Date/Time: Sat, 12 Jul 2025 00:56:45 +0000
Position Failed to Flatten
View Count: 852
[2020-07-07 15:17:18]
User299107 - Posts: 60
Hi guys,
I had an open position which I "Flattened", which was rejected as "no order in Book" even though clearly on chart. So, "flatten" again. Then all chart positions gone. I've called broker to be certain I am FLAT and no working orders. However, I notice that in Trade Activity Window it shows 2 "trades" ie 4 fills, but in the Trade Orders Window I only see 3 Fills.
I've had this type of crap happen previously and it cost me ALOT... I know this is only peanuts this time, but I need to know what occurred and why I only see 3 fills in Trade Orders Window.
Thanks,
Eliza
[2020-07-07 15:43:32]
Update
I can now see 4 fills - had the window sorting according to something other than Entry Time.
But still concerned about the original error messages that enticed me into hitting FLATTEN for the second time.
With position Open, and OCO on chart, these messages said unable to cancel a no orders in book ????????????????
[2020-07-08 06:52:37]
What was on the chart? A Position or an Order? Or both? These are different.
Refer to:
Trading Information Windows: Automatic Clearing of Orders
It is possible the issue is what is described here:
Basic Trading and the Trade Window: Rejected Market Order When Using Flatten or Reverse Because of Position Limit Exceeded
You need to analyze the Trade Activity Log to see what has happened:
Trade Activity Log
There is no need to be asking us. We do not know. Only you will know.
Date Time Of Last Edit: 2020-07-08 06:53:31
[2020-07-08 09:33:08]
guys,
This is the order of events from my experience and corroborated in the log;
1. position Open with OCO orders (visible on chart and in log)
then
2. Flatten only closes position and fails to clear OCO orders due to "no orders in book" listed in log. and Orders still appear on chart.
3. Position is closed - which I failed to realize as orders are still active.
4. I think what has occurred is that the Orders failed to be cancelled when FLATTEN was initiated and so my OCO stop was filled.
4. So, I hit FLATTEN again it closed that position.
The issue for me is the message from TT of "no orders in book" and then they get filled.
Can you respond to the issue of OCO not cancelling once position is closed please
Thanks,
Eliza
[2020-07-08 10:01:42]
We need you to provide the information here:
Trade Activity Log Analysis: Support Assisted Trade Activity Log Analysis
There is a cost for us to look at this at 55 USD per hour. It will be sufficient to add 20 USD to your account.
So we need you to add credit to your Sierra Chart account:
https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit
Also, your explanation cannot be technically correct either:
We did actually locate those rejections and they are completely valid since the orders were either filled and canceled already.
Date Time Of Last Edit: 2020-07-08 10:02:30
[2020-07-08 10:29:47]
guys,
I'm not paying for you to look at logs
I'm going to forget this incident and monitor the system
Eliza
[2020-07-08 12:51:06]
Sierra_Chart Engineering - Posts: 20184
Right, and we are not going to spend our time looking through your logs and your case. This is why we charge for the time. We bill for our support time. It is not free.
Furthermore, what you said is just not true:
Thinking about this a little more, probably what happened is that you flattened the position at the same time the stop or target order filled. In which case, the child orders (target and stop) that you attempted to cancel were already canceled/filled and that is what generated the error messages and you ended up with a new position which you had to flatten again.
So there is nothing wrong here. It is just simply a matter of understanding what happened.
And this is why we charge for the analysis.
Date Time Of Last Edit: 2020-07-08 12:54:31
