Date/Time: Sun, 28 Apr 2024 09:05:36 +0000
[Locked] - Notice: Denali Data Feed - Market By Order Changes (Full delivery down to quantity 2)
View Count: 4615
[2021-03-25 00:35:07] |
This thread will be about the process to deliver market by order data through the Denali Exchange Data Feed on a separate connection and provide all orders down to a quantity of 2. We will update this thread this week with our progress and provide instructions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-25 13:24:02] |
In order to begin to receive data on the new connection, it is necessary to be running prerelease 2243. The latest revision. Even if you have this version, install it again with Help >> Download Prerelease. It has this setting: Global Settings >> Sierra Chart Server Settings >>Use Separate Connection for Market by Order Data. This needs to be set to No for now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-19 03:34:43] |
We do apologize for the long delay with not getting this done sooner. Other development tasks had come up. We do have a lot of servers to configure for this. We are finishing with the remaining configuration, to move market by order data onto a separate connection.
[2021-05-24 21:21:52] |
We are planning the transition to the new connection for market by order data, and a reduction in the quantity down to 5, Thursday evening this week (2021-05-27). We will send out a notice to the user base. And once we are comfortable we can take this quantity down further. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-05-25 08:40:42
[2021-05-25 19:35:17] |
Sierra_Chart Engineering - Posts: 14111 |
We have completed additional testing related to this, and we continue to expect to release the market by order data on a new connection on Wednesday evening (2021-05-26). Therefore, to continue to access market by order data, you need to be running the current version. Update instructions: Software Download: Fast Update Effective 2021-05-26 at 17:00:00 (US Eastern time) or after, you will need to set Global Settings >> Sierra Chart Server Settings >> Use Separate Connection for Market by Order Data to Yes. And then reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers This needs to be done to continue to have access to the market by order data. We will also be lowering the minimum order quantity to be sent to 4 at this time. ----- To control the minimum order quantity received from the server and therefore displayed, refer to: Market By Order Data: Adjusting Minimum Quantity to Display for Market by Order Data Therefore, if the minimum quantity of 4 now is too low you can increase this. It is within your control always. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-05-28 20:15:12
[2021-05-26 14:38:42] |
One thing we want to make clear, is do not set Global Settings >> Sierra Chart Server Settings >> Use Separate Connection for Market by Order Data to Yes before 2021-05-26 at 17:00:00 (US Eastern time). This will cause unusual problems with receiving market data.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-05-26 22:06:03
[2021-05-26 21:50:26] |
We have changed the schedule, we have done the release of market by order data on a separate connection, effective this Wednesday (2021-05-26) at 17:40:00. So this is in effect now. We will be sending out a notice to users this evening shortly. We are monitoring the data feeds to make sure everything is working properly. If there is any issue we will revert back but we do not expect that. Make sure you are running a current version of Sierra Chart. Update instructions: Software Download: Fast Update You will need to set Global Settings >> Sierra Chart Server Settings >> Use Separate Connection for Market by Order Data to Yes. And then reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers This needs to be done to continue to have access to the market by order data. We have also lowered the minimum order quantity to be sent to 4 at this time. To control the minimum order quantity received from the server and therefore displayed, refer to: Market By Order Data: Adjusting Minimum Quantity to Display for Market by Order Data Therefore, if the minimum quantity of 4 now is too low you can increase this. It is within your control always. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-05-28 20:13:48
