Date/Time: Thu, 02 May 2024 03:36:24 +0000
DOM not showing full inventory only current price
View Count: 735
[2020-07-01 14:43:34] |
marketmayhem - Posts: 10 |
Hello- I was connected and displaying full book (DOM), I was disconnected, and then when I re-connected I only had the current price. DOM should be attached |
[2020-07-01 15:04:46] |
John - SC Support - Posts: 31293 |
First, exit from Sierra Chart and then login using the Force Login option. Refer to the information here: Sierra Chart - Software Login Instructions: Forced Login If you continue to have an issue with the depth levels, then refer to the following: File Menu: Not Receiving the Full Number of Market Depth Levels For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-01 15:09:28] |
please close maybe it was a hiccup on my data all of sudden i was disconnected, then reconnected full dom came back
