Date/Time: Fri, 03 May 2024 18:10:31 +0000
Data services with tradovate account
View Count: 551
[2020-07-07 03:10:55] |
User884550 - Posts: 149 |
Hello Can I use Sierra data services and order routing if I am tradovate client? Can I then cancel my current real-time data subscriptions with them? |
[2020-07-07 03:47:41] |
You can use the Denali Exchange Data Feed with any trading service supported by Sierra Chart: Denali Exchange Data Feed Although you cannot use the Sierra Chart Order Routing Service with them. You need to use a different clearing firm: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-07 04:45:55] |
As I understand tradovate are clearing via dorman? And I need cme and Eurex. Would Sierra data and routing be a solution? |
[2020-07-07 10:31:02] |
Yes you can use the Sierra Chart Order Routing service with Dorman: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-07 10:31:22
