Date/Time: Mon, 29 Apr 2024 21:37:40 +0000
Numbers Bars Calculated values 2 & Depth of Market
View Count: 2561
[2021-01-14 15:19:29] |
User781913 - Posts: 12 |
Why are the Numbers Bars Calculated values 2 all 0? In Depth of Market Data, I can't find Bid Ask Difference or Bid Ask Pull Stack Difference, and Bid Stack/Pull Value and Ask Stack/Pull Value don't show up either. These are not provided in CQG data? In Depth of Market Data, bid/ask show as bars, but I want numbers. What I'm really looking for is Depth of Market levels, not Depth of Market Data, but I can't find this study. I'm using CQG data feed. Date Time Of Last Edit: 2021-01-14 15:29:49
[2021-01-14 16:01:08] |
John - SC Support - Posts: 31187 |
First, refer to the information at the following link for how to display the Market Depth information on the Chart DOM. It sounds like this is really what you are looking for: Global Trade Settings Windows: Troubleshooting Market Depth Data Not Displaying in Chart/Trade DOM Columns In the Numbers Bars Calculated Values 2, the Pulling/Stacking items will not show any values unless you have the Pulling/Stacking columns displayed in the DOM. Refer to the information here for how to add columns to the DOM: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) Finally, you will find the full list of what data is available in the Numbers Bars Calculated Values and Numbers Bars Calculated Values 2 studies starting here: Numbers Bars: Numbers Bars Calculated Values Subgraph Descriptions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-14 16:59:02] |
Followed your instructions, now the Numbers Bars Calculated values 2 show up, but the Depth of Market Data still doesn't show any numbers (See attached). Also, there're only graph options for display, but I just want to see the numbers. How should I do it? Thanks! |
Stack pull.png / V - Attached On 2021-01-14 16:56:57 UTC - Size: 21.46 KB - 464 views |
[2021-12-09 17:38:13] |
Sargon Petros - Posts: 52 |
Hello, When I updated from version 2315 to the latest build, this study seems to stop working, more specifically for the ask/bid pull stacking data. For some reason, I don't see any data and it's all zeros. I downgraded back to 2315 and it still does not return any data. Could you help me to figure out if this is something specific to my account or my configuration? |
[2021-12-09 18:18:53] |
We are assuming that you are using the Numbers Bars Calculated Values 2 study and displaying the Pulling/Stacking subgraphs from that study. If that is the case, then you also need to have the Pulling/Stacking columns displayed on the Chart DOM in order to get the data into the Numbers Bars Calculated Values. Otherwise, the Pulling/Stacking is not calculated. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-30 02:51:16] |
User153286 - Posts: 44 |
I had the same issue, could not figure out why. I do use multiple charts at one time. So I tried seeing what levels of pulling and stacking I could get in a different chart with the trading DOM. To my surprise I got the 9 to 10 levels and yet still the original chart I was using only had 1 level. So.... I built a new chart, applied the desired studies and then deleted the one chart which only had 1 level. I now have the chart with studies I wanted and it has the complete available levels of pulling and stacking on the Chart Trading DOM
[2024-01-03 09:13:36] |
mbarbhaya - Posts: 35 |
Please share your CHT chartbook file
