Date/Time: Mon, 06 May 2024 00:23:08 +0000
Problem with Closed PL not uptaded
View Count: 388
[2020-12-02 21:07:33] |
User888444 - Posts: 3 |
Hello, I have a problem with the Closed PLs of each of the markets traded. None of the results correspond to the reality given by the trade activity log. Can you explain me how to correct this problem? Thanks Bruno |
[2020-12-03 18:37:39] |
We need to know what specific value you are referring to and where it is located. In the case of Daily Profit/loss, refer to: Help With Daily Profit/Loss Value We also recommend using the Sierra Chart Order Routing Service instead of CQG to avoid issues like this: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
