Date/Time: Fri, 26 Apr 2024 15:59:25 +0000
How To Set Up: SC Order Routing Svc w/ EOD or delayed data CME & ICE/US
View Count: 526
[2020-09-08 19:21:49] |
Do you still have a question here? We see the thread is hidden.
[2020-09-08 21:00:25] |
User875622 - Posts: 17 |
Un-hidden.
[2020-09-08 23:21:56] |
The question was not answered.
[2020-09-09 14:24:11] |
John - SC Support - Posts: 31147 |
If you already have an account with one of the FCMs that supports the Sierra Chart Order Routing Service, then you just need to follow through the Setup Instructions for the service starting at Step #3. You will find the Setup Instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions If you do not want any Real-Time data, then you just need to not sign up for it. In which case you will have access to the Delayed Streaming Data for the CME Group and the Historical data for the ICE US. Refer to the following for the Delayed Streaming Data feed: Delayed Exchange Data Feed And refer to the following for the Historical Data Feed: Sierra Chart Historical Data Service Related to this, also refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#PeriodicUpdatingOfSymbolsNotReceivingStreamingData For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-09 20:27:35
