Date/Time: Mon, 06 May 2024 19:00:49 +0000
Using Sierra Chart Routing/Data instead of CQG
View Count: 531
[2020-07-06 05:53:18] |
User798041 - Posts: 1 |
Hello, Can I subscribe to ONLY the top-of-the-book data for Denali Feed ( $ 1 per month for CME ) , instead of the $20 a month to be able to use SC Routing ? And if I switch to SC Routing, will I need CQG if I only trade CME ? |
[2020-07-06 07:30:33] |
You can get the top of book data for the entire CME group for 3.25 USD per month + 20 USD for the real-time data connection. If you use the Sierra Chart Order Routing Service you do not need to use CQG. Here is the documentation for the Denali Exchange Data Feed: Denali Exchange Data Feed Here is the documentation for the Sierra Chart Order Routing Service: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
