Date/Time: Tue, 21 May 2024 07:03:26 +0000
Broker confusion
View Count: 492
[2020-07-15 20:25:16] |
CaptEZ - Posts: 4 |
I've been using Sierra with Interactive Brokers for a couple years, but am fed up with using IB as it seems Sierra is as well. Im currently subscribed to Denali data feed and it has been great. Im now trading mainly options and setup a new account with CTS (introducing broker is Blue Line Futures, clearing firm RCG). If I close my IB account, will I be able to use Sierra with CTS? I guess Im confused with the order routing and execution. If Im unable to do this, can you recommend a broker? I saw another person has a similar problem and is ready to drop IB but unsure where to migrate too. I have a feeling there are a lot of other people in this predicament... Thanks |
[2020-07-16 20:54:48] |
. If I close my IB account, will I be able to use Sierra with CTS? Yes CTS is supported.But we do recommend using the Denali Exchange Data Feed with CTS when using CTS: Denali Exchange Data Feed You can also use our Sierra Chart order routing service to chart and trade CME group options as well: Sierra Chart / Trading Technologies Futures Order Routing Service But you may prefer the CTS front-end software for options capabilities Sierra Chart does not have. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-16 20:55:10
