Date/Time: Sun, 05 May 2024 20:07:36 +0000
Changing colors on correlated charts
View Count: 457
[2020-09-21 00:30:01] |
User425645 - Posts: 113 |
Hello, below i will post an image of /es with /nq overlaid. Id like to make it more easier to see visually by changing the bar colors for /nq (/nq is the overlaid chart) and im not sure how to do that. Appreciate your time. |
[2020-09-21 16:09:29] |
John - SC Support - Posts: 31379 |
In order to change the colors from the Study/Price Overlay study, you first have to set the Input for Use Colors From Source Study to No. Refer to the information here: Study/Price Overlay Study: Use Colors from Source Study Then you can change the subgraph colors for the Open, High, Low, and Last which will affect your Up and Down bar colors. Refer to the following for how to change Subgraph Colors: Chart Studies: Subgraphs Tab >> Color For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-21 21:31:46] |
Also refer to: Color Settings for Graph Draw Types Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
