Date/Time: Sat, 18 May 2024 06:48:37 +0000
Keep Text on right of screen
View Count: 734
[2021-02-23 11:25:04] |
58LesPaul - Posts: 429 |
I am using Daily OHLC to mark the last few days high and low on the 5 minute chart and use type text to label them Yesterday's High, Yesterdays Low, etc. Is there any way to keep that text on the right(or left) side of the screen as the chart scrolls? If not, could this be implemented? Thanks |
[2021-02-23 14:59:28] |
User459170 - Posts: 262 |
Hope this helps. Chart Studies: Subgraphs Tab >> Name and Value Labels
[2021-02-24 16:55:22] |
Have a look at the Stationary Text Tool: Chart Drawing Tools: Type Text | Stationary Text Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-24 16:55:53
[2021-02-24 21:15:11] |
I tried stationary text but it stayed with the time it was set in and scrolled to the left as the chart progressed. It worked with the name value labels in the Daily OHLC study but it will only display high and low, not yesterday’s high and so on. But I can work with that. Thanks |
[2021-02-24 21:16:16] |
[Hope this helps. Chart Studies: Subgraphs Tab >> Name and Value Labels] That works, thanks! |
[2021-02-25 04:38:24] |
Configure the Daily OHLC to reference back (Reference Days Back) 1 or more days , then you will get yesterday's high and low. Daily OHLC: Inputs Date Time Of Last Edit: 2021-02-25 04:39:34
[2021-02-25 09:32:14] |
I'm referring to the text as "yesterday's high", I have the line for yesterdays high but it just labels it as a high and I was wanting it labeled as Yesterday's High. |
[2021-02-25 15:15:41] |
Refer to this setting: Chart Studies: Subgraphs Tab >> Label For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-25 15:46:35] |
Chart Studies: Subgraphs Tab >> Label I was wondering this morning if that would do it, thanks. This program can do everything! |
