Date/Time: Thu, 16 May 2024 12:15:36 +0000
Out of order timestamps on continuous contract / but not on normal contract
View Count: 368
[2021-02-10 17:36:17] |
User818063 - Posts: 15 |
Hi I recently noticed some "out of order timestamps detected...". It happens only on the continuous contract. When using the same front month there is no error on the exact same period. I deleted on the relevant data files and synched my clock but the problem persists. The feed is Denali and here is an example of today on the CL (2 screenshots + chartbook enclosed-by). Please advise. -- W. |
SCOutOfOrderFrontMonth.png / V - Attached On 2021-02-10 17:34:44 UTC - Size: 48.88 KB - 141 views SCOutOfOrderFrontMonth.png / V - Attached On 2021-02-10 17:34:52 UTC - Size: 48.88 KB - 175 views Private File |
[2021-02-10 17:48:57] |
John - SC Support - Posts: 31666 |
We would need to see the Message Log that includes the Timestamp errors. Follow these instructions to get us your Message Log: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-10 19:25:41] |
First you are using the old symbol format. You need to translate the symbols using the Edit >> Translate Symbols to Current Service command. This is essential.
