Date/Time: Wed, 04 Nov 2026 16:06:22 +0000
Opening shared files
View Count: 1012
[2021-01-05 16:09:12]
User619322 - Posts: 3
I am not able to open a shared file I see in my account. A user shared it with me but I cannot see it in the actual program
[2021-01-05 17:16:25]
John - SC Support - Posts: 48419
The first thing to do is to exit from Sierra Chart and then start the program again. This will try the download of the file to your system again.
If this is a Chartbook file, then make sure you are going to File >> Open Chartbook to select the file to open.
If you are still having an issue, then we would need to see your Message Log following these instructions:
Reconnect to the data feed:
Date Time Of Last Edit: 2021-01-05 21:49:58
