Date/Time: Thu, 16 May 2024 16:33:14 +0000
CONFIGURACION PLATAFORMA PARA CUENTA REAL FINANCIADA
View Count: 684
[2020-06-12 16:14:37] |
User885665 - Posts: 1 |
buenas tardes la presente tienen ´por motivo solicitar informacion sobre cual es el proceso a seguir para poder operar en real con su plataforma actualmente tengo una cuenta financiada con MES capital (ONEUP TRADER) y me gustaria usar su plataforma para operar dicha cuenta
[2020-06-12 18:28:16] |
Sierra Chart does not support Rithmic or ONEUP TRADER. For live trading, you will need to use the Sierra Chart order routing service: Sierra Chart / Trading Technologies Futures Order Routing Service Instructions are on that page. For simulated trading, you can use this service: Simulated Futures Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-12 18:28:25
