Date/Time: Sat, 04 May 2024 04:54:38 +0000
Phillips Capital Trading Account
View Count: 1169
[2020-07-01 19:32:15] |
Sirius Trader - Posts: 2 |
I have been evaluating both Sierra Chart and Ninja Trader recently, and have pretty much decided that I am going to go with your platform. I do like the NT Brokerage however, low margin and cheap commissions. I opened an account at NT Brokerage, and chose Phillips Capital as my FCM. My question is, can I use Sierra Chart as my trading platform in this instance? I am considering the level 5 package, and the SC Futures Order Routing/Data package as well. If this will not work, can you recommend a broker with comparable fees/margin requirements to NT Brokerage? Thanks Robert |
[2020-07-02 00:58:36] |
You can find low-margin low commissions just about anywhere these days. You really need the account direct with Phillips Capital. They do support the Sierra Chart order routing service now. We have more information here: Using Sierra Chart with Ninja Trader Brokerage Refer to step 2 here regarding the supported brokers/firms: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-02 00:59:48
