Date/Time: Thu, 02 May 2024 13:03:42 +0000
Real-time data problem
View Count: 510
[2020-11-30 14:31:38] |
User368075 - Posts: 9 |
How can I get a discounted price with real time data? I tried AMP but they declined my application. Are there other broker with low minimum deposit that you can suggest me? If I don’t find a solution, can we transfer the balance on another Sierra account? Thank you |
[2020-11-30 15:11:18] |
John - SC Support - Posts: 31293 |
The only thing we can point you to is the following service that we have available with AMP to allow for a minimal amount to be deposited in order to qualify for the Non-Professional fees from the CME Group. Easy Solution to CME Funded Trading Account Requirement Even though the above is through AMP, give it a try, as you get to the AMP setup through a special link so they are aware of the lower funding amount. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-30 15:18:26] |
I’ll give a try. If I don’t got a solution, is possible to transfer the balance on another Sierra chart account?
[2020-11-30 19:07:20] |
Yes, you can transfer funds between Sierra Chart Accounts. Just post in the Account Support Tickets that you want to make the transfer. Make sure you logged in as the account from which you want to transfer out when you make the post. That way we know you are the account holder asking to move funds out of your account. You can access the Account Support Tickets here: https://www.sierrachart.com/UserControlPanel.php?page=SupportTickets For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-30 19:07:43
[2020-11-30 19:21:43] |
Thank you
[2020-12-01 11:28:39] |
medsafi - Posts: 2 |
est ce que il'y a une autre methode directe pour avtive les flux en temps reel sans avoir ouvrir un compte de trading avec un un broker
[2020-12-01 14:25:41] |
From Google Translate: is there any other direct method to avtive real-time flows without opening a trading account with a broker?
For the CME Group data you have the choice of paying the Professional Exchange Fees or the Non-Professional Exchange Fees. If you want to qualify as a Non-Professional, then the CME Group requires that you have a trading account. You will find more information on this topic here: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
