Date/Time: Sat, 04 May 2024 20:18:14 +0000
do you have stock data feed ? and how to use the denali data ?
View Count: 649
[2021-02-01 05:37:42] |
User845173 - Posts: 6 |
Hi I am currently with tradovate and using the data feed from tradovate. i heard that you have stock and also if I want to use your future data too. please advise how to do that ?
[2021-02-01 08:16:05] |
Yes we have all of this data available. Both US stocks and CME Group futures and EUREX and other exchanges. Refer to: Real-Time Exchange Data Feeds Available From Sierra Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-01 08:16:38
[2021-03-02 22:25:58] |
which pkg should i buy ? i have pkg 5 now, so which one should i use ? and my current sub will be expired on 3/11, so if renew now and change to another pkg, how will this work ? thanks
[2021-03-02 23:01:41] |
John - SC Support - Posts: 31362 |
Refer to the differences in the Packages here: Description of Service Packages and Pricing: Packages If you are going to get data from us for the CME Group or EUREX, then you should use package 10, 11, or 12 which includes the Denali Data Feed Fee. To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link. Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. --------------------- For CME Group or EUREX data, you would use the Denali Exchange Data Feed. Refer to the information (including Setup Instructions) here: Denali Exchange Data Feed --------------------- for U.S. Equities (and other exchanges) you would use the Sierra Chart Exchange Data Feed. Refer to the information (including Setup Instructions) here: Sierra Chart Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
