Date/Time: Wed, 01 May 2024 17:43:47 +0000
Denali data and live trading
View Count: 567
[2021-05-04 10:22:13] |
User938731 - Posts: 16 |
Hi there. Yesterday I wanted to activate the denali exchange feed in order to get the denali CME exhange data. However I was somewhat confused, because I could not find where I could just activate it for the 10 usd/m as per your info. So I took a package deal for a month. I did this while I still had some usage time on my half year sub. I just wanted to test my live trading connection, but it failed to function. Maybe I did something wrong with the package deal. Please advise. Greetz, Maurice.
[2021-05-04 15:01:58] |
John - SC Support - Posts: 31260 |
Everything about your setup looks correct. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-04 16:33:19] |
Can it be that AMP has to activate the feed with my AMP account? I assume that I have to connect via SC/TT order routing.... ?
[2021-05-04 18:51:45] |
No, it is not anything related to activating an account with AMP, at least not at this time. You are currently validated as having a trading account through May 20, 2021. So you will need to connect to your account before that date, but for now it is something else. Please follow the instructions above to get us your Message Log. ------------------------ You can not connect to AMP using the SC/TT Order Routing any longer. AMP stopped support for that about 2 months ago. They should have set you up with CQG at this time. Once you have the CQG information, follow these instructions to connect to your CQG account: CQG Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-04 19:24:09] |
I had CQG. But I cancelled it to start using your Denali feed. Do I need a CQG connection to get the Denali feed? Than I would have to reactivate again. And how long will it take for you to set up your new direct feed with the CME?
[2021-05-04 20:29:22] |
You would still need CQG for Order Routing in order to verify you have a live, funded, futures trading account to qualify for the non-professional CME Group exchange fees. If you are with AMP, then most likely you still have CQG for order routing, and you just stopped the data from CQG. But you would need to verify this with AMP. ------------------------------- Nonetheless, there is still something else going on with your data. Please get us your Message Log by following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-04 20:40:46] |
Software version: 2250 64-bit | 2021-05-04 16:39:46.369 Primary Thread ID: 5260 | 2021-05-04 16:39:46.369 Usage end date: 2021-06-28 | 2021-05-04 16:39:46.369 Enabled for: Advanced Features 2. | 2021-05-04 16:39:46.369 Enabled for: Sierra Chart Historical Data Service. | 2021-05-04 16:39:46.369 Enabled for: Denali Real-Time Exchange Data Feed. | 2021-05-04 16:39:46.369 Enabled for: Delayed Denali Exchange Data Feed. | 2021-05-04 16:39:46.369 Enabled for exchange2: CME (Trading Account Required) | 2021-05-04 16:39:46.369 Enabled for exchange2: CBOT (Trading Account Required) | 2021-05-04 16:39:46.369 Enabled for exchange2: COMEX (Trading Account Required) | 2021-05-04 16:39:46.369 Enabled for exchange2: NYMEX (Trading Account Required) | 2021-05-04 16:39:46.369 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-05-04 16:39:46.369 Current selected Data/Trading service: SC Data - All Services | 2021-05-04 16:39:46.369 Custom symbol settings values: enabled | 2021-05-04 16:39:46.369 Chart Update Interval: 1000 | 2021-05-04 16:39:46.369 Intraday Data Storage Time Unit: 0 | 2021-05-04 16:39:46.369 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-05-04 16:39:46.369 2021-05-04 20:39:46 Local computer time in UTC | 2021-05-04 16:39:46.369 2021-05-04 16:39:46 Local computer time in SC Time Zone | 2021-05-04 16:39:46.369 2021-05-04 20:32:15 Server time in UTC | 2021-05-04 16:39:46.369 Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-05-04 16:39:46.369 Program path: C:\SierraChart\ | 2021-05-04 16:39:46.369 Data Files path: C:\SierraChart\Data\ | 2021-05-04 16:39:46.369 OS Version Number: 10.0 | 2021-05-04 16:39:46.369 Locale Setting: C | 2021-05-04 16:39:46.369 DLLs: Convergent_64.dll, ETOFSv2.0.dll, ETOFSv2.0_64.dll, ETOFSv3.dll, ETOFSv3_64.dll, MAutoFloorCeiling.dll, MAutoFloorCeiling_2151.dll, MAutoFloorCeiling_2151_64.dll, MAutoFloorCeiling_64.dll, MBidAskOscillator.dll, MBidAskOscillator_2151.dll, MBidAskOscillator_2151_64.dll, MBidAskOscillator_64.dll, MBoxChart.dll, MBoxChart_2151.dll, MBoxChart_2151_64.dll, MBoxChart_64.dll, MBoxHistogram.dll, MBoxHistogram_2151.dll, MBoxHistogram_2151_64.dll, MBoxHistogram_64.dll, MCumulativeDelta.dll, MCumulativeDelta_2151.dll | 2021-05-04 16:39:46.370 Allowed protected custom studies: Smaug_SC_Library, SST_FreeBundle, SST_VolumeProfile, zyp_download_free | 2021-05-04 16:39:46.370 File >> Disconnect selected. | 2021-05-04 16:39:51.629 SC Data - All Services | Waiting for socket receive thread to end | 2021-05-04 16:39:51.630 DTC Client socket (1) | CloseSocket call. | 2021-05-04 16:39:51.630 DTC Client socket (1) | Max send buffers used during socket life: 4 | 2021-05-04 16:39:51.630 DTC Client socket (1) | Max send buffer size during socket life: 2450 | 2021-05-04 16:39:51.630 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-05-04 16:39:51.630 SC Data - All Services | Disconnected from the server. | 2021-05-04 16:39:51.631 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2021-05-04 16:39:51.631 DTC Client socket (2) | CloseSocket call. | 2021-05-04 16:39:51.631 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-05-04 16:39:51.631 SC DTC Data with Market Depth | Disconnected from the server. | 2021-05-04 16:39:51.631 SC Data - All Services | Disconnected. | 2021-05-04 16:39:51.631 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-05-04 16:39:51.756 DTC Client socket (2) | Closed. | 2021-05-04 16:39:51.756 SC Data - All Services | Connected to server complete. | 2021-05-04 16:39:57.738 Triggering next historical data download in queue. | 2021-05-04 16:39:57.738 Triggering next historical data download in queue. | 2021-05-04 16:39:57.738 Triggering next historical data download in queue. | 2021-05-04 16:39:57.738 Triggering next historical data download in queue. | 2021-05-04 16:39:57.738 No download requests in the queue to start downloads for. | 2021-05-04 16:39:57.738 No download requests in the queue to start downloads for. | 2021-05-04 16:39:57.739 No download requests in the queue to start downloads for. | 2021-05-04 16:39:57.739 No download requests in the queue to start downloads for. | 2021-05-04 16:39:57.739 Mapping ESM21-CME to ESM21. Service code: cme | 2021-05-04 16:39:58.060 SC Data - All Services | Starting real-time market data updates for: ESM21-CME (ESM21). ID: 1 Service code: cme | 2021-05-04 16:39:58.060 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2021-05-04 16:39:58.060 SC Data - All Services | Requesting security definition data for: ESM21-CME (ESM21). ID: 1 | 2021-05-04 16:39:58.060 Added historical Intraday data request for ESM21-CME to the queue. | 2021-05-04 16:39:58.060 Intraday data recording state for symbol ESM21-CME is set to download 'Pending'. | 2021-05-04 16:39:58.060 Triggering next historical data download in queue. | 2021-05-04 16:39:58.060 DTC Client socket (2) | Creating socket. | 2021-05-04 16:39:58.060 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-05-04 16:39:58.060 DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2021-05-04 16:39:58.060 Delaying start of download for ESM21-CME | 2021-05-04 16:39:58.075 SC Data - All Services | Network connection to server complete. | 2021-05-04 16:39:58.167 SC Data - All Services | Starting socket receive thread. | 2021-05-04 16:39:58.167 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-05-04 16:39:58.167 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-05-04 16:39:58.285 SC Data - All Services | Sending logon request message. | 2021-05-04 16:39:58.285 SC Data - All Services | Received logon response. | 2021-05-04 16:39:59.036 SC Data - All Services | Server Name: SC Realtime Server. | 2021-05-04 16:39:59.036 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-05-04 16:39:59.036 SC Data - All Services | Successfully connected. | 2021-05-04 16:39:59.036 SC Data - All Services | Trading is not supported. | 2021-05-04 16:39:59.036 SC Data - All Services | Restarting real-time data updates for symbol: ESM21-CME -> ESM21 | 2021-05-04 16:39:59.036 SC Data - All Services | Received security definition for symbol ESM21-CME | 2021-05-04 16:39:59.160 HD Request # 36 | Downloading Intraday chart data for ESM21-CME to the file ESM21-CME.scid. Service: cme | 2021-05-04 16:40:04.921 HD Request # 36 | Download start date-time: 2021-05-04 16:39:51.000000. File last date-time: 2021-05-04 16:39:51.248000 | 2021-05-04 16:40:04.922 HD Request # 36 | Using server: ds21.sierracharts.com port 10149 | 2021-05-04 16:40:04.922 Socket (4) | Creating socket. | 2021-05-04 16:40:04.922 Socket (4) | New receive buffer size: 5242880 | 2021-05-04 16:40:04.922 Socket (4) | Connecting to IP: 216.1.90.129. | 2021-05-04 16:40:04.922 DTC Client socket (3) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 16:40:09.931 DTC Client socket (3) | Closed. | 2021-05-04 16:40:09.932 DTC Client socket (5) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-04 16:40:09.932 DTC Client socket (5) | Closed. | 2021-05-04 16:40:09.932 Socket (4) | CloseSocket call. | 2021-05-04 16:40:24.922 Socket (4) | Closed. | 2021-05-04 16:40:24.922 HD Request # 36 | Error downloading historical Intraday data for ESM21-CME. Timeout error connecting to server. | 2021-05-04 16:40:24.922 Added historical Intraday data request for ESM21-CME to the queue. | 2021-05-04 16:40:24.922 Triggering next historical data download in queue. | 2021-05-04 16:40:24.922 Historical data download thread signaled to stop. | 2021-05-04 16:40:24.922 HD Request # 36 | Received 0 records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for ESM21-CME | 2021-05-04 16:40:24.923 HD Request # 36 | Completion time: 20s | 2021-05-04 16:40:24.923 HD Request # 37 | Downloading Intraday chart data for ESM21-CME to the file ESM21-CME.scid. Service: cme | 2021-05-04 16:40:24.923 HD Request # 37 | Download start date-time: 2021-05-04 16:39:51.000000. File last date-time: 2021-05-04 16:39:51.248000 | 2021-05-04 16:40:24.923 HD Request # 37 | Using server: ds23.sierracharts.com port 10150 | 2021-05-04 16:40:24.923 Socket (4) | Creating socket. | 2021-05-04 16:40:24.923 Socket (4) | New receive buffer size: 5242880 | 2021-05-04 16:40:24.923 Socket (4) | Connecting to IP: 216.1.90.130. | 2021-05-04 16:40:24.923 HD Request # 37 | Setting DTC encoding to Binary VLS | 2021-05-04 16:40:25.185 HD Request # 37 | Sending historical data logon request message. | 2021-05-04 16:40:25.185 HD Request # 37 | Requesting Intraday data. Start date-time: 2021-05-04 16:39:51. Record interval: 0. Symbol: ESM21 | 2021-05-04 16:40:25.767 HD Request # 37 | Decompressing data. | 2021-05-04 16:40:25.886 HD Request # 37 | Receiving Intraday data for ESM21-CME starting at 2021-05-04 16:39:51.248000 | 2021-05-04 16:40:25.886 Socket (4) | CloseSocket call. | 2021-05-04 16:40:25.886 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-05-04 16:40:25.886 Historical data download thread signaled to stop. | 2021-05-04 16:40:25.886 HD Request # 37 | Timestamp of first Intraday data file record written: 2021-05-04 16:39:53.654000 | 2021-05-04 16:40:25.886 HD Request # 37 | Received 47 records from 2021-05-04 16:39:51.248000 to 2021-05-04 16:40:22.038000 (30.8 seconds) and wrote 46 records for ESM21-CME | 2021-05-04 16:40:25.886 HD Request # 37 | Add time&sales data | Remembered last file record date-time: 2021-05-04 20:40:22.038000 | 2021-05-04 16:40:25.887 Added 6 Time and Sales records to Intraday data file for ESM21-CME after download. | 2021-05-04 16:40:25.887 HD Request # 37 | Completion time: 1s | 2021-05-04 16:40:25.887 HD Request # 37 | Intraday data download complete for ESM21-CME. Unique request ID: 28 | 2021-05-04 16:40:25.887 Removing historical data download ID 28. | 2021-05-04 16:40:25.887 Real-time Intraday chart data file updates started for ESM21-CME | 2021-05-04 16:40:25.887 Intraday chart data file opened for ESM21-CME | 2021-05-04 16:40:25.887 HD Request # 37 | Enabling Intraday chart updating for symbol. | 2021-05-04 16:40:25.887 Triggering next historical data download in queue. | 2021-05-04 16:40:25.887 No download requests in the queue to start downloads for. | 2021-05-04 16:40:25.887 Socket (4) | Socket gracefully closed by remote side. | 2021-05-04 16:40:26.005 Socket (4) | Closed. | 2021-05-04 16:40:26.006 Opened cached Intraday file: C:\SierraChart\Data\ESM21-CME.scid. Thread ID: 21200 | 2021-05-04 16:40:30.414 |
[2021-05-04 20:47:46] |
You are getting the following error: HD Request # 36 | Error downloading historical Intraday data for ESM21-CME. Timeout error connecting to server.
Refer to the following: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Overview and Solutions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
