Date/Time: Sun, 19 May 2024 19:22:56 +0000
Access NASDAQ Stocks
View Count: 478
[2020-12-27 14:18:12] |
aharfouche - Posts: 6 |
Hi, I have the advanced package and I am trying to do some analysis on some NASDAQ stocks like Apple, Tesla, BABA and others. I can't find these stocks in the symbol search, how can I do that please? |
[2020-12-27 19:25:28] |
You just need to manually enter those particular stock symbols in the File >> Find Symbol window to open a chart. This is explained here: File Menu: Find Symbol (File) Or you can use this method: https://www.sierrachart.com/index.php?page=doc/GettingStarted.php#AlternateOpeningCharts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-27 19:30:25
