Date/Time: Sat, 18 May 2024 18:47:09 +0000
[Programming Help] - Referencing chart misprint
View Count: 481
[2020-06-15 18:30:06] |
User236880 - Posts: 15 |
When using studies that reference a 2nd chart(ratio/butterfly/difference), there seems to be a brief misprint when a new candle is made. Shown in the first attached picture is the Crack spread and what happens to the highest high/lowest low over N bars study, and how it should look in the second attached picture. Is there any way to avoid this? |
Capture1.PNG / V - Attached On 2020-06-15 18:24:07 UTC - Size: 8.06 KB - 192 views Capture2.PNG / V - Attached On 2020-06-15 18:24:31 UTC - Size: 8.8 KB - 171 views |
[2020-06-16 01:03:29] |
We recommend using this feature: Custom Calculated Symbols And we recommend using the Denali Exchange Data Feed instead of Interactive Brokers data. Refer to: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
