Date/Time: Sat, 04 May 2024 09:58:24 +0000
Ninjatrader and Sierrachart
View Count: 688
[2021-03-01 22:05:08] |
User562481 - Posts: 3 |
Hi, I need to connect Sierra Chart with Ninja Trader in order to view futures data on Sierra Chart with the CQG connection I have through Ninja Trader. Thanks |
[2021-03-01 22:18:13] |
We definitely do not recommend this method. Refer to: Using Sierra Chart with Ninja Trader Brokerage You will want to use the Denali Exchange Data Feed for data: Denali Exchange Data Feed You can still use CQG to verify you have a trading account to meet CME data requirements. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-01 22:23:24
[2021-04-16 16:32:07] |
Vlion333 - Posts: 1 |
along these lines but opposite in function .... is there a way to use sierra charts with denali feed and allow ninjatrader platform to access the denali data feed? thank you in advance on pointing out any direction to do this. |
[2021-04-16 19:27:45] |
John - SC Support - Posts: 31362 |
There is not a way to do what you propose. The Sierra Chart data feeds (including the Denali Exchange Data Feed) only work with Sierra Chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
