Date/Time: Sat, 18 May 2024 21:05:54 +0000
CQG or Sierra data feed
View Count: 447
[2021-03-10 13:30:39] |
User328051 - Posts: 4 |
Hello, I am currently set up with AMP futures and tried to use rithmic with sierra chart but it did not work. I am now trying to switch to either CQG web API or Sierra's order routing service. Firstly is Sierra's order routing service avaliable with AMP? Secondly, are the issues with CQG I've read about still a thing In 2021? Thank you very much, Nathan |
[2021-03-10 16:17:26] |
For the brokers that support the order routing service, refer to step two here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions CQG is fine for order routing except Sierra Chart does not support server-side bracket orders with CQG but for market data we strongly recommend you use our Denali Exchange Data Feed: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
