Date/Time: Sun, 05 May 2024 22:29:49 +0000
delayed data
View Count: 427
[2021-02-02 15:14:57] |
User111993 - Posts: 1 |
Hi noticed on the top of my chart my feed is delayed, using sc futures order routing data thanks for your help
[2021-02-02 15:58:15] |
John - SC Support - Posts: 31379 |
Your setup is all good on our end, so you should be getting the Real-Time data. The most common reason for a problem like this is that the option File >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds is not set to Yes. Be sure this is set to Yes. After changing, reconnect: File Menu: Procedure to Reconnect to the Data and Trade Servers If the above does not solve the problem then follow these instructions to get us your Message Log: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-02 16:01:00
