Date/Time: Wed, 04 Nov 2026 15:53:04 +0000
MES Problem
View Count: 897
[2021-01-13 00:04:07]
User936653 - Posts: 5
In my account when I load MES March contract, it doesnt show up as the correct pricing.
The pricing is like DOW pricing 13,000 etc.
ES is fine, micros are not correct.
Can somebody help me out with this?
[2021-01-13 05:36:57]
There can be a couple of different causes of this. One can be a price multiplier issue from CQG which we have seen in the past or due to an unusual usage scenario.
The first thing to do is to update Sierra Chart to the latest prerelease:
And then:
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
[2021-01-13 14:21:24]
ok, pricing is right, i deleted all data and downloaded. Now my macd seems to be incorrect. Cant figure out why. Only for for MES i am experiencing this problem
[2021-01-13 17:41:14]
A study cannot be incorrect. It is based upon the underlying data in the chart. So you need to look at what the data problem is in the chart. Also be aware of the following:
We are no longer as of December 28, 2020 providing the Sierra Chart provided historical data service for CQG or Interactive Brokers users. For more information, refer to this Support Board thread:
Jan 1, 2021 Changes to Historical Data: Interactive Brokers, CQG
Also refer to this post for steps that you need to do now:
Jan 1, 2021 Changes to Historical Data: Interactive Brokers, CQG | Post: 245144
The solution to this problem is to use the Denali Exchange Data Feed for CME and EUREX (Upcoming in January 2021) data. Step-by-step instructions are here:
The first calendar month of this data feed is free. Let us know if you need help with the set up and we will help you through all of the steps.
In the case of CQG you will then need to contact your broker and cancel CME and EUREX exchange fees through your CQG account so you do not pay exchange fees twice. You definitively do not have to pay any market data exchange fees through your brokerage account to CQG. This is not required.
For other exchanges (ICE, HKFE) you need to use the Sierra Chart Exchange Data Feed:
As an alternative to CQG, we recommend using the Sierra Chart Order Routing Service:
Sierra Chart / Trading Technologies Futures Order Routing Service
In regards to using CQG provided historical data, we definitely do not recommend using that. It has an additional cost of 25 USD per month. The data delivery is slow and inefficient and causes Sierra Chart to freeze during the processing of it. Only 5 days of tick data is supported from CQG. And only current futures contracts are provided.
Whereas with Sierra Chart provided data feeds, you will have access to 10+ years of reliable high-speed delivered tick by tick data. Once again we do not advise using CQG historical data and it will not work well with Sierra Chart. And we also provide no technical help or support for any CQG provided historical data or real-time data.
Date Time Of Last Edit: 2021-01-13 17:41:33
