Date/Time: Sat, 21 Nov 2026 10:39:56 +0000
Looking to trade /ES and /MES which live data feed to use?
View Count: 1530
| [2020-10-26 22:02:57] |
| Akular - Posts: 1 |
Hi everyone, I am looking to trade futures TPO profile with /es and /mes. Can someone kindly direct me to which live data feed I will need to purchase? If I also wanted to view the DOM and TPO would I have to purchase a different data feed. If so, which one? Thx u again for your assistance Andy |
| [2020-10-27 06:06:58] |
You will need this data feed: Denali Exchange Data Feed You have already activated this data feed though. You just need to activate the exchange you want but the question is do you have a funded trading account, to take advantage of the lower-priced CME fees ?. Refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges For now use the Delayed Exchange Data Feed: Delayed Exchange Data Feed If I also wanted to view the DOM and TPO would I have to purchase a different data feed. If so, which one? ---- Your account has been activated and the usage time extended if necessary. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-27 06:07:19
