Date/Time: Fri, 03 May 2024 00:25:51 +0000
[Programming Help] - Problems with chart after updating from 2185 to 2206
View Count: 419
[2020-12-04 00:36:31] |
goodness - Posts: 8 |
Hi, after updating to the version 2206 SC makes problems with the chart especially Renko and P&F - I am using that charts. I have deleted all indicators, but the problems remains. I have reduced the forward lines in chartsettings to 10, but ist doesn´t help. The vertical lines in front the bars are blinking with each tick and it seems, that the calculation of each bar is not corrrect - have a look at the attachment. Actually I am using V. 2185 that works stable with that kind of bars (Renko+P&F). I am very disapointed in that case, because SC is one of the best trading platforms. Maybe I have to leave SC, if that error still remains. Date Time Of Last Edit: 2020-12-04 00:40:55
Attachment Deleted. SC-Chartproblems.png / V - Attached On 2020-12-04 00:40:42 UTC - Size: 85.35 KB - 183 views |
[2020-12-04 01:47:45] |
There definitely is nothing wrong with Sierra Chart in regards to this. The issue must be caused by a custom study. Use Safe Mode: Sierra Chart - Software Login Instructions: Using Safe Mode For more details, refer to: *IMPORTANT* Notice: Custom Study Improperly Altering Time Scale of Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-04 01:48:01
