Date/Time: Mon, 29 Apr 2024 09:23:42 +0000
cannot log in twice to rithmic
View Count: 549
[2020-07-05 23:53:54] |
User368470 - Posts: 1 |
As a non- professional trader, I should be able to run two software logins to rithmic, (including two Sierra Charts), on the same computer. When I try to do this, my first software gets kicked off and I am left with only one software having the live feed. I easily had both feeds a couple of months ago, I had both - what gives? Have filled out all the forms for non- professional trader with Sierra Charts and rithmic. Please advise. My clearing broker is Amp Futures and my email is **.
Date Time Of Last Edit: 2020-07-06 00:30:08
[2020-07-06 00:29:55] |
You need to discontinue use of Rithmic. Refer to: Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward You need to change to the Sierra Chart Order Routing service: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-06 00:30:24
