Date/Time: Wed, 04 Nov 2026 14:21:26 +0000
New Account data activation
View Count: 1050
[2021-02-15 16:30:35]
User946075 - Posts: 8
Hi - I am working with Earn2Trade Gauntlet mini to become a funded trader. They require I use Rithmic data. I created a Direct Sierra Chart Account, purchased the advanced service package 5, downloaded the Rithmic Zip file and logged into my Rithmic Data feed in my new account. However, I'm getting a "Connection error message from service: Rithmic Trading|Logon error received from server" when attempting to sign into my account. Can you please provide additional guidance how I can connect my data feed?
[2021-02-17 06:14:32]
Here is an Excerpt of the log.
Rithmic Trading | Port for executable: 51688 | 2021-02-17 00:10:34.238
Listening socket (1984). Port 51688 | Closed. | 2021-02-17 00:10:34.238
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2021-02-17 00:10:34.238
Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2021-02-17 00:10:34.249
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-02-17 00:10:34.927 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-02-17 00:10:34.927
DTC Client socket (1) | Closed. | 2021-02-17 00:10:34.927
Rithmic Trading | Bridge process is not running! | 2021-02-17 00:10:36.246
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51688 | 2021-02-17 00:10:36.246
DTC Client socket (1) | Creating socket. | 2021-02-17 00:10:36.246
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-02-17 00:10:36.246
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-02-17 00:10:36.246
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-02-17 00:10:38.265 *
DTC Client socket (1) | CloseSocket call. | 2021-02-17 00:10:38.265
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-17 00:10:38.265
DTC Client socket (1) | Closed. | 2021-02-17 00:10:38.265
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-17 00:10:38.265
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 00:10:38.265
DTC Client socket (0) | CloseSocket call. | 2021-02-17 00:10:38.281
Rithmic Trading | Disconnected. | 2021-02-17 00:10:38.281
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 00:10:38.281
[2021-02-17 14:29:31]
User384094 - Posts: 1
I have exactly the same problem trying to connect myy AMP futures account
Log is attached
imageScreenshot_ Login error data feed.png / V - Attached On 2021-02-17 14:28:12 UTC - Size: 56.52 KB - 358 views
[2021-02-17 18:06:49]
RE: post #3 - User384094, Looks like to me your issue may be a little different. Looking at your error log it looks like you need to download and install the Rithmic Bridge files here Rithmic Bridge Files and install in your C:\SierraChart\Rim folder.
[2021-02-17 23:36:13]
We apologize for the delay with the response.
Regarding the log in post #2 and the connectivity issue, we need to see the entire Message Log. Not a portion. That portion does not show what we need to see. See the instructions below.
Regarding post #3, you do need to install bridge files and those can be downloaded from here:
Reconnect to the data feed:
[2021-02-18 01:19:34]
Here is the entire log:
Software version: 2230 64-bit | 2021-02-17 19:15:23.176
Primary Thread ID: 19628 | 2021-02-17 19:15:23.176
Usage end date: 2021-03-30 | 2021-02-17 19:15:23.176
Enabled for: Advanced Features 2. | 2021-02-17 19:15:23.176
Enabled for: Sierra Chart Historical Data Service. | 2021-02-17 19:15:23.176
Enabled for: Delayed Denali Exchange Data Feed. | 2021-02-17 19:15:23.176
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-02-17 19:15:23.176
Current selected Data/Trading service: Rithmic Trading | 2021-02-17 19:15:23.176
Custom symbol settings values: enabled | 2021-02-17 19:15:23.176
Chart Update Interval: 200 | 2021-02-17 19:15:23.176
Intraday Data Storage Time Unit: 0 | 2021-02-17 19:15:23.176
Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-02-17 19:15:23.176
2021-02-18 01:15:23 Local computer time in UTC | 2021-02-17 19:15:23.176
2021-02-17 19:15:23 Local computer time in SC Time Zone | 2021-02-17 19:15:23.176
2021-02-18 01:12:12 Server time in UTC | 2021-02-17 19:15:23.176
Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-02-17 19:15:23.176
Program path: C:\SierraChart\ | 2021-02-17 19:15:23.176
Data Files path: C:\SierraChart\Data\ | 2021-02-17 19:15:23.176
OS Version Number: 10.0 | 2021-02-17 19:15:23.176
Locale Setting: C | 2021-02-17 19:15:23.176
DLLs: CumulativeDeltaDifference_64.dll, DeltaAboveBelowPrice_64.dll, EdgeTradingGroup.dll, EdgeTradingGroup_64.dll, ETG Audio.dll, ETOFSv3.dll, ETOFSv3_64.dll, openal32.dll, sst_FreeBundle.dll, sst_FreeBundle_2151.dll, sst_FreeBundle_2151_64.dll, sst_FreeBundle_64.dll, sst_michael_spilman.dll, sst_michael_spilman_2151_64.dll, sst_michael_spilman_64.dll, sst_recent_traded_volume_values.dll, sst_recent_traded_volume_values_64.dll, sst_renko_optimize.dll, sst_renko_optimize_64.dll, sst_speed_blocks.dll, sst_speed_blocks_2151.dll | 2021-02-17 19:15:23.177
Allowed protected custom studies: | 2021-02-17 19:15:23.177
Rithmic Trading | Port for executable: 61000 | 2021-02-17 19:16:43.698
Listening socket (1476). Port 61000 | Closed. | 2021-02-17 19:16:43.698
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2021-02-17 19:16:43.699
Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2021-02-17 19:16:43.728
Rithmic Trading | Bridge process is running. | 2021-02-17 19:16:45.733
Rithmic Trading | Connecting to the server 127.0.0.1. Port 61000 | 2021-02-17 19:16:45.733
DTC Client socket (1) | Creating socket. | 2021-02-17 19:16:45.734
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-02-17 19:16:45.734
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-02-17 19:16:45.734
Rithmic Trading | Network connection to server complete. | 2021-02-17 19:16:45.735
Rithmic Trading | Starting socket receive thread. | 2021-02-17 19:16:45.735
Rithmic Trading | Sending encoding request to server: Binary VLS. Compression: none | 2021-02-17 19:16:45.736
Rithmic Trading | Setting DTC encoding to Binary VLS | 2021-02-17 19:16:45.736
Rithmic Trading | Sending logon request message. | 2021-02-17 19:16:45.736
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2021-02-17 19:16:45.738
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2021-02-17 19:16:45.740
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2021-02-17 19:16:45.740
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2021-02-17 19:16:46.024
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2021-02-17 19:16:46.055
Rithmic Trading | Received logon response. | 2021-02-17 19:16:46.056
Rithmic Trading | Server Name: DTC Bridge. | 2021-02-17 19:16:46.056
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2021-02-17 19:16:46.056
Rithmic Trading | Logon error received from server | 2021-02-17 19:16:46.056
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-17 19:16:46.056
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:16:46.056
Rithmic Trading | Waiting for socket receive thread to end | 2021-02-17 19:16:46.085
DTC Client socket (1) | CloseSocket call. | 2021-02-17 19:16:46.085
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-17 19:16:46.085
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-02-17 19:16:46.085
Rithmic Trading | Disconnected. | 2021-02-17 19:16:46.085
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:16:46.085
Rithmic Trading | Port for executable: 61010 | 2021-02-17 19:16:48.075
Listening socket (1204). Port 61010 | Closed. | 2021-02-17 19:16:48.075
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2021-02-17 19:16:48.076
Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2021-02-17 19:16:48.085
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-02-17 19:16:48.779 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-02-17 19:16:48.779
DTC Client socket (1) | Closed. | 2021-02-17 19:16:48.779
Rithmic Trading | Bridge process is not running! | 2021-02-17 19:16:50.090
Rithmic Trading | Connecting to the server 127.0.0.1. Port 61010 | 2021-02-17 19:16:50.090
DTC Client socket (1) | Creating socket. | 2021-02-17 19:16:50.090
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-02-17 19:16:50.090
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-02-17 19:16:50.091
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-02-17 19:16:52.128 *
DTC Client socket (1) | CloseSocket call. | 2021-02-17 19:16:52.128
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-17 19:16:52.128
DTC Client socket (1) | Closed. | 2021-02-17 19:16:52.128
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-17 19:16:52.128
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:16:52.128
DTC Client socket (0) | CloseSocket call. | 2021-02-17 19:16:52.144
Rithmic Trading | Disconnected. | 2021-02-17 19:16:52.144
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:16:52.144
Rithmic Trading | Port for executable: 61012 | 2021-02-17 19:16:54.156
Listening socket (1544). Port 61012 | Closed. | 2021-02-17 19:16:54.156
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2021-02-17 19:16:54.156
Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2021-02-17 19:16:54.165
Rithmic Trading | Bridge process is running. | 2021-02-17 19:16:56.150
Rithmic Trading | Connecting to the server 127.0.0.1. Port 61012 | 2021-02-17 19:16:56.150
DTC Client socket (1) | Creating socket. | 2021-02-17 19:16:56.150
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-02-17 19:16:56.150
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-02-17 19:16:56.150
Rithmic Trading | Network connection to server complete. | 2021-02-17 19:16:56.152
Rithmic Trading | Starting socket receive thread. | 2021-02-17 19:16:56.152
Rithmic Trading | Sending encoding request to server: Binary VLS. Compression: none | 2021-02-17 19:16:56.152
Rithmic Trading | Setting DTC encoding to Binary VLS | 2021-02-17 19:16:56.154
Rithmic Trading | Sending logon request message. | 2021-02-17 19:16:56.154
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2021-02-17 19:16:56.155
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2021-02-17 19:16:56.158
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2021-02-17 19:16:56.158
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2021-02-17 19:16:56.478
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2021-02-17 19:16:56.516
Rithmic Trading | Received logon response. | 2021-02-17 19:16:56.516
Rithmic Trading | Server Name: DTC Bridge. | 2021-02-17 19:16:56.516
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2021-02-17 19:16:56.516
Rithmic Trading | Logon error received from server | 2021-02-17 19:16:56.516
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-17 19:16:56.516
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:16:56.516
Rithmic Trading | Waiting for socket receive thread to end | 2021-02-17 19:16:56.539
DTC Client socket (1) | CloseSocket call. | 2021-02-17 19:16:56.540
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-17 19:16:56.540
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-02-17 19:16:56.540
Rithmic Trading | Disconnected. | 2021-02-17 19:16:56.540
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:16:56.540
Rithmic Trading | Port for executable: 61022 | 2021-02-17 19:16:58.545
Listening socket (1204). Port 61022 | Closed. | 2021-02-17 19:16:58.545
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2021-02-17 19:16:58.546
Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2021-02-17 19:16:58.555
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-02-17 19:16:59.219 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-02-17 19:16:59.219
DTC Client socket (1) | Closed. | 2021-02-17 19:16:59.219
Rithmic Trading | Bridge process is not running! | 2021-02-17 19:17:00.551
Rithmic Trading | Connecting to the server 127.0.0.1. Port 61022 | 2021-02-17 19:17:00.551
DTC Client socket (1) | Creating socket. | 2021-02-17 19:17:00.551
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-02-17 19:17:00.552
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-02-17 19:17:00.552
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-02-17 19:17:02.591 *
DTC Client socket (1) | CloseSocket call. | 2021-02-17 19:17:02.591
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-17 19:17:02.591
DTC Client socket (1) | Closed. | 2021-02-17 19:17:02.591
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-17 19:17:02.591
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:17:02.591
DTC Client socket (0) | CloseSocket call. | 2021-02-17 19:17:02.606
Rithmic Trading | Disconnected. | 2021-02-17 19:17:02.606
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:17:02.606
Rithmic Trading | Port for executable: 61026 | 2021-02-17 19:17:04.612
Listening socket (1204). Port 61026 | Closed. | 2021-02-17 19:17:04.612
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2021-02-17 19:17:04.613
Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2021-02-17 19:17:04.627
Rithmic Trading | Bridge process is running. | 2021-02-17 19:17:06.638
Rithmic Trading | Connecting to the server 127.0.0.1. Port 61026 | 2021-02-17 19:17:06.638
DTC Client socket (1) | Creating socket. | 2021-02-17 19:17:06.639
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-02-17 19:17:06.639
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-02-17 19:17:06.639
Rithmic Trading | Network connection to server complete. | 2021-02-17 19:17:06.642
Rithmic Trading | Starting socket receive thread. | 2021-02-17 19:17:06.642
Rithmic Trading | Sending encoding request to server: Binary VLS. Compression: none | 2021-02-17 19:17:06.642
Rithmic Trading | Setting DTC encoding to Binary VLS | 2021-02-17 19:17:06.643
Rithmic Trading | Sending logon request message. | 2021-02-17 19:17:06.643
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2021-02-17 19:17:06.644
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2021-02-17 19:17:06.646
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2021-02-17 19:17:06.647
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2021-02-17 19:17:06.914
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2021-02-17 19:17:06.952
Rithmic Trading | Received logon response. | 2021-02-17 19:17:06.953
Rithmic Trading | Server Name: DTC Bridge. | 2021-02-17 19:17:06.953
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2021-02-17 19:17:06.953
Rithmic Trading | Logon error received from server | 2021-02-17 19:17:06.953
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-17 19:17:06.953
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:17:06.953
Rithmic Trading | Waiting for socket receive thread to end | 2021-02-17 19:17:06.967
DTC Client socket (1) | CloseSocket call. | 2021-02-17 19:17:06.968
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-17 19:17:06.968
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-02-17 19:17:06.968
Rithmic Trading | Disconnected. | 2021-02-17 19:17:06.968
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:17:06.968
Rithmic Trading | Port for executable: 61038 | 2021-02-17 19:17:08.979
Listening socket (1524). Port 61038 | Closed. | 2021-02-17 19:17:08.979
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2021-02-17 19:17:08.979
Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2021-02-17 19:17:08.989
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-02-17 19:17:09.683 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-02-17 19:17:09.683
DTC Client socket (1) | Closed. | 2021-02-17 19:17:09.683
Rithmic Trading | Bridge process is not running! | 2021-02-17 19:17:11.000
Rithmic Trading | Connecting to the server 127.0.0.1. Port 61038 | 2021-02-17 19:17:11.000
DTC Client socket (1) | Creating socket. | 2021-02-17 19:17:11.000
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-02-17 19:17:11.000
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-02-17 19:17:11.000
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-02-17 19:17:13.038 *
DTC Client socket (1) | CloseSocket call. | 2021-02-17 19:17:13.039
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-17 19:17:13.039
DTC Client socket (1) | Closed. | 2021-02-17 19:17:13.039
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-17 19:17:13.039
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:17:13.039
DTC Client socket (0) | CloseSocket call. | 2021-02-17 19:17:13.054
Rithmic Trading | Disconnected. | 2021-02-17 19:17:13.054
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:17:13.054
Rithmic Trading | Port for executable: 61041 | 2021-02-17 19:17:15.059
Listening socket (1552). Port 61041 | Closed. | 2021-02-17 19:17:15.059
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2021-02-17 19:17:15.060
Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2021-02-17 19:17:15.070
Rithmic Trading | Bridge process is running. | 2021-02-17 19:17:17.070
Rithmic Trading | Connecting to the server 127.0.0.1. Port 61041 | 2021-02-17 19:17:17.070
DTC Client socket (1) | Creating socket. | 2021-02-17 19:17:17.070
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-02-17 19:17:17.070
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-02-17 19:17:17.070
Rithmic Trading | Network connection to server complete. | 2021-02-17 19:17:17.071
Rithmic Trading | Starting socket receive thread. | 2021-02-17 19:17:17.071
Rithmic Trading | Sending encoding request to server: Binary VLS. Compression: none | 2021-02-17 19:17:17.071
Rithmic Trading | Setting DTC encoding to Binary VLS | 2021-02-17 19:17:17.072
Rithmic Trading | Sending logon request message. | 2021-02-17 19:17:17.072
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2021-02-17 19:17:17.074
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2021-02-17 19:17:17.076
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2021-02-17 19:17:17.076
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2021-02-17 19:17:17.311
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2021-02-17 19:17:17.339
Rithmic Trading | Received logon response. | 2021-02-17 19:17:17.340
Rithmic Trading | Server Name: DTC Bridge. | 2021-02-17 19:17:17.340
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2021-02-17 19:17:17.340
Rithmic Trading | Logon error received from server | 2021-02-17 19:17:17.340
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-17 19:17:17.340
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:17:17.340
Rithmic Trading | Waiting for socket receive thread to end | 2021-02-17 19:17:17.365
DTC Client socket (1) | CloseSocket call. | 2021-02-17 19:17:17.366
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-17 19:17:17.366
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-02-17 19:17:17.366
Rithmic Trading | Disconnected. | 2021-02-17 19:17:17.366
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:17:17.366
Rithmic Trading | Port for executable: 61051 | 2021-02-17 19:17:19.357
Listening socket (1552). Port 61051 | Closed. | 2021-02-17 19:17:19.357
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2021-02-17 19:17:19.358
Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2021-02-17 19:17:19.368
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-02-17 19:17:20.122 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-02-17 19:17:20.122
DTC Client socket (1) | Closed. | 2021-02-17 19:17:20.122
Rithmic Trading | Bridge process is not running! | 2021-02-17 19:17:21.374
Rithmic Trading | Connecting to the server 127.0.0.1. Port 61051 | 2021-02-17 19:17:21.374
DTC Client socket (1) | Creating socket. | 2021-02-17 19:17:21.374
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-02-17 19:17:21.374
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-02-17 19:17:21.374
File >> Disconnect selected. | 2021-02-17 19:17:22.685
DTC Client socket (1) | CloseSocket call. | 2021-02-17 19:17:22.685
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-17 19:17:22.685
Rithmic Trading | Disconnected. | 2021-02-17 19:17:22.685
DTC Client socket (1) | Closed. | 2021-02-17 19:17:22.685
[2021-02-18 01:59:37]
Update to post #6: I believe the issue with getting this error message ("Connection error message from service: Rithmic Trading|Logon error received from server") was an attempt to Log into the wrong server. I switched the server to "Paper Trading Server" which from speaking with Earn2Trade is the correct server to log into and I was able to successfully Connect. However, now I'm having a different issue. The connection to that server connects then disconnects over and over again. The connection wont stabilize. I'm providing the error log for this new connection issue below:
Software version: 2230 64-bit | 2021-02-17 19:48:10.444
Primary Thread ID: 8660 | 2021-02-17 19:48:10.444
Usage end date: 2021-03-30 | 2021-02-17 19:48:10.444
Enabled for: Advanced Features 2. | 2021-02-17 19:48:10.444
Enabled for: Sierra Chart Historical Data Service. | 2021-02-17 19:48:10.444
Enabled for: Delayed Denali Exchange Data Feed. | 2021-02-17 19:48:10.444
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-02-17 19:48:10.444
Current selected Data/Trading service: Rithmic Trading | 2021-02-17 19:48:10.444
Custom symbol settings values: enabled | 2021-02-17 19:48:10.444
Chart Update Interval: 200 | 2021-02-17 19:48:10.445
Intraday Data Storage Time Unit: 0 | 2021-02-17 19:48:10.445
Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-02-17 19:48:10.445
2021-02-18 01:48:10 Local computer time in UTC | 2021-02-17 19:48:10.445
2021-02-17 19:48:10 Local computer time in SC Time Zone | 2021-02-17 19:48:10.445
2021-02-18 01:29:23 Server time in UTC | 2021-02-17 19:48:10.445
Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-02-17 19:48:10.445
Program path: C:\SierraChart\ | 2021-02-17 19:48:10.445
Data Files path: C:\SierraChart\Data\ | 2021-02-17 19:48:10.445
OS Version Number: 10.0 | 2021-02-17 19:48:10.445
Locale Setting: C | 2021-02-17 19:48:10.445
DLLs: CumulativeDeltaDifference_64.dll, DeltaAboveBelowPrice_64.dll, EdgeTradingGroup.dll, EdgeTradingGroup_64.dll, ETG Audio.dll, ETOFSv3.dll, ETOFSv3_64.dll, openal32.dll, sst_FreeBundle.dll, sst_FreeBundle_2151.dll, sst_FreeBundle_2151_64.dll, sst_FreeBundle_64.dll, sst_michael_spilman.dll, sst_michael_spilman_2151_64.dll, sst_michael_spilman_64.dll, sst_recent_traded_volume_values.dll, sst_recent_traded_volume_values_64.dll, sst_renko_optimize.dll, sst_renko_optimize_64.dll, sst_speed_blocks.dll, sst_speed_blocks_2151.dll | 2021-02-17 19:48:10.446
Allowed protected custom studies: | 2021-02-17 19:48:10.446
Rithmic Trading | Port for executable: 61980 | 2021-02-17 19:49:06.663
Listening socket (1788). Port 61980 | Closed. | 2021-02-17 19:49:06.663
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2021-02-17 19:49:06.664
Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2021-02-17 19:49:06.678
Rithmic Trading | Bridge process is running. | 2021-02-17 19:49:08.670
Rithmic Trading | Connecting to the server 127.0.0.1. Port 61980 | 2021-02-17 19:49:08.670
DTC Client socket (1) | Creating socket. | 2021-02-17 19:49:08.670
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-02-17 19:49:08.670
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-02-17 19:49:08.670
Rithmic Trading | Network connection to server complete. | 2021-02-17 19:49:08.676
Rithmic Trading | Starting socket receive thread. | 2021-02-17 19:49:08.676
Rithmic Trading | Sending encoding request to server: Binary VLS. Compression: none | 2021-02-17 19:49:08.676
Rithmic Trading | Setting DTC encoding to Binary VLS | 2021-02-17 19:49:08.677
Rithmic Trading | Sending logon request message. | 2021-02-17 19:49:08.677
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2021-02-17 19:49:08.678
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2021-02-17 19:49:08.680
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2021-02-17 19:49:08.681
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2021-02-17 19:49:08.929
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2021-02-17 19:49:08.996
Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2021-02-17 19:49:09.099
Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2021-02-17 19:49:09.228
Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2021-02-17 19:49:09.257
Rithmic Trading | Message from server: subscribeTradeRoute error. Error code: API_ALREADY_EXISTS | 2021-02-17 19:49:09.269
Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2021-02-17 19:49:09.302
Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2021-02-17 19:49:09.400
Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2021-02-17 19:49:09.445
Rithmic Trading | Received logon response. | 2021-02-17 19:49:09.689
Rithmic Trading | Server Name: SC DTC Bridge. | 2021-02-17 19:49:09.689
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2021-02-17 19:49:09.689
Rithmic Trading | Successfully connected. IB='Earn2Trade', Firm='Earn2Trade'. | 2021-02-17 19:49:09.689
Rithmic Trading | Trading is supported. | 2021-02-17 19:49:09.689
Rithmic Trading | Order cancel and replace is supported. | 2021-02-17 19:49:09.689
Rithmic Trading | OCO Orders supported. | 2021-02-17 19:49:09.689
Rithmic Trading | Connected to server complete. | 2021-02-17 19:49:09.689
Triggering next historical data download in queue. | 2021-02-17 19:49:09.689
No download requests in the queue to start downloads for. | 2021-02-17 19:49:09.689
Rithmic Trading | Message from server: Received unknown message type from DTC client. Type = 603 | 2021-02-17 19:49:10.386
Rithmic Trading | Message from server: Received unknown message type from DTC client. Type = 603 | 2021-02-17 19:49:11.078
Rithmic Trading | Message from server: Server Alert: Received logout message - logging out. | 2021-02-17 19:49:11.792
Rithmic Trading | Message from server: Deleting API object. | 2021-02-17 19:49:11.793
Rithmic Trading | Message from server: Server Alert: Intraday History Connection Closed | 2021-02-17 19:49:11.793
Rithmic Trading | Message from server: Server Alert: PnL Connection Closed | 2021-02-17 19:49:11.795
Rithmic Trading | Message from server: Server Alert: Trading System Connection Closed | 2021-02-17 19:49:11.799
Rithmic Trading | Message from server: Server Alert: Market Data Connection Closed | 2021-02-17 19:49:11.801
DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-02-17 19:49:11.821
DTC Client socket (1) | CloseSocket call. | 2021-02-17 19:49:11.822
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-17 19:49:11.822
DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-17 19:49:11.822
DTC Client socket (1) | Closed. | 2021-02-17 19:49:11.822
Connection to the external service has been lost. | 2021-02-17 19:49:11.822
Rithmic Trading | Waiting for socket receive thread to end | 2021-02-17 19:49:11.847
DTC Client socket (0) | CloseSocket call. | 2021-02-17 19:49:11.847
Rithmic Trading | Disconnected. | 2021-02-17 19:49:11.847
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:49:11.847
Rithmic Trading | Port for executable: 62006 | 2021-02-17 19:49:13.841
Listening socket (1788). Port 62006 | Closed. | 2021-02-17 19:49:13.841
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2021-02-17 19:49:13.842
Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2021-02-17 19:49:13.852
Rithmic Trading | Bridge process is not running! | 2021-02-17 19:49:15.843
Rithmic Trading | Connecting to the server 127.0.0.1. Port 62006 | 2021-02-17 19:49:15.843
DTC Client socket (1) | Creating socket. | 2021-02-17 19:49:15.843
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-02-17 19:49:15.843
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-02-17 19:49:15.843
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-02-17 19:49:17.875 *
DTC Client socket (1) | CloseSocket call. | 2021-02-17 19:49:17.875
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-17 19:49:17.875
DTC Client socket (1) | Closed. | 2021-02-17 19:49:17.875
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-17 19:49:17.875
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:49:17.875
DTC Client socket (0) | CloseSocket call. | 2021-02-17 19:49:17.892
Rithmic Trading | Disconnected. | 2021-02-17 19:49:17.892
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:49:17.892
Rithmic Trading | Port for executable: 62008 | 2021-02-17 19:49:19.888
Listening socket (756). Port 62008 | Closed. | 2021-02-17 19:49:19.888
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2021-02-17 19:49:19.888
Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2021-02-17 19:49:19.899
Rithmic Trading | Bridge process is not running! | 2021-02-17 19:49:21.893
Rithmic Trading | Connecting to the server 127.0.0.1. Port 62008 | 2021-02-17 19:49:21.893
DTC Client socket (1) | Creating socket. | 2021-02-17 19:49:21.893
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-02-17 19:49:21.893
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-02-17 19:49:21.893
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-02-17 19:49:23.954 *
DTC Client socket (1) | CloseSocket call. | 2021-02-17 19:49:23.955
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-17 19:49:23.955
DTC Client socket (1) | Closed. | 2021-02-17 19:49:23.955
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-17 19:49:23.955
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:49:23.955
DTC Client socket (0) | CloseSocket call. | 2021-02-17 19:49:23.971
Rithmic Trading | Disconnected. | 2021-02-17 19:49:23.971
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:49:23.971
Rithmic Trading | Port for executable: 62012 | 2021-02-17 19:49:25.970
Listening socket (1788). Port 62012 | Closed. | 2021-02-17 19:49:25.970
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2021-02-17 19:49:25.971
Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2021-02-17 19:49:25.981
Rithmic Trading | Bridge process is not running! | 2021-02-17 19:49:27.986
Rithmic Trading | Connecting to the server 127.0.0.1. Port 62012 | 2021-02-17 19:49:27.986
DTC Client socket (3) | Creating socket. | 2021-02-17 19:49:27.986
DTC Client socket (3) | New receive buffer size: 5242880 | 2021-02-17 19:49:27.986
DTC Client socket (3) | Connecting to IP: 127.0.0.1. | 2021-02-17 19:49:27.986
DTC Client socket (3) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-02-17 19:49:30.023 *
DTC Client socket (3) | CloseSocket call. | 2021-02-17 19:49:30.023
DTC Client socket (3) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-17 19:49:30.023
DTC Client socket (3) | Closed. | 2021-02-17 19:49:30.023
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-17 19:49:30.023
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:49:30.023
DTC Client socket (0) | CloseSocket call. | 2021-02-17 19:49:30.039
Rithmic Trading | Disconnected. | 2021-02-17 19:49:30.039
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:49:30.039
Rithmic Trading | Port for executable: 62014 | 2021-02-17 19:49:32.048
Listening socket (1712). Port 62014 | Closed. | 2021-02-17 19:49:32.048
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2021-02-17 19:49:32.049
Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2021-02-17 19:49:32.058
Rithmic Trading | Bridge process is running. | 2021-02-17 19:49:34.065
Rithmic Trading | Connecting to the server 127.0.0.1. Port 62014 | 2021-02-17 19:49:34.065
DTC Client socket (2) | Creating socket. | 2021-02-17 19:49:34.066
DTC Client socket (2) | New receive buffer size: 5242880 | 2021-02-17 19:49:34.066
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2021-02-17 19:49:34.066
Rithmic Trading | Network connection to server complete. | 2021-02-17 19:49:34.067
Rithmic Trading | Starting socket receive thread. | 2021-02-17 19:49:34.067
Rithmic Trading | Sending encoding request to server: Binary VLS. Compression: none | 2021-02-17 19:49:34.067
Rithmic Trading | Setting DTC encoding to Binary VLS | 2021-02-17 19:49:34.068
Rithmic Trading | Sending logon request message. | 2021-02-17 19:49:34.068
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2021-02-17 19:49:34.070
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2021-02-17 19:49:34.072
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2021-02-17 19:49:34.072
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2021-02-17 19:49:34.699
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2021-02-17 19:49:34.790
Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2021-02-17 19:49:34.988
Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2021-02-17 19:49:35.075
Rithmic Trading | Message from server: subscribeTradeRoute error. Error code: API_ALREADY_EXISTS | 2021-02-17 19:49:35.351
Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2021-02-17 19:49:35.729
Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2021-02-17 19:49:35.836
Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2021-02-17 19:49:36.335
Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2021-02-17 19:49:36.603
Rithmic Trading | Received logon response. | 2021-02-17 19:49:37.067
Rithmic Trading | Server Name: SC DTC Bridge. | 2021-02-17 19:49:37.067
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2021-02-17 19:49:37.067
Rithmic Trading | Successfully connected. IB='Earn2Trade', Firm='Earn2Trade'. | 2021-02-17 19:49:37.067
Rithmic Trading | Trading is supported. | 2021-02-17 19:49:37.067
Rithmic Trading | Order cancel and replace is supported. | 2021-02-17 19:49:37.067
Rithmic Trading | OCO Orders supported. | 2021-02-17 19:49:37.067
Rithmic Trading | Connected to server complete. | 2021-02-17 19:49:37.067
Triggering next historical data download in queue. | 2021-02-17 19:49:37.067
No download requests in the queue to start downloads for. | 2021-02-17 19:49:37.067
No download requests in the queue to start downloads for. | 2021-02-17 19:49:37.068
Rithmic Trading | Message from server: Received unknown message type from DTC client. Type = 603 | 2021-02-17 19:49:37.757
Rithmic Trading | Message from server: Received unknown message type from DTC client. Type = 603 | 2021-02-17 19:49:38.446
Rithmic Trading | Message from server: Server Alert: Received logout message - logging out. | 2021-02-17 19:49:44.109
Rithmic Trading | Message from server: Deleting API object. | 2021-02-17 19:49:44.110
Rithmic Trading | Message from server: Server Alert: Intraday History Connection Closed | 2021-02-17 19:49:44.110
Rithmic Trading | Message from server: Server Alert: PnL Connection Closed | 2021-02-17 19:49:44.112
Rithmic Trading | Message from server: Server Alert: Trading System Connection Closed | 2021-02-17 19:49:44.115
Rithmic Trading | Message from server: Server Alert: Market Data Connection Closed | 2021-02-17 19:49:44.118
DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-02-17 19:49:44.137
DTC Client socket (2) | CloseSocket call. | 2021-02-17 19:49:44.138
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-17 19:49:44.138
DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-17 19:49:44.138
DTC Client socket (2) | Closed. | 2021-02-17 19:49:44.138
Connection to the external service has been lost. | 2021-02-17 19:49:44.138
Rithmic Trading | Waiting for socket receive thread to end | 2021-02-17 19:49:44.161
DTC Client socket (0) | CloseSocket call. | 2021-02-17 19:49:44.161
Rithmic Trading | Disconnected. | 2021-02-17 19:49:44.161
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:49:44.161
Rithmic Trading | Port for executable: 62043 | 2021-02-17 19:49:46.183
Listening socket (1244). Port 62043 | Closed. | 2021-02-17 19:49:46.183
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2021-02-17 19:49:46.183
Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2021-02-17 19:49:46.193
Rithmic Trading | Bridge process is not running! | 2021-02-17 19:49:48.188
Rithmic Trading | Connecting to the server 127.0.0.1. Port 62043 | 2021-02-17 19:49:48.188
DTC Client socket (1) | Creating socket. | 2021-02-17 19:49:48.188
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-02-17 19:49:48.188
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-02-17 19:49:48.188
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-02-17 19:49:50.235 *
DTC Client socket (1) | CloseSocket call. | 2021-02-17 19:49:50.235
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-17 19:49:50.235
DTC Client socket (1) | Closed. | 2021-02-17 19:49:50.235
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-17 19:49:50.235
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:49:50.235
DTC Client socket (0) | CloseSocket call. | 2021-02-17 19:49:50.251
Rithmic Trading | Disconnected. | 2021-02-17 19:49:50.251
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:49:50.251
Rithmic Trading | Port for executable: 62045 | 2021-02-17 19:49:52.257
Listening socket (1244). Port 62045 | Closed. | 2021-02-17 19:49:52.257
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2021-02-17 19:49:52.258
Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2021-02-17 19:49:52.268
Rithmic Trading | Bridge process is not running! | 2021-02-17 19:49:54.270
Rithmic Trading | Connecting to the server 127.0.0.1. Port 62045 | 2021-02-17 19:49:54.270
DTC Client socket (1) | Creating socket. | 2021-02-17 19:49:54.270
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-02-17 19:49:54.271
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-02-17 19:49:54.271
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-02-17 19:49:56.317 *
DTC Client socket (1) | CloseSocket call. | 2021-02-17 19:49:56.317
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-17 19:49:56.317
DTC Client socket (1) | Closed. | 2021-02-17 19:49:56.317
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-17 19:49:56.317
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:49:56.317
DTC Client socket (0) | CloseSocket call. | 2021-02-17 19:49:56.333
Rithmic Trading | Disconnected. | 2021-02-17 19:49:56.333
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:49:56.333
Rithmic Trading | Port for executable: 62048 | 2021-02-17 19:49:58.335
Listening socket (1784). Port 62048 | Closed. | 2021-02-17 19:49:58.335
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2021-02-17 19:49:58.336
Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2021-02-17 19:49:58.350
Rithmic Trading | Bridge process is not running! | 2021-02-17 19:50:00.344
Rithmic Trading | Connecting to the server 127.0.0.1. Port 62048 | 2021-02-17 19:50:00.344
DTC Client socket (1) | Creating socket. | 2021-02-17 19:50:00.344
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-02-17 19:50:00.344
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-02-17 19:50:00.344
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-02-17 19:50:02.365 *
DTC Client socket (1) | CloseSocket call. | 2021-02-17 19:50:02.366
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-17 19:50:02.366
DTC Client socket (1) | Closed. | 2021-02-17 19:50:02.366
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-02-17 19:50:02.366
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:50:02.366
DTC Client socket (0) | CloseSocket call. | 2021-02-17 19:50:02.381
Rithmic Trading | Disconnected. | 2021-02-17 19:50:02.382
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:50:02.382
Rithmic Trading | Port for executable: 62050 | 2021-02-17 19:50:04.376
Listening socket (1756). Port 62050 | Closed. | 2021-02-17 19:50:04.376
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2021-02-17 19:50:04.377
Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2021-02-17 19:50:04.387
Rithmic Trading | Bridge process is running. | 2021-02-17 19:50:06.394
Rithmic Trading | Connecting to the server 127.0.0.1. Port 62050 | 2021-02-17 19:50:06.394
DTC Client socket (1) | Creating socket. | 2021-02-17 19:50:06.394
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-02-17 19:50:06.394
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-02-17 19:50:06.394
Rithmic Trading | Network connection to server complete. | 2021-02-17 19:50:06.395
Rithmic Trading | Starting socket receive thread. | 2021-02-17 19:50:06.395
Rithmic Trading | Sending encoding request to server: Binary VLS. Compression: none | 2021-02-17 19:50:06.395
Rithmic Trading | Setting DTC encoding to Binary VLS | 2021-02-17 19:50:06.396
Rithmic Trading | Sending logon request message. | 2021-02-17 19:50:06.396
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2021-02-17 19:50:06.398
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2021-02-17 19:50:06.400
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2021-02-17 19:50:06.400
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2021-02-17 19:50:07.110
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2021-02-17 19:50:07.176
Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2021-02-17 19:50:07.369
Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2021-02-17 19:50:07.466
Rithmic Trading | Message from server: subscribeTradeRoute error. Error code: API_ALREADY_EXISTS | 2021-02-17 19:50:07.571
Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2021-02-17 19:50:07.642
Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2021-02-17 19:50:07.716
Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2021-02-17 19:50:07.948
Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2021-02-17 19:50:08.006
Rithmic Trading | Received logon response. | 2021-02-17 19:50:08.391
Rithmic Trading | Server Name: SC DTC Bridge. | 2021-02-17 19:50:08.391
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2021-02-17 19:50:08.391
Rithmic Trading | Successfully connected. IB='Earn2Trade', Firm='Earn2Trade'. | 2021-02-17 19:50:08.391
Rithmic Trading | Trading is supported. | 2021-02-17 19:50:08.391
Rithmic Trading | Order cancel and replace is supported. | 2021-02-17 19:50:08.391
Rithmic Trading | OCO Orders supported. | 2021-02-17 19:50:08.391
Rithmic Trading | Connected to server complete. | 2021-02-17 19:50:08.391
Triggering next historical data download in queue. | 2021-02-17 19:50:08.392
No download requests in the queue to start downloads for. | 2021-02-17 19:50:08.392
Rithmic Trading | Message from server: Received unknown message type from DTC client. Type = 603 | 2021-02-17 19:50:09.085
Rithmic Trading | Message from server: Received unknown message type from DTC client. Type = 603 | 2021-02-17 19:50:09.785
Rithmic Trading | Message from server: Server Alert: Received logout message - logging out. | 2021-02-17 19:50:10.064
Rithmic Trading | Message from server: Deleting API object. | 2021-02-17 19:50:10.065
Rithmic Trading | Message from server: Server Alert: Intraday History Connection Closed | 2021-02-17 19:50:10.065
Rithmic Trading | Message from server: Server Alert: PnL Connection Closed | 2021-02-17 19:50:10.068
Rithmic Trading | Message from server: Server Alert: Trading System Connection Closed | 2021-02-17 19:50:10.071
Rithmic Trading | Message from server: Server Alert: Market Data Connection Closed | 2021-02-17 19:50:10.074
DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-02-17 19:50:10.093
DTC Client socket (1) | CloseSocket call. | 2021-02-17 19:50:10.094
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-02-17 19:50:10.094
DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-17 19:50:10.094
DTC Client socket (1) | Closed. | 2021-02-17 19:50:10.094
Connection to the external service has been lost. | 2021-02-17 19:50:10.094
Rithmic Trading | Waiting for socket receive thread to end | 2021-02-17 19:50:10.111
DTC Client socket (0) | CloseSocket call. | 2021-02-17 19:50:10.112
Rithmic Trading | Disconnected. | 2021-02-17 19:50:10.112
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-17 19:50:10.112
File >> Disconnect selected. | 2021-02-17 19:50:11.934
DTC Client socket (0) | CloseSocket call. | 2021-02-17 19:50:11.934
Rithmic Trading | Disconnected. | 2021-02-17 19:50:11.934
[2021-02-18 17:51:27]
You can close this thread now. the connection has been stable during the RTH session.
