Date/Time: Sat, 18 May 2024 04:37:35 +0000
Alert Text for chart drawing
View Count: 665
[2020-07-17 12:40:21] |
User361939 - Posts: 158 |
Hello, i am trying to create TEXT alert when price cross e.g horizontal line on certain level or extending rectangle. After clicking on chart drawing there is section "Alerts" but i can add only "sound" notification and i don't see where can i add TEXT so i get TEXT INFO. Could you help me? Best Regards |
[2020-07-20 12:15:53] |
We are not sure what you are looking for in terms of TEXT in an alert. The only option for specific text associated with an alert is by changing the name of the Alert. Refer to the information here: https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#AlertNumber_UserDefinedName And also refer to the information for the 3 settings starting here: https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#IncludeAlertNameInAlertEmail You can use an alert sound in a tool alert. Refer to the information here: Chart Drawing Tools: Chart Drawing Alert Options Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
