04 02:48:29.388 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:29.388 Auth Websocket socket (25) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:29.388 Auth Websocket socket (25) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:29.388 Auth Websocket socket (25) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:29.388 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:30.389 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:30.389 Auth Websocket socket (26) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:30.390 Auth Websocket socket (26) | New receive buffer size: 5242880 | 2021-05-04 02:48:30.390 Auth Websocket socket (26) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:30.390 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:30.551 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:30.551 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:31.044 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:31.044 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:31.044 Auth Websocket | Server header | Sec-WebSocket-Accept: zRFJrpsHbQSqsacRtGdGmq7wS+Y= | 2021-05-04 02:48:31.044 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:31.044 Auth Websocket | Server header | | 2021-05-04 02:48:31.044 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:31.044 TransAct WS | Sending account logon message. | 2021-05-04 02:48:31.044 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:31.254 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:31.254 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:31.254 TransAct WS | Session key cleared | 2021-05-04 02:48:31.264 Auth Websocket socket (26) | CloseSocket call. | 2021-05-04 02:48:31.264 Auth Websocket socket (26) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:31.264 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:31.264 TransAct WS | Disconnected. | 2021-05-04 02:48:31.264 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:31.264 Auth Websocket socket (26) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:31.264 Auth Websocket socket (26) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:31.266 Auth Websocket socket (26) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:31.267 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:32.279 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:32.279 Auth Websocket socket (27) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:32.279 Auth Websocket socket (27) | New receive buffer size: 5242880 | 2021-05-04 02:48:32.280 Auth Websocket socket (27) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:32.280 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:32.443 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:32.443 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:32.931 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:32.931 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:32.931 Auth Websocket | Server header | Sec-WebSocket-Accept: rm8O05BgA7VRjdRRFmC1GR6CwMY= | 2021-05-04 02:48:32.931 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:32.931 Auth Websocket | Server header | | 2021-05-04 02:48:32.931 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:32.931 TransAct WS | Sending account logon message. | 2021-05-04 02:48:32.931 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:33.145 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:33.145 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:33.145 TransAct WS | Session key cleared | 2021-05-04 02:48:33.154 Auth Websocket socket (27) | CloseSocket call. | 2021-05-04 02:48:33.154 Auth Websocket socket (27) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:33.154 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:33.154 TransAct WS | Disconnected. | 2021-05-04 02:48:33.154 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:33.154 Auth Websocket socket (27) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:33.155 Auth Websocket socket (27) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:33.155 Auth Websocket socket (27) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:33.155 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:34.170 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:34.170 Auth Websocket socket (29) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:34.170 Auth Websocket socket (29) | New receive buffer size: 5242880 | 2021-05-04 02:48:34.171 Auth Websocket socket (29) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:34.171 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:34.348 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:34.348 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:34.880 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:34.880 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:34.880 Auth Websocket | Server header | Sec-WebSocket-Accept: S01HuTg4XgACwjQys13ZW0qQbNg= | 2021-05-04 02:48:34.880 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:34.880 Auth Websocket | Server header | | 2021-05-04 02:48:34.880 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:34.880 TransAct WS | Sending account logon message. | 2021-05-04 02:48:34.880 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:35.105 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:35.105 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:35.105 TransAct WS | Session key cleared | 2021-05-04 02:48:35.142 Auth Websocket socket (29) | CloseSocket call. | 2021-05-04 02:48:35.143 Auth Websocket socket (29) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:35.143 Auth Websocket socket (29) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:35.143 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:35.143 TransAct WS | Disconnected. | 2021-05-04 02:48:35.143 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:35.143 Auth Websocket socket (29) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:35.143 Auth Websocket socket (29) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:35.143 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:36.138 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:36.138 Auth Websocket socket (28) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:36.138 Auth Websocket socket (28) | New receive buffer size: 5242880 | 2021-05-04 02:48:36.138 Auth Websocket socket (28) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:36.138 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:36.307 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:36.307 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:36.840 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:36.840 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:36.840 Auth Websocket | Server header | Sec-WebSocket-Accept: Y+7oGV7H4e9kKr8AyjsDZ0DfXZE= | 2021-05-04 02:48:36.840 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:36.840 Auth Websocket | Server header | | 2021-05-04 02:48:36.840 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:36.840 TransAct WS | Sending account logon message. | 2021-05-04 02:48:36.840 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:37.069 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:37.069 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:37.069 TransAct WS | Session key cleared | 2021-05-04 02:48:37.217 Auth Websocket socket (28) | CloseSocket call. | 2021-05-04 02:48:37.231 Auth Websocket socket (28) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:37.231 Auth Websocket socket (28) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:37.232 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:37.232 TransAct WS | Disconnected. | 2021-05-04 02:48:37.232 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:37.232 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:38.232 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:38.232 Auth Websocket socket (30) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:38.233 Auth Websocket socket (30) | New receive buffer size: 5242880 | 2021-05-04 02:48:38.233 Auth Websocket socket (30) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:38.233 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:38.403 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:38.403 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:38.919 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:38.919 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:38.920 Auth Websocket | Server header | Sec-WebSocket-Accept: tGMH+Zj3vb/M0SEslSsl180J2vE= | 2021-05-04 02:48:38.920 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:38.920 Auth Websocket | Server header | | 2021-05-04 02:48:38.920 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:38.920 TransAct WS | Sending account logon message. | 2021-05-04 02:48:38.920 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:39.171 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:39.171 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:39.171 TransAct WS | Session key cleared | 2021-05-04 02:48:39.184 Auth Websocket socket (30) | CloseSocket call. | 2021-05-04 02:48:39.184 Auth Websocket socket (30) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:39.185 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:39.185 TransAct WS | Disconnected. | 2021-05-04 02:48:39.185 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:39.185 Auth Websocket socket (30) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:39.185 Auth Websocket socket (30) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:39.185 Auth Websocket socket (30) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:39.185 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:40.186 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:40.186 Auth Websocket socket (31) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:40.186 Auth Websocket socket (31) | New receive buffer size: 5242880 | 2021-05-04 02:48:40.187 Auth Websocket socket (31) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:40.187 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:40.356 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:40.356 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:40.869 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:40.869 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:40.869 Auth Websocket | Server header | Sec-WebSocket-Accept: l6dco03VdPdbgmGheAglSHrvF14= | 2021-05-04 02:48:40.869 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:40.869 Auth Websocket | Server header | | 2021-05-04 02:48:40.869 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:40.869 TransAct WS | Sending account logon message. | 2021-05-04 02:48:40.869 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:41.116 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:41.116 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:41.116 TransAct WS | Session key cleared | 2021-05-04 02:48:41.122 Auth Websocket socket (31) | CloseSocket call. | 2021-05-04 02:48:41.122 Auth Websocket socket (31) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:41.122 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:41.122 TransAct WS | Disconnected. | 2021-05-04 02:48:41.122 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:41.122 Auth Websocket socket (31) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:41.122 Auth Websocket socket (31) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:41.122 Auth Websocket socket (31) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:41.122 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:42.123 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:42.123 Auth Websocket socket (32) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:42.124 Auth Websocket socket (32) | New receive buffer size: 5242880 | 2021-05-04 02:48:42.124 Auth Websocket socket (32) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:42.124 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:42.298 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:42.298 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:42.829 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:42.829 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:42.829 Auth Websocket | Server header | Sec-WebSocket-Accept: t+zOCXEc0ZbObobiITUZYvFCDow= | 2021-05-04 02:48:42.829 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:42.829 Auth Websocket | Server header | | 2021-05-04 02:48:42.829 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:42.829 TransAct WS | Sending account logon message. | 2021-05-04 02:48:42.829 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:43.064 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:43.064 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:43.064 TransAct WS | Session key cleared | 2021-05-04 02:48:43.077 Auth Websocket socket (32) | CloseSocket call. | 2021-05-04 02:48:43.077 Auth Websocket socket (32) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:43.077 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:43.077 TransAct WS | Disconnected. | 2021-05-04 02:48:43.077 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:43.077 Auth Websocket socket (32) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:43.079 Auth Websocket socket (32) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:43.080 Auth Websocket socket (32) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:43.080 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:44.076 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:44.076 Auth Websocket socket (33) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:44.076 Auth Websocket socket (33) | New receive buffer size: 5242880 | 2021-05-04 02:48:44.077 Auth Websocket socket (33) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:44.077 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:44.240 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:44.241 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:44.733 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:44.733 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:44.733 Auth Websocket | Server header | Sec-WebSocket-Accept: i/GlJW7eDFWadAODQOYXcdn+Ypo= | 2021-05-04 02:48:44.733 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:44.733 Auth Websocket | Server header | | 2021-05-04 02:48:44.733 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:44.733 TransAct WS | Sending account logon message. | 2021-05-04 02:48:44.733 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:44.944 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:44.944 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:44.944 TransAct WS | Session key cleared | 2021-05-04 02:48:44.951 Auth Websocket socket (33) | CloseSocket call. | 2021-05-04 02:48:44.951 Auth Websocket socket (33) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:44.951 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:44.951 TransAct WS | Disconnected. | 2021-05-04 02:48:44.951 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:44.951 Auth Websocket socket (33) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:44.953 Auth Websocket socket (33) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:44.953 Auth Websocket socket (33) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:44.953 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:45.951 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:45.951 Auth Websocket socket (34) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:45.952 Auth Websocket socket (34) | New receive buffer size: 5242880 | 2021-05-04 02:48:45.952 Auth Websocket socket (34) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:45.952 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:46.118 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:46.118 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:46.623 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:46.623 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:46.623 Auth Websocket | Server header | Sec-WebSocket-Accept: W+Mg5jxoqe5jp1bubeYQ9wzXH2Q= | 2021-05-04 02:48:46.623 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:46.623 Auth Websocket | Server header | | 2021-05-04 02:48:46.623 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:46.623 TransAct WS | Sending account logon message. | 2021-05-04 02:48:46.623 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:46.839 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:46.839 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:46.839 TransAct WS | Session key cleared | 2021-05-04 02:48:46.857 Auth Websocket socket (34) | CloseSocket call. | 2021-05-04 02:48:46.857 Auth Websocket socket (34) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:46.857 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:46.857 TransAct WS | Disconnected. | 2021-05-04 02:48:46.858 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:46.858 Auth Websocket socket (34) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:46.858 Auth Websocket socket (34) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:46.858 Auth Websocket socket (34) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:46.858 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:47.857 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:47.857 Auth Websocket socket (35) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:47.858 Auth Websocket socket (35) | New receive buffer size: 5242880 | 2021-05-04 02:48:47.858 Auth Websocket socket (35) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:47.858 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:48.021 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:48.021 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:48.513 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:48.513 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:48.513 Auth Websocket | Server header | Sec-WebSocket-Accept: NEVTbOK3Rd4uuwnmXzlaI/8v/Fw= | 2021-05-04 02:48:48.513 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:48.513 Auth Websocket | Server header | | 2021-05-04 02:48:48.513 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:48.513 TransAct WS | Sending account logon message. | 2021-05-04 02:48:48.513 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:48.726 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:48.726 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:48.726 TransAct WS | Session key cleared | 2021-05-04 02:48:48.732 Auth Websocket socket (35) | CloseSocket call. | 2021-05-04 02:48:48.732 Auth Websocket socket (35) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:48.732 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:48.732 TransAct WS | Disconnected. | 2021-05-04 02:48:48.732 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:48.732 Auth Websocket socket (35) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:48.732 Auth Websocket socket (35) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:48.733 Auth Websocket socket (35) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:48.733 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:49.747 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:49.747 Auth Websocket socket (36) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:49.748 Auth Websocket socket (36) | New receive buffer size: 5242880 | 2021-05-04 02:48:49.748 Auth Websocket socket (36) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:49.748 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:49.915 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:49.915 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:50.411 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:50.411 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:50.411 Auth Websocket | Server header | Sec-WebSocket-Accept: lFP4CB8Q/Q+CaVbnlBb0cHR9RRI= | 2021-05-04 02:48:50.411 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:50.411 Auth Websocket | Server header | | 2021-05-04 02:48:50.411 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:50.411 TransAct WS | Sending account logon message. | 2021-05-04 02:48:50.411 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:50.626 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:50.626 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:50.626 TransAct WS | Session key cleared | 2021-05-04 02:48:50.639 Auth Websocket socket (36) | CloseSocket call. | 2021-05-04 02:48:50.639 Auth Websocket socket (36) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:50.639 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:50.639 TransAct WS | Disconnected. | 2021-05-04 02:48:50.639 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:50.639 Auth Websocket socket (36) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:50.639 Auth Websocket socket (36) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:50.639 Auth Websocket socket (36) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:50.639 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:51.639 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:51.639 Auth Websocket socket (37) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:51.639 Auth Websocket socket (37) | New receive buffer size: 5242880 | 2021-05-04 02:48:51.639 Auth Websocket socket (37) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:51.639 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:51.814 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:51.814 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:52.340 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:52.340 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:52.340 Auth Websocket | Server header | Sec-WebSocket-Accept: RRLZwzzFkh2sgF9wpUo72ai9+4I= | 2021-05-04 02:48:52.340 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:52.340 Auth Websocket | Server header | | 2021-05-04 02:48:52.340 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:52.340 TransAct WS | Sending account logon message. | 2021-05-04 02:48:52.340 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:52.563 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:52.563 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:52.563 TransAct WS | Session key cleared | 2021-05-04 02:48:52.576 Auth Websocket socket (37) | CloseSocket call. | 2021-05-04 02:48:52.576 Auth Websocket socket (37) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:52.576 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:52.576 TransAct WS | Disconnected. | 2021-05-04 02:48:52.576 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:52.576 Auth Websocket socket (37) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:52.576 Auth Websocket socket (37) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:52.577 Auth Websocket socket (37) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:52.577 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:53.576 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:53.576 Auth Websocket socket (38) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:53.577 Auth Websocket socket (38) | New receive buffer size: 5242880 | 2021-05-04 02:48:53.577 Auth Websocket socket (38) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:53.577 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:53.741 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:53.741 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:54.231 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:54.231 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:54.231 Auth Websocket | Server header | Sec-WebSocket-Accept: gwdQKlUMnNo+vbOgfAMoBHBizX8= | 2021-05-04 02:48:54.231 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:54.231 Auth Websocket | Server header | | 2021-05-04 02:48:54.231 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:54.231 TransAct WS | Sending account logon message. | 2021-05-04 02:48:54.231 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:54.446 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:54.446 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:54.446 TransAct WS | Session key cleared | 2021-05-04 02:48:54.467 Auth Websocket socket (38) | CloseSocket call. | 2021-05-04 02:48:54.467 Auth Websocket socket (38) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:54.467 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:54.467 TransAct WS | Disconnected. | 2021-05-04 02:48:54.467 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:54.467 Auth Websocket socket (38) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:54.467 Auth Websocket socket (38) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:54.467 Auth Websocket socket (38) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:54.467 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:55.467 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:55.467 Auth Websocket socket (39) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:55.467 Auth Websocket socket (39) | New receive buffer size: 5242880 | 2021-05-04 02:48:55.467 Auth Websocket socket (39) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:55.468 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:55.630 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:55.630 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:56.119 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:56.119 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:56.119 Auth Websocket | Server header | Sec-WebSocket-Accept: Gq1ZDRar5rJboN8uwYNoIO7oup0= | 2021-05-04 02:48:56.119 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:56.119 Auth Websocket | Server header | | 2021-05-04 02:48:56.119 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:56.119 TransAct WS | Sending account logon message. | 2021-05-04 02:48:56.119 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:56.330 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:56.330 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:56.330 TransAct WS | Session key cleared | 2021-05-04 02:48:56.342 Auth Websocket socket (39) | CloseSocket call. | 2021-05-04 02:48:56.342 Auth Websocket socket (39) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:56.342 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:56.342 TransAct WS | Disconnected. | 2021-05-04 02:48:56.342 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:56.342 Auth Websocket socket (39) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:56.342 Auth Websocket socket (39) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:56.342 Auth Websocket socket (39) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:56.342 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:57.342 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:57.342 Auth Websocket socket (40) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:57.342 Auth Websocket socket (40) | New receive buffer size: 5242880 | 2021-05-04 02:48:57.343 Auth Websocket socket (40) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:57.343 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:57.509 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:57.509 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:58.004 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:58.004 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:58.004 Auth Websocket | Server header | Sec-WebSocket-Accept: nPFo8zH8LeIglS2d2GkAkR9O7Yk= | 2021-05-04 02:48:58.004 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:58.004 Auth Websocket | Server header | | 2021-05-04 02:48:58.004 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:58.004 TransAct WS | Sending account logon message. | 2021-05-04 02:48:58.004 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:48:58.218 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:48:58.218 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:58.218 TransAct WS | Session key cleared | 2021-05-04 02:48:58.232 Auth Websocket socket (40) | CloseSocket call. | 2021-05-04 02:48:58.232 Auth Websocket socket (40) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:48:58.232 Auth Websocket | WebSocket closed. | 2021-05-04 02:48:58.232 TransAct WS | Disconnected. | 2021-05-04 02:48:58.232 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:48:58.232 Auth Websocket socket (40) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:48:58.233 Auth Websocket socket (40) | Write has completed. Shutdown being performed. | 2021-05-04 02:48:58.234 Auth Websocket socket (40) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:48:58.234 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:48:59.233 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:48:59.233 Auth Websocket socket (41) | Creating socket. Using TLS 1.2. | 2021-05-04 02:48:59.233 Auth Websocket socket (41) | New receive buffer size: 5242880 | 2021-05-04 02:48:59.234 Auth Websocket socket (41) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:48:59.234 Auth Websocket | Opening WebSocket. | 2021-05-04 02:48:59.448 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:48:59.448 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:48:59.946 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:48:59.946 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:48:59.946 Auth Websocket | Server header | Sec-WebSocket-Accept: l8xuSIOmqmpJIvASNyLN6bXFGkg= | 2021-05-04 02:48:59.946 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:48:59.946 Auth Websocket | Server header | | 2021-05-04 02:48:59.946 Auth Websocket | Web socket state is now open. | 2021-05-04 02:48:59.946 TransAct WS | Sending account logon message. | 2021-05-04 02:48:59.946 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:49:00.161 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:49:00.161 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:49:00.161 TransAct WS | Session key cleared | 2021-05-04 02:49:00.170 Auth Websocket socket (41) | CloseSocket call. | 2021-05-04 02:49:00.170 Auth Websocket socket (41) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:49:00.170 Auth Websocket | WebSocket closed. | 2021-05-04 02:49:00.170 TransAct WS | Disconnected. | 2021-05-04 02:49:00.170 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:49:00.170 Auth Websocket socket (41) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:49:00.170 Auth Websocket socket (41) | Write has completed. Shutdown being performed. | 2021-05-04 02:49:00.171 Auth Websocket socket (41) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:49:00.171 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:49:01.170 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:49:01.170 Auth Websocket socket (42) | Creating socket. Using TLS 1.2. | 2021-05-04 02:49:01.171 Auth Websocket socket (42) | New receive buffer size: 5242880 | 2021-05-04 02:49:01.172 Auth Websocket socket (42) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:49:01.172 Auth Websocket | Opening WebSocket. | 2021-05-04 02:49:01.340 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:49:01.340 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:49:01.845 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:49:01.845 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:49:01.845 Auth Websocket | Server header | Sec-WebSocket-Accept: I6/Fg8oCxyL3x0iIsNME16bhKCY= | 2021-05-04 02:49:01.845 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:49:01.845 Auth Websocket | Server header | | 2021-05-04 02:49:01.845 Auth Websocket | Web socket state is now open. | 2021-05-04 02:49:01.845 TransAct WS | Sending account logon message. | 2021-05-04 02:49:01.845 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:49:02.065 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:49:02.065 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:49:02.065 TransAct WS | Session key cleared | 2021-05-04 02:49:02.076 Auth Websocket socket (42) | CloseSocket call. | 2021-05-04 02:49:02.076 Auth Websocket socket (42) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:49:02.076 Auth Websocket | WebSocket closed. | 2021-05-04 02:49:02.076 TransAct WS | Disconnected. | 2021-05-04 02:49:02.076 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:49:02.076 Auth Websocket socket (42) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:49:02.076 Auth Websocket socket (42) | Write has completed. Shutdown being performed. | 2021-05-04 02:49:02.076 Auth Websocket socket (42) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:49:02.077 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:49:03.076 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:49:03.076 Auth Websocket socket (43) | Creating socket. Using TLS 1.2. | 2021-05-04 02:49:03.077 Auth Websocket socket (43) | New receive buffer size: 5242880 | 2021-05-04 02:49:03.078 Auth Websocket socket (43) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:49:03.078 Auth Websocket | Opening WebSocket. | 2021-05-04 02:49:03.341 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:49:03.341 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:49:03.825 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:49:03.825 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:49:03.825 Auth Websocket | Server header | Sec-WebSocket-Accept: 8kgE0jOXlvz+grT/2Byte1xjbyM= | 2021-05-04 02:49:03.825 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:49:03.825 Auth Websocket | Server header | | 2021-05-04 02:49:03.825 Auth Websocket | Web socket state is now open. | 2021-05-04 02:49:03.825 TransAct WS | Sending account logon message. | 2021-05-04 02:49:03.825 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:49:04.039 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:49:04.039 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:49:04.039 TransAct WS | Session key cleared | 2021-05-04 02:49:04.044 Auth Websocket socket (43) | CloseSocket call. | 2021-05-04 02:49:04.045 Auth Websocket socket (43) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:49:04.045 Auth Websocket | WebSocket closed. | 2021-05-04 02:49:04.045 TransAct WS | Disconnected. | 2021-05-04 02:49:04.045 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:49:04.045 Auth Websocket socket (43) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:49:04.045 Auth Websocket socket (43) | Write has completed. Shutdown being performed. | 2021-05-04 02:49:04.045 Auth Websocket socket (43) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:49:04.045 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:49:05.045 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:49:05.045 Auth Websocket socket (44) | Creating socket. Using TLS 1.2. | 2021-05-04 02:49:05.046 Auth Websocket socket (44) | New receive buffer size: 5242880 | 2021-05-04 02:49:05.046 Auth Websocket socket (44) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:49:05.046 Auth Websocket | Opening WebSocket. | 2021-05-04 02:49:05.216 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:49:05.216 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:49:05.719 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:49:05.719 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:49:05.719 Auth Websocket | Server header | Sec-WebSocket-Accept: ViY5cD/wB+VNkoyRAjul7qDpAso= | 2021-05-04 02:49:05.719 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:49:05.719 Auth Websocket | Server header | | 2021-05-04 02:49:05.719 Auth Websocket | Web socket state is now open. | 2021-05-04 02:49:05.719 TransAct WS | Sending account logon message. | 2021-05-04 02:49:05.719 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:49:06.043 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:49:06.043 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:49:06.043 TransAct WS | Session key cleared | 2021-05-04 02:49:06.242 Auth Websocket socket (44) | CloseSocket call. | 2021-05-04 02:49:06.242 Auth Websocket socket (44) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:49:06.242 Auth Websocket | WebSocket closed. | 2021-05-04 02:49:06.242 Auth Websocket socket (44) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:49:06.242 TransAct WS | Disconnected. | 2021-05-04 02:49:06.242 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:49:06.242 Auth Websocket socket (44) | Write has completed. Shutdown being performed. | 2021-05-04 02:49:06.249 Auth Websocket socket (44) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:49:06.250 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:49:07.232 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:49:07.232 Auth Websocket socket (45) | Creating socket. Using TLS 1.2. | 2021-05-04 02:49:07.233 Auth Websocket socket (45) | New receive buffer size: 5242880 | 2021-05-04 02:49:07.233 Auth Websocket socket (45) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:49:07.233 Auth Websocket | Opening WebSocket. | 2021-05-04 02:49:07.395 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:49:07.395 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:49:07.881 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:49:07.881 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:49:07.881 Auth Websocket | Server header | Sec-WebSocket-Accept: VZOvOqQcb1pGnZTANklnoQ768zY= | 2021-05-04 02:49:07.881 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:49:07.881 Auth Websocket | Server header | | 2021-05-04 02:49:07.881 Auth Websocket | Web socket state is now open. | 2021-05-04 02:49:07.881 TransAct WS | Sending account logon message. | 2021-05-04 02:49:07.881 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:49:08.097 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:49:08.097 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:49:08.097 TransAct WS | Session key cleared | 2021-05-04 02:49:08.173 Auth Websocket socket (45) | CloseSocket call. | 2021-05-04 02:49:08.174 Auth Websocket socket (45) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:49:08.174 Auth Websocket socket (45) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:49:08.175 Auth Websocket | WebSocket closed. | 2021-05-04 02:49:08.175 TransAct WS | Disconnected. | 2021-05-04 02:49:08.176 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:49:08.176 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:49:09.170 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:49:09.170 Auth Websocket socket (46) | Creating socket. Using TLS 1.2. | 2021-05-04 02:49:09.170 Auth Websocket socket (46) | New receive buffer size: 5242880 | 2021-05-04 02:49:09.171 Auth Websocket socket (46) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:49:09.171 Auth Websocket | Opening WebSocket. | 2021-05-04 02:49:09.350 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:49:09.350 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:49:09.876 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:49:09.876 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:49:09.876 Auth Websocket | Server header | Sec-WebSocket-Accept: TPDjbM0IWWZCV4ymMfGV4FzcAzI= | 2021-05-04 02:49:09.876 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:49:09.876 Auth Websocket | Server header | | 2021-05-04 02:49:09.876 Auth Websocket | Web socket state is now open. | 2021-05-04 02:49:09.876 TransAct WS | Sending account logon message. | 2021-05-04 02:49:09.876 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:49:10.198 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:49:10.198 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:49:10.198 TransAct WS | Session key cleared | 2021-05-04 02:49:10.200 Auth Websocket socket (46) | CloseSocket call. | 2021-05-04 02:49:10.200 Auth Websocket socket (46) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:49:10.200 Auth Websocket | WebSocket closed. | 2021-05-04 02:49:10.200 TransAct WS | Disconnected. | 2021-05-04 02:49:10.200 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:49:10.200 Auth Websocket socket (46) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:49:10.201 Auth Websocket socket (46) | Write has completed. Shutdown being performed. | 2021-05-04 02:49:10.201 Auth Websocket socket (46) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:49:10.201 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:49:11.202 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:49:11.202 Auth Websocket socket (47) | Creating socket. Using TLS 1.2. | 2021-05-04 02:49:11.203 Auth Websocket socket (47) | New receive buffer size: 5242880 | 2021-05-04 02:49:11.203 Auth Websocket socket (47) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:49:11.203 Auth Websocket | Opening WebSocket. | 2021-05-04 02:49:11.374 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:49:11.374 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:49:11.887 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:49:11.887 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:49:11.887 Auth Websocket | Server header | Sec-WebSocket-Accept: W7Yl/S00I1yn2kfdfuFQhAwtEMg= | 2021-05-04 02:49:11.888 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:49:11.888 Auth Websocket | Server header | | 2021-05-04 02:49:11.888 Auth Websocket | Web socket state is now open. | 2021-05-04 02:49:11.888 TransAct WS | Sending account logon message. | 2021-05-04 02:49:11.888 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:49:12.107 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:49:12.107 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:49:12.107 TransAct WS | Session key cleared | 2021-05-04 02:49:12.123 Auth Websocket socket (47) | CloseSocket call. | 2021-05-04 02:49:12.123 Auth Websocket socket (47) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:49:12.123 Auth Websocket | WebSocket closed. | 2021-05-04 02:49:12.123 TransAct WS | Disconnected. | 2021-05-04 02:49:12.123 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:49:12.123 Auth Websocket socket (47) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:49:12.123 Auth Websocket socket (47) | Write has completed. Shutdown being performed. | 2021-05-04 02:49:12.124 Auth Websocket socket (47) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:49:12.124 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:49:13.123 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:49:13.123 Auth Websocket socket (48) | Creating socket. Using TLS 1.2. | 2021-05-04 02:49:13.124 Auth Websocket socket (48) | New receive buffer size: 5242880 | 2021-05-04 02:49:13.124 Auth Websocket socket (48) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:49:13.124 Auth Websocket | Opening WebSocket. | 2021-05-04 02:49:13.289 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:49:13.289 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:49:13.789 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:49:13.789 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:49:13.789 Auth Websocket | Server header | Sec-WebSocket-Accept: mnR/I2kSWPBqhvlXOxIeKmgrw6E= | 2021-05-04 02:49:13.789 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:49:13.789 Auth Websocket | Server header | | 2021-05-04 02:49:13.789 Auth Websocket | Web socket state is now open. | 2021-05-04 02:49:13.789 TransAct WS | Sending account logon message. | 2021-05-04 02:49:13.789 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:49:14.004 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:49:14.004 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:49:14.005 TransAct WS | Session key cleared | 2021-05-04 02:49:14.013 Auth Websocket socket (48) | CloseSocket call. | 2021-05-04 02:49:14.013 Auth Websocket socket (48) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:49:14.013 Auth Websocket | WebSocket closed. | 2021-05-04 02:49:14.013 TransAct WS | Disconnected. | 2021-05-04 02:49:14.013 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:49:14.013 Auth Websocket socket (48) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:49:14.013 Auth Websocket socket (48) | Write has completed. Shutdown being performed. | 2021-05-04 02:49:14.013 Auth Websocket socket (48) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:49:14.013 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:49:15.014 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:49:15.014 Auth Websocket socket (49) | Creating socket. Using TLS 1.2. | 2021-05-04 02:49:15.015 Auth Websocket socket (49) | New receive buffer size: 5242880 | 2021-05-04 02:49:15.015 Auth Websocket socket (49) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:49:15.015 Auth Websocket | Opening WebSocket. | 2021-05-04 02:49:15.190 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:49:15.190 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:49:15.705 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:49:15.705 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:49:15.705 Auth Websocket | Server header | Sec-WebSocket-Accept: b06G+m6kLfyfhG3bCR+LNJhBKPk= | 2021-05-04 02:49:15.705 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:49:15.705 Auth Websocket | Server header | | 2021-05-04 02:49:15.705 Auth Websocket | Web socket state is now open. | 2021-05-04 02:49:15.706 TransAct WS | Sending account logon message. | 2021-05-04 02:49:15.706 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:49:15.927 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:49:15.927 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:49:15.927 TransAct WS | Session key cleared | 2021-05-04 02:49:15.936 Auth Websocket socket (49) | CloseSocket call. | 2021-05-04 02:49:15.936 Auth Websocket socket (49) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:49:15.936 Auth Websocket | WebSocket closed. | 2021-05-04 02:49:15.936 TransAct WS | Disconnected. | 2021-05-04 02:49:15.936 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:49:15.936 Auth Websocket socket (49) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:49:15.936 Auth Websocket socket (49) | Write has completed. Shutdown being performed. | 2021-05-04 02:49:15.936 Auth Websocket socket (49) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:49:15.936 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:49:16.936 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:49:16.936 Auth Websocket socket (50) | Creating socket. Using TLS 1.2. | 2021-05-04 02:49:16.936 Auth Websocket socket (50) | New receive buffer size: 5242880 | 2021-05-04 02:49:16.936 Auth Websocket socket (50) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:49:16.936 Auth Websocket | Opening WebSocket. | 2021-05-04 02:49:17.101 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:49:17.101 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:49:17.587 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:49:17.587 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:49:17.587 Auth Websocket | Server header | Sec-WebSocket-Accept: /POFh7dW1hwrDZFLwqbp1wY+Wy8= | 2021-05-04 02:49:17.587 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:49:17.587 Auth Websocket | Server header | | 2021-05-04 02:49:17.587 Auth Websocket | Web socket state is now open. | 2021-05-04 02:49:17.587 TransAct WS | Sending account logon message. | 2021-05-04 02:49:17.587 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:49:17.798 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:49:17.798 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:49:17.798 TransAct WS | Session key cleared | 2021-05-04 02:49:17.810 Auth Websocket socket (50) | CloseSocket call. | 2021-05-04 02:49:17.810 Auth Websocket socket (50) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:49:17.810 Auth Websocket | WebSocket closed. | 2021-05-04 02:49:17.810 TransAct WS | Disconnected. | 2021-05-04 02:49:17.810 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:49:17.810 Auth Websocket socket (50) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:49:17.811 Auth Websocket socket (50) | Write has completed. Shutdown being performed. | 2021-05-04 02:49:17.811 Auth Websocket socket (50) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:49:17.811 Auth Websocket socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:49:57.733 Auth Websocket socket (1) | Closed. | 2021-05-04 02:49:57.733 Auth Websocket socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:49:57.733 Auth Websocket socket (2) | Closed. | 2021-05-04 02:49:57.733 Auth Websocket socket (3) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:49:57.733 Auth Websocket socket (3) | Closed. | 2021-05-04 02:49:57.733 Auth Websocket socket (4) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:49:57.733 Auth Websocket socket (4) | Closed. | 2021-05-04 02:49:57.733 Auth Websocket socket (5) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:49:57.733 Auth Websocket socket (5) | Closed. | 2021-05-04 02:49:57.733 Auth Websocket socket (6) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:49:57.733 Auth Websocket socket (6) | Closed. | 2021-05-04 02:49:57.733 Auth Websocket socket (7) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:49:57.733 Auth Websocket socket (7) | Closed. | 2021-05-04 02:49:57.733 Auth Websocket socket (8) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:49:57.733 Auth Websocket socket (8) | Closed. | 2021-05-04 02:49:57.733 Auth Websocket socket (1) | Deleting network socket now after delay. | 2021-05-04 02:50:27.748 Auth Websocket socket (2) | Deleting network socket now after delay. | 2021-05-04 02:50:27.748 Auth Websocket socket (3) | Deleting network socket now after delay. | 2021-05-04 02:50:27.748 Auth Websocket socket (4) | Deleting network socket now after delay. | 2021-05-04 02:50:27.748 Auth Websocket socket (5) | Deleting network socket now after delay. | 2021-05-04 02:50:27.748 Auth Websocket socket (6) | Deleting network socket now after delay. | 2021-05-04 02:50:27.748 Auth Websocket socket (7) | Deleting network socket now after delay. | 2021-05-04 02:50:27.748 Auth Websocket socket (8) | Deleting network socket now after delay. | 2021-05-04 02:50:27.748 Auth Websocket socket (9) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:27.748 Auth Websocket socket (9) | Closed. | 2021-05-04 02:50:27.748 Auth Websocket socket (10) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:27.748 Auth Websocket socket (10) | Closed. | 2021-05-04 02:50:27.749 Auth Websocket socket (11) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:27.749 Auth Websocket socket (11) | Closed. | 2021-05-04 02:50:27.749 Auth Websocket socket (12) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:27.749 Auth Websocket socket (12) | Closed. | 2021-05-04 02:50:27.749 Auth Websocket socket (13) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:27.749 Auth Websocket socket (13) | Closed. | 2021-05-04 02:50:27.749 Auth Websocket socket (14) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:27.749 Auth Websocket socket (14) | Closed. | 2021-05-04 02:50:27.749 Auth Websocket socket (15) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:27.749 Auth Websocket socket (15) | Closed. | 2021-05-04 02:50:27.749 Auth Websocket socket (16) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:27.749 Auth Websocket socket (16) | Closed. | 2021-05-04 02:50:27.749 Auth Websocket socket (17) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:27.749 Auth Websocket socket (17) | Closed. | 2021-05-04 02:50:27.749 Auth Websocket socket (18) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:27.749 Auth Websocket socket (18) | Closed. | 2021-05-04 02:50:27.749 Auth Websocket socket (19) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:27.749 Auth Websocket socket (19) | Closed. | 2021-05-04 02:50:27.749 Auth Websocket socket (20) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:27.749 Auth Websocket socket (20) | Closed. | 2021-05-04 02:50:27.749 Auth Websocket socket (21) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:27.749 Auth Websocket socket (21) | Closed. | 2021-05-04 02:50:27.749 Auth Websocket socket (22) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:27.749 Auth Websocket socket (22) | Closed. | 2021-05-04 02:50:27.749 Auth Websocket socket (23) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:27.749 Auth Websocket socket (23) | Closed. | 2021-05-04 02:50:27.750 Auth Websocket socket (24) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:27.750 Auth Websocket socket (24) | Closed. | 2021-05-04 02:50:27.750 MESM1 5 Min #1 | Reloading chart. | 2021-05-04 02:50:43.631 MESM1 5 Min #2 | Reloading chart. | 2021-05-04 02:50:43.741 MESM1 5 Min #3 | Reloading chart. | 2021-05-04 02:50:43.750 MESM1 5 Min #4 | Reloading chart. | 2021-05-04 02:50:43.760 MESM1 15 Min #5 | Reloading chart. | 2021-05-04 02:50:44.007 Starting DelayedDownloadMonitoringTimer | 2021-05-04 02:50:45.545 Starting HDTimeoutTimer | 2021-05-04 02:50:45.545 Added historical Intraday data request for MESM1 to the queue. | 2021-05-04 02:50:45.545 Intraday data recording state for symbol MESM1 is set to download 'Pending'. | 2021-05-04 02:50:45.545 Triggering next historical data download in queue. | 2021-05-04 02:50:45.545 HD Request # 1 | Downloading Intraday chart data for MESM1 to the file MESM1.scid. Service: TransAct.Trading | 2021-05-04 02:50:45.545 HD Request # 1 | Download start date-time: 2021-05-03 16:44:11.000000. File last date-time: 2021-05-03 16:44:11.000000 | 2021-05-04 02:50:45.546 HD Request # 1 | Using server: ds12.sierracharts.com port 10150 | 2021-05-04 02:50:45.552 Socket (1) | Creating socket. | 2021-05-04 02:50:45.592 Socket (1) | New receive buffer size: 5242880 | 2021-05-04 02:50:45.593 Socket (1) | Connecting to IP: 204.15.197.14. | 2021-05-04 02:50:45.593 HD Request # 1 | Setting DTC encoding to Binary VLS | 2021-05-04 02:50:45.932 HD Request # 1 | Sending historical data logon request message. | 2021-05-04 02:50:45.932 HD Request # 1 | Requesting Intraday data. Start date-time: 2021-05-03 16:44:11. Record interval: 0. Symbol: MESM1 | 2021-05-04 02:50:46.576 Socket (1) | CloseSocket call. | 2021-05-04 02:50:46.749 Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:50:46.749 Socket (1) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:50:46.749 HD Request # 1 | Historical data for MESM1 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2021-05-04 02:50:46.750 Historical data download thread signaled to stop. | 2021-05-04 02:50:46.750 HD Request # 1 | Received 0 records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for MESM1 | 2021-05-04 02:50:46.750 HD Request # 1 | Completion time: 1s | 2021-05-04 02:50:46.799 HD Request # 1 | Intraday data download complete for MESM1. Unique request ID: 1 | 2021-05-04 02:50:46.799 Removing historical data download ID 1. | 2021-05-04 02:50:46.799 HD Request # 1 | Enabling Intraday chart updating for symbol. | 2021-05-04 02:50:46.799 Triggering next historical data download in queue. | 2021-05-04 02:50:46.799 No download requests in the queue to start downloads for. | 2021-05-04 02:50:46.799 Socket (1) | Socket gracefully closed by remote side. | 2021-05-04 02:50:46.914 Socket (1) | Closed. | 2021-05-04 02:50:46.914 Auth Websocket socket (9) | Deleting network socket now after delay. | 2021-05-04 02:50:57.780 Auth Websocket socket (10) | Deleting network socket now after delay. | 2021-05-04 02:50:57.780 Auth Websocket socket (11) | Deleting network socket now after delay. | 2021-05-04 02:50:57.780 Auth Websocket socket (12) | Deleting network socket now after delay. | 2021-05-04 02:50:57.780 Auth Websocket socket (13) | Deleting network socket now after delay. | 2021-05-04 02:50:57.780 Auth Websocket socket (14) | Deleting network socket now after delay. | 2021-05-04 02:50:57.780 Auth Websocket socket (15) | Deleting network socket now after delay. | 2021-05-04 02:50:57.780 Auth Websocket socket (16) | Deleting network socket now after delay. | 2021-05-04 02:50:57.780 Auth Websocket socket (17) | Deleting network socket now after delay. | 2021-05-04 02:50:57.780 Auth Websocket socket (18) | Deleting network socket now after delay. | 2021-05-04 02:50:57.780 Auth Websocket socket (19) | Deleting network socket now after delay. | 2021-05-04 02:50:57.780 Auth Websocket socket (20) | Deleting network socket now after delay. | 2021-05-04 02:50:57.780 Auth Websocket socket (21) | Deleting network socket now after delay. | 2021-05-04 02:50:57.780 Auth Websocket socket (22) | Deleting network socket now after delay. | 2021-05-04 02:50:57.780 Auth Websocket socket (23) | Deleting network socket now after delay. | 2021-05-04 02:50:57.780 Auth Websocket socket (24) | Deleting network socket now after delay. | 2021-05-04 02:50:57.780 Auth Websocket socket (25) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:57.780 Auth Websocket socket (25) | Closed. | 2021-05-04 02:50:57.780 Auth Websocket socket (26) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:57.780 Auth Websocket socket (26) | Closed. | 2021-05-04 02:50:57.780 Auth Websocket socket (27) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:57.780 Auth Websocket socket (27) | Closed. | 2021-05-04 02:50:57.780 Auth Websocket socket (28) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:57.780 Auth Websocket socket (28) | Closed. | 2021-05-04 02:50:57.780 Auth Websocket socket (29) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:57.780 Auth Websocket socket (29) | Closed. | 2021-05-04 02:50:57.781 Auth Websocket socket (30) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:57.781 Auth Websocket socket (30) | Closed. | 2021-05-04 02:50:57.781 Auth Websocket socket (31) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:57.781 Auth Websocket socket (31) | Closed. | 2021-05-04 02:50:57.782 Auth Websocket socket (32) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:57.782 Auth Websocket socket (32) | Closed. | 2021-05-04 02:50:57.782 Auth Websocket socket (33) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:57.782 Auth Websocket socket (33) | Closed. | 2021-05-04 02:50:57.782 Auth Websocket socket (34) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:57.782 Auth Websocket socket (34) | Closed. | 2021-05-04 02:50:57.783 Auth Websocket socket (35) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:57.783 Auth Websocket socket (35) | Closed. | 2021-05-04 02:50:57.783 Auth Websocket socket (36) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:57.783 Auth Websocket socket (36) | Closed. | 2021-05-04 02:50:57.784 Auth Websocket socket (37) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:57.784 Auth Websocket socket (37) | Closed. | 2021-05-04 02:50:57.784 Auth Websocket socket (38) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:57.784 Auth Websocket socket (38) | Closed. | 2021-05-04 02:50:57.785 Auth Websocket socket (39) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:50:57.785 Auth Websocket socket (39) | Closed. | 2021-05-04 02:50:57.785 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:51:17.814 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:51:17.814 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2021-05-04 02:51:17.815 Auth Websocket socket (1) | New receive buffer size: 5242880 | 2021-05-04 02:51:17.816 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:51:17.816 Auth Websocket | Opening WebSocket. | 2021-05-04 02:51:17.981 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:51:17.982 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:51:18.476 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:51:18.476 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:51:18.476 Auth Websocket | Server header | Sec-WebSocket-Accept: uWCqiYlRssMRiwfJ3UP/8NvRf78= | 2021-05-04 02:51:18.476 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:51:18.476 Auth Websocket | Server header | | 2021-05-04 02:51:18.476 Auth Websocket | Web socket state is now open. | 2021-05-04 02:51:18.476 TransAct WS | Sending account logon message. | 2021-05-04 02:51:18.476 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:51:18.691 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:51:18.691 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:51:18.691 TransAct WS | Session key cleared | 2021-05-04 02:51:19.224 Auth Websocket socket (1) | CloseSocket call. | 2021-05-04 02:51:19.225 Auth Websocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:51:19.225 Auth Websocket | WebSocket closed. | 2021-05-04 02:51:19.225 Auth Websocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:51:19.225 Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2021-05-04 02:51:19.225 Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:51:19.225 TransAct WS | Disconnected. | 2021-05-04 02:51:19.226 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:51:19.226 Auth Websocket socket (40) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:51:27.780 Auth Websocket socket (40) | Closed. | 2021-05-04 02:51:27.780 Auth Websocket socket (41) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:51:27.780 Auth Websocket socket (41) | Closed. | 2021-05-04 02:51:27.780 Auth Websocket socket (42) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:51:27.780 Auth Websocket socket (42) | Closed. | 2021-05-04 02:51:27.780 Auth Websocket socket (43) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:51:27.780 Auth Websocket socket (43) | Closed. | 2021-05-04 02:51:27.780 Auth Websocket socket (44) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:51:27.780 Auth Websocket socket (44) | Closed. | 2021-05-04 02:51:27.781 Auth Websocket socket (45) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:51:27.781 Auth Websocket socket (45) | Closed. | 2021-05-04 02:51:27.781 Auth Websocket socket (46) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:51:27.781 Auth Websocket socket (46) | Closed. | 2021-05-04 02:51:27.781 Auth Websocket socket (47) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:51:27.781 Auth Websocket socket (47) | Closed. | 2021-05-04 02:51:27.781 Auth Websocket socket (48) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:51:27.781 Auth Websocket socket (48) | Closed. | 2021-05-04 02:51:27.781 Auth Websocket socket (49) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:51:27.781 Auth Websocket socket (49) | Closed. | 2021-05-04 02:51:27.781 Auth Websocket socket (50) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:51:27.781 Auth Websocket socket (50) | Closed. | 2021-05-04 02:51:27.781 Auth Websocket socket (25) | Deleting network socket now after delay. | 2021-05-04 02:51:57.811 Auth Websocket socket (26) | Deleting network socket now after delay. | 2021-05-04 02:51:57.811 Auth Websocket socket (27) | Deleting network socket now after delay. | 2021-05-04 02:51:57.811 Auth Websocket socket (28) | Deleting network socket now after delay. | 2021-05-04 02:51:57.812 Auth Websocket socket (29) | Deleting network socket now after delay. | 2021-05-04 02:51:57.812 Auth Websocket socket (30) | Deleting network socket now after delay. | 2021-05-04 02:51:57.812 Auth Websocket socket (31) | Deleting network socket now after delay. | 2021-05-04 02:51:57.812 Auth Websocket socket (32) | Deleting network socket now after delay. | 2021-05-04 02:51:57.812 Auth Websocket socket (33) | Deleting network socket now after delay. | 2021-05-04 02:51:57.812 Auth Websocket socket (34) | Deleting network socket now after delay. | 2021-05-04 02:51:57.812 Auth Websocket socket (35) | Deleting network socket now after delay. | 2021-05-04 02:51:57.812 Auth Websocket socket (36) | Deleting network socket now after delay. | 2021-05-04 02:51:57.812 Auth Websocket socket (37) | Deleting network socket now after delay. | 2021-05-04 02:51:57.812 Auth Websocket socket (38) | Deleting network socket now after delay. | 2021-05-04 02:51:57.812 Auth Websocket socket (39) | Deleting network socket now after delay. | 2021-05-04 02:51:57.812 Auth Websocket socket (40) | Deleting network socket now after delay. | 2021-05-04 02:51:57.812 Auth Websocket socket (41) | Deleting network socket now after delay. | 2021-05-04 02:51:57.812 Auth Websocket socket (42) | Deleting network socket now after delay. | 2021-05-04 02:51:57.812 Auth Websocket socket (43) | Deleting network socket now after delay. | 2021-05-04 02:51:57.812 Auth Websocket socket (44) | Deleting network socket now after delay. | 2021-05-04 02:51:57.812 Auth Websocket socket (45) | Deleting network socket now after delay. | 2021-05-04 02:51:57.812 Auth Websocket socket (46) | Deleting network socket now after delay. | 2021-05-04 02:51:57.812 Auth Websocket socket (47) | Deleting network socket now after delay. | 2021-05-04 02:51:57.812 Auth Websocket socket (48) | Deleting network socket now after delay. | 2021-05-04 02:51:57.812 Auth Websocket socket (49) | Deleting network socket now after delay. | 2021-05-04 02:51:57.812 Auth Websocket socket (50) | Deleting network socket now after delay. | 2021-05-04 02:51:57.812 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:53:19.217 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:53:19.217 Auth Websocket socket (2) | Creating socket. Using TLS 1.2. | 2021-05-04 02:53:19.217 Auth Websocket socket (2) | New receive buffer size: 5242880 | 2021-05-04 02:53:19.218 Auth Websocket socket (2) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:53:19.218 Auth Websocket | Opening WebSocket. | 2021-05-04 02:53:19.387 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:53:19.387 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:53:19.892 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:53:19.892 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:53:19.892 Auth Websocket | Server header | Sec-WebSocket-Accept: cGCBaYN/Ac8w4+TdyEVAH64e8Ik= | 2021-05-04 02:53:19.892 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:53:19.892 Auth Websocket | Server header | | 2021-05-04 02:53:19.892 Auth Websocket | Web socket state is now open. | 2021-05-04 02:53:19.892 TransAct WS | Sending account logon message. | 2021-05-04 02:53:19.892 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:53:20.106 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:53:20.106 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:53:20.106 TransAct WS | Session key cleared | 2021-05-04 02:53:20.125 Auth Websocket socket (2) | CloseSocket call. | 2021-05-04 02:53:20.126 Auth Websocket socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:53:20.126 Auth Websocket | WebSocket closed. | 2021-05-04 02:53:20.126 TransAct WS | Disconnected. | 2021-05-04 02:53:20.126 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:53:20.126 Auth Websocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:53:20.127 Auth Websocket socket (2) | Write has completed. Shutdown being performed. | 2021-05-04 02:53:20.127 Auth Websocket socket (2) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:53:20.128 Auth Websocket socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:53:27.843 Auth Websocket socket (1) | Closed. | 2021-05-04 02:53:27.843 Auth Websocket socket (1) | Deleting network socket now after delay. | 2021-05-04 02:53:57.858 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:55:20.125 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:55:20.125 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2021-05-04 02:55:20.127 Auth Websocket socket (1) | New receive buffer size: 5242880 | 2021-05-04 02:55:20.127 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:55:20.127 Auth Websocket | Opening WebSocket. | 2021-05-04 02:55:20.289 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:55:20.289 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:55:20.778 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:55:20.778 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:55:20.778 Auth Websocket | Server header | Sec-WebSocket-Accept: 67PFntRXut7Ps8kIrpiQTSC2cZQ= | 2021-05-04 02:55:20.778 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:55:20.778 Auth Websocket | Server header | | 2021-05-04 02:55:20.778 Auth Websocket | Web socket state is now open. | 2021-05-04 02:55:20.778 TransAct WS | Sending account logon message. | 2021-05-04 02:55:20.778 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:55:20.988 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:55:20.988 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:55:20.988 TransAct WS | Session key cleared | 2021-05-04 02:55:21.000 Auth Websocket socket (1) | CloseSocket call. | 2021-05-04 02:55:21.000 Auth Websocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:55:21.000 Auth Websocket | WebSocket closed. | 2021-05-04 02:55:21.000 TransAct WS | Disconnected. | 2021-05-04 02:55:21.000 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:55:21.000 Auth Websocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:55:21.001 Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2021-05-04 02:55:21.001 Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:55:21.001 Auth Websocket socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:55:27.890 Auth Websocket socket (2) | Closed. | 2021-05-04 02:55:27.890 Auth Websocket socket (2) | Deleting network socket now after delay. | 2021-05-04 02:55:57.922 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:57:21.000 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:57:21.000 Auth Websocket socket (2) | Creating socket. Using TLS 1.2. | 2021-05-04 02:57:21.003 Auth Websocket socket (2) | New receive buffer size: 5242880 | 2021-05-04 02:57:21.005 Auth Websocket socket (2) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:57:21.005 Auth Websocket | Opening WebSocket. | 2021-05-04 02:57:21.173 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:57:21.173 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:57:21.701 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:57:21.701 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:57:21.701 Auth Websocket | Server header | Sec-WebSocket-Accept: Np/7EcQyvmBV4EMrgfLlWqgFTzo= | 2021-05-04 02:57:21.701 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:57:21.701 Auth Websocket | Server header | | 2021-05-04 02:57:21.701 Auth Websocket | Web socket state is now open. | 2021-05-04 02:57:21.701 TransAct WS | Sending account logon message. | 2021-05-04 02:57:21.701 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:57:21.915 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:57:21.915 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:57:21.915 TransAct WS | Session key cleared | 2021-05-04 02:57:21.938 Auth Websocket socket (2) | CloseSocket call. | 2021-05-04 02:57:21.938 Auth Websocket socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:57:21.938 Auth Websocket | WebSocket closed. | 2021-05-04 02:57:21.938 TransAct WS | Disconnected. | 2021-05-04 02:57:21.938 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:57:21.938 Auth Websocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:57:21.938 Auth Websocket socket (2) | Write has completed. Shutdown being performed. | 2021-05-04 02:57:21.938 Auth Websocket socket (2) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:57:21.938 Auth Websocket socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:57:27.969 Auth Websocket socket (1) | Closed. | 2021-05-04 02:57:27.969 Auth Websocket socket (1) | Deleting network socket now after delay. | 2021-05-04 02:57:57.984 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-05-04 02:59:21.938 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-05-04 02:59:21.938 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2021-05-04 02:59:21.938 Auth Websocket socket (1) | New receive buffer size: 5242880 | 2021-05-04 02:59:21.938 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2021-05-04 02:59:21.938 Auth Websocket | Opening WebSocket. | 2021-05-04 02:59:22.114 Auth Websocket | Sending WebSocket handshake. | 2021-05-04 02:59:22.114 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-04 02:59:22.645 Auth Websocket | Server header | Upgrade: WebSocket | 2021-05-04 02:59:22.645 Auth Websocket | Server header | Connection: Upgrade | 2021-05-04 02:59:22.645 Auth Websocket | Server header | Sec-WebSocket-Accept: Wdg8NYk8TyoRhUt+X6YhhCTyNlE= | 2021-05-04 02:59:22.645 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-05-04 02:59:22.645 Auth Websocket | Server header | | 2021-05-04 02:59:22.645 Auth Websocket | Web socket state is now open. | 2021-05-04 02:59:22.645 TransAct WS | Sending account logon message. | 2021-05-04 02:59:22.645 TransAct WS | Account logon error: -1(-1) | 2021-05-04 02:59:22.948 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-05-04 02:59:22.948 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:59:22.948 TransAct WS | Session key cleared | 2021-05-04 02:59:22.969 Auth Websocket socket (1) | CloseSocket call. | 2021-05-04 02:59:22.969 Auth Websocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-04 02:59:22.970 Auth Websocket | WebSocket closed. | 2021-05-04 02:59:22.970 TransAct WS | Disconnected. | 2021-05-04 02:59:22.970 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-05-04 02:59:22.970 Auth Websocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-04 02:59:22.970 Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2021-05-04 02:59:22.970 Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2021-05-04 02:59:22.970 Auth Websocket socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 02:59:28.001 Auth Websocket socket (2) | Closed. | 2021-05-04 02:59:28.001 Auth Websocket socket (2) | Deleting network socket now after delay. | 2021-05-04 02:59:58.016 |
[2021-05-04 18:39:59] |
John - SC Support - Posts: 31379 |
You are getting the following error: TransAct WS | Account logon error: -1(-1)
Normally this means that TransAct needs to allow your account to use the websocket. Refer to the information here: https://www.sierrachart.com/index.php?page=doc/TransAct.php#AccountLogonError But, we just ran across a situation where an incorrect password was generating this same message. So first, check with TransAct and see if they need to approve your account. If so, then that should be it. If it is already approved, then try re-entering your TransAct password on the File >> Data/Trade Service Settings window. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
