Date/Time: Sat, 18 May 2024 22:45:56 +0000
sierra/denali with amp tt question
View Count: 572
[2020-06-18 14:31:08] |
User310898 - Posts: 35 |
Hi very basic question if may. 1. I already have the $100 AMP account with Denali and TT fix for routing which I was using to get live data. I was executing elsewhere. I am now interested in funding this to start executing on - is there somewhere other than my Sierra platform I am able to view my trades. For example a web based browser or even mobile in case I lose connectivity to my Sierra platform and need to close trades? 2. For DAX Futures is it correct I simply activate "Eurex with Market Depth"? 3. Can you give me the link with the instructions to set up the $100 AMP account for reduced CME fees as I want to send it to a friend that uses Sierra and I am unable to locate it. Thanks a lot! |
[2020-06-18 16:28:13] |
1. Yes, for the SC Order Routing with TT, there is a web-based panel that can be used. You will find the information on this here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#WebBasedTradingPanel 2. You will need to activate the Sierra Chart Exchange Data Feed and then activate the EUREX exchange within that. Note that in any month in which you use both the Sierra Chart Exchange Data Feed along with the Denali Exchange Data Feed, you will receive a $12.00 USD credit to your account. Here is the relevant documentation and set up instructions: Sierra Chart Exchange Data Feed 3. Here is the link: Easy Solution to CME Funded Trading Account Requirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-19 00:23:25] |
What can I say - absolutely WORLD CLASS Legendary Support as always. Really can't thank you enough. No idea how you guys manage to deal with so many queries in such an efficient manner. Testament to how good Sierra is from top to bottom. All the best. |
[2020-06-19 18:28:32] |
Thank you.
