Date/Time: Thu, 02 May 2024 14:43:57 +0000
CQG data feed is mega choppy
View Count: 543
[2020-09-10 18:09:02] |
User475566 - Posts: 6 |
CQG data feed is mega choppy stalling etc please help me to switch to a better cleaner data feed i'm ready to go live and this is ridiculous im just on cme only data feed |
[2020-09-10 18:10:39] |
i am with AMP FUTURES
[2020-09-10 19:13:27] |
Try the Denali Exchange Data Feed: Denali Exchange Data Feed But we cannot make any guarantees as to the performance you will get because this is dependent on the overall network connectivity. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-10 19:24:08] |
Also check this setting: Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) And refer to the above post as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-11 16:02:42] |
1. is Denali data feed the same as TT ? 2. Do i get will historical data? 3. In other words what differences are there from using CQG data? Fees debit my debit card or bank? 4. How much are total fees? $20 5. Is there a free trial??? |
[2020-09-11 16:03:45] |
PS: Are my orders placed on the CME servers? if not where?
[2020-09-11 16:08:24] |
i pay CME exchange fees thru my amp account.... would that chance if i use Denali?
[2020-09-11 18:51:55] |
Is Denali Just data feed? In other words will i still need CQG to execute orders? Or what do you have for executing orders? |
[2020-09-11 20:58:31] |
John - SC Support - Posts: 31293 |
You can continue to use CQG for your trading and get the data through the Denali Exchange Data Feed from us. If you do this, then you would want to let AMP know to stop the data from CQG so you are not paying for it twice. You can also have AMP set up your account to have the Denali Exchange Data Feed paid for through them. If you are interested in changing your trading provider, then you can use the Sierra Chart Order Routing Service which is suported by AMP. Refer to the information here: Sierra Chart / Trading Technologies Futures Order Routing Service As to where the orders exist, it depends on the type of order. Refer to the information in What's Included section in the link above for the Sierra Chart Order Routing Service and also to the information here for CQG: CQG Trading Platform Service: What is Included For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-11 21:55:00] |
1. is Denali data feed the same as TT ? No.2. Do i get will historical data? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-11 21:55:31
