Date/Time: Sat, 18 May 2024 16:14:01 +0000
dom info
View Count: 649
[2020-06-09 06:36:20] |
User888645 - Posts: 11 |
Hi Dom on sierra only displaying best two bids and offers. no other levels available no matter what i try. displayed all the data until two weeks ago what do i do to resolve thanks |
[2020-06-09 06:45:40] |
Refer to this section here: File Menu: Not Receiving the Full Number of Market Depth Levels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-09 07:37:26] |
thank you for the response. I have tried this with no luck. could it be by data feed from rithmic?
[2020-06-09 07:44:22] |
Well maybe but we see you are using the Denali Exchange Data Feed for CME symbols which has full depth. What is the symbol you are noticing the limited depth with?
[2020-06-09 07:47:45] |
well all of them Es Gold oil etc |
[2020-06-09 07:56:56] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-09 07:57:38] |
maybe that is an issue. I only pay for Sierra platform and have a rithmic data feed. should i disable denali?? |
[2020-06-09 08:05:40] |
here is the log Software version: 2118 64-bit | 2020-06-09 04:01:08.310 Primary Thread ID: 14024 | 2020-06-09 04:01:08.310 Usage end date: 2020-06-18 | 2020-06-09 04:01:08.310 Enabled for: Advanced Features 2. | 2020-06-09 04:01:08.310 Enabled for: Sierra Chart Historical Data Service. | 2020-06-09 04:01:08.310 Enabled for: Denali Real-Time Exchange Data Feed. | 2020-06-09 04:01:08.310 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-06-09 04:01:08.310 Enabled for exchange2: CME | 2020-06-09 04:01:08.310 Allow Support for Sierra Chart Data Feeds is disabled. | 2020-06-09 04:01:08.310 Current selected Data/Trading service: Rithmic Trading | 2020-06-09 04:01:08.310 Custom symbol settings values: enabled | 2020-06-09 04:01:08.310 Chart Update Interval: 500 | 2020-06-09 04:01:08.310 Intraday Data Storage Time Unit: 0 | 2020-06-09 04:01:08.310 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-06-09 04:01:08.310 2020-06-09 10:01:08 Local computer time | 2020-06-09 04:01:08.310 2020-06-09 08:01:08 Local computer time in UTC | 2020-06-09 04:01:08.310 2020-06-09 04:01:08 Local computer time in SC Time Zone | 2020-06-09 04:01:08.310 2020-06-09 06:17:20 Server time in UTC | 2020-06-09 04:01:08.310 Local computer UTC time and Server UTC time difference: 0 seconds. | 2020-06-09 04:01:08.310 Program path: C:\SierraChart\ | 2020-06-09 04:01:08.310 Data Files path: C:\SierraChart\Data\ | 2020-06-09 04:01:08.310 OS Version Number: 10.0 | 2020-06-09 04:01:08.310 Locale Setting: C | 2020-06-09 04:01:08.310 Allowed protected custom studies: | 2020-06-09 04:01:08.310 Rithmic Trading | Port for executable: 49515 | 2020-06-09 04:01:18.789 Listening socket (1572). Port 49515 | Closed. | 2020-06-09 04:01:18.789 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-09 04:01:18.790 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49515. Current folder: C:\SierraChart\Rim | 2020-06-09 04:01:18.805 Rithmic Trading | Bridge process is not running! | 2020-06-09 04:01:20.818 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49515 | 2020-06-09 04:01:20.818 DTC Client socket (2) | Creating socket. | 2020-06-09 04:01:20.818 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-09 04:01:20.818 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-09 04:01:22.844 * DTC Client socket (2) | CloseSocket call. | 2020-06-09 04:01:22.844 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-09 04:01:22.844 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-09 04:01:22.844 DTC Client socket (2) | Closed. | 2020-06-09 04:01:22.844 DTC Client socket (0) | CloseSocket call. | 2020-06-09 04:01:22.859 Rithmic Trading | Disconnected. | 2020-06-09 04:01:22.859 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-09 04:01:22.859 Rithmic Trading | Port for executable: 49520 | 2020-06-09 04:01:24.871 Listening socket (1700). Port 49520 | Closed. | 2020-06-09 04:01:24.871 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-09 04:01:24.873 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49520. Current folder: C:\SierraChart\Rim | 2020-06-09 04:01:24.880 Rithmic Trading | Bridge process is running. | 2020-06-09 04:01:26.875 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49520 | 2020-06-09 04:01:26.875 DTC Client socket (1) | Creating socket. | 2020-06-09 04:01:26.875 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-09 04:01:26.875 Rithmic Trading | Connected to server. | 2020-06-09 04:01:26.878 Rithmic Trading | Starting socket receive thread. | 2020-06-09 04:01:26.878 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-09 04:01:26.880 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-09 04:01:26.883 Rithmic Trading | Sending logon request message. | 2020-06-09 04:01:26.883 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-09 04:01:26.887 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-09 04:01:26.890 Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-09 04:01:26.890 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2020-06-09 04:01:30.254 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2020-06-09 04:01:30.563 Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2020-06-09 04:01:31.976 Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2020-06-09 04:01:32.266 Rithmic Trading | Message from server: subscribeTradeRoute error. Error code: API_ALREADY_EXISTS | 2020-06-09 04:01:32.843 Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2020-06-09 04:01:33.714 Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2020-06-09 04:01:34.026 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2020-06-09 04:01:35.419 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2020-06-09 04:01:35.707 Rithmic Trading | Received logon response. | 2020-06-09 04:01:35.886 Rithmic Trading | Server Name: SC DTC Bridge. | 2020-06-09 04:01:35.886 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-09 04:01:35.886 Rithmic Trading | Successfully connected. IB='Earn2Trade', Firm='Earn2Trade'. | 2020-06-09 04:01:35.886 Rithmic Trading | Trading is supported. | 2020-06-09 04:01:35.886 Rithmic Trading | Order cancel and replace is supported. | 2020-06-09 04:01:35.886 Rithmic Trading | OCO Orders supported. | 2020-06-09 04:01:35.886 Rithmic Trading | Connected to data and trading server. | 2020-06-09 04:01:35.886 Triggering next historical data download in queue. | 2020-06-09 04:01:35.886 Triggering next historical data download in queue. | 2020-06-09 04:01:35.886 Triggering next historical data download in queue. | 2020-06-09 04:01:35.886 Triggering next historical data download in queue. | 2020-06-09 04:01:35.886 Subscribing to symbol for symbol alert. ESM0-CME | 2020-06-09 04:01:35.886 Rithmic Trading | Starting real-time market data updates for: ESM0-CME. ID: 1 Service code: rithmic.trading | 2020-06-09 04:01:35.887 Rithmic Trading | Requesting security definition data for: ESM0-CME. ID: 1 | 2020-06-09 04:01:35.887 Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2020-06-09 04:01:35.887 Rithmic Trading | Message from server: Received unknown message type from DTC client. Type = 603 | 2020-06-09 04:01:35.902 Rithmic Trading | Message from server: Received unknown message type from DTC client. Type = 603 | 2020-06-09 04:01:35.909 Rithmic Trading | Starting real-time market data updates for: NQM0-CME. ID: 2 Service code: rithmic.trading | 2020-06-09 04:01:35.980 Rithmic Trading | Requesting security definition data for: NQM0-CME. ID: 2 | 2020-06-09 04:01:35.980 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQM0-CME | 2020-06-09 04:01:35.980 Added historical Intraday data request for NQM0-CME to the queue. | 2020-06-09 04:01:35.980 Intraday data recording state for symbol NQM0-CME is set to download 'Pending'. | 2020-06-09 04:01:35.980 Triggering next historical data download in queue. | 2020-06-09 04:01:35.980 Delaying start of download for NQM0-CME | 2020-06-09 04:01:35.980 Rithmic Trading | Starting real-time market data updates for: YMM0-CBOT. ID: 3 Service code: rithmic.trading | 2020-06-09 04:01:35.980 Rithmic Trading | Requesting security definition data for: YMM0-CBOT. ID: 3 | 2020-06-09 04:01:35.980 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: YMM0-CBOT | 2020-06-09 04:01:35.980 Added historical Intraday data request for YMM0-CBOT to the queue. | 2020-06-09 04:01:35.981 Intraday data recording state for symbol YMM0-CBOT is set to download 'Pending'. | 2020-06-09 04:01:35.981 Triggering next historical data download in queue. | 2020-06-09 04:01:35.981 Rithmic Trading | Starting real-time market data updates for: RTYM0-CME. ID: 4 Service code: rithmic.trading | 2020-06-09 04:01:35.981 Rithmic Trading | Requesting security definition data for: RTYM0-CME. ID: 4 | 2020-06-09 04:01:35.981 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: RTYM0-CME | 2020-06-09 04:01:35.981 Added historical Intraday data request for RTYM0-CME to the queue. | 2020-06-09 04:01:35.981 Intraday data recording state for symbol RTYM0-CME is set to download 'Pending'. | 2020-06-09 04:01:35.981 Triggering next historical data download in queue. | 2020-06-09 04:01:35.981 Rithmic Trading | Starting real-time market data updates for: GCJ1-COMEX. ID: 5 Service code: rithmic.trading | 2020-06-09 04:01:35.981 Rithmic Trading | Requesting security definition data for: GCJ1-COMEX. ID: 5 | 2020-06-09 04:01:35.981 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: GCJ1-COMEX | 2020-06-09 04:01:35.981 Added historical Intraday data request for GCJ1-COMEX to the queue. | 2020-06-09 04:01:35.981 Intraday data recording state for symbol GCJ1-COMEX is set to download 'Pending'. | 2020-06-09 04:01:35.981 Triggering next historical data download in queue. | 2020-06-09 04:01:35.981 Rithmic Trading | Starting real-time market data updates for: ZBU0-CBOT. ID: 6 Service code: rithmic.trading | 2020-06-09 04:01:35.983 Rithmic Trading | Requesting security definition data for: ZBU0-CBOT. ID: 6 | 2020-06-09 04:01:35.983 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZBU0-CBOT | 2020-06-09 04:01:35.983 Added historical Intraday data request for ZBU0-CBOT to the queue. | 2020-06-09 04:01:35.983 Intraday data recording state for symbol ZBU0-CBOT is set to download 'Pending'. | 2020-06-09 04:01:35.983 Triggering next historical data download in queue. | 2020-06-09 04:01:35.983 Rithmic Trading | Starting real-time market data updates for: 6JM0-CME. ID: 7 Service code: rithmic.trading | 2020-06-09 04:01:35.983 Rithmic Trading | Requesting security definition data for: 6JM0-CME. ID: 7 | 2020-06-09 04:01:35.983 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: 6JM0-CME | 2020-06-09 04:01:35.983 Added historical Intraday data request for 6JM0-CME to the queue. | 2020-06-09 04:01:35.983 Intraday data recording state for symbol 6JM0-CME is set to download 'Pending'. | 2020-06-09 04:01:35.983 Triggering next historical data download in queue. | 2020-06-09 04:01:35.983 SC DTC Data with Market Depth | Starting real-time market data updates for: USDX. ID: 8 Service code: fxstatscalc | 2020-06-09 04:01:35.984 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2020-06-09 04:01:35.984 SC DTC Data with Market Depth | Requesting security definition data for: USDX. ID: 8 | 2020-06-09 04:01:35.984 Added historical Intraday data request for USDX to the queue. | 2020-06-09 04:01:35.984 Intraday data recording state for symbol USDX is set to download 'Pending'. | 2020-06-09 04:01:35.984 Triggering next historical data download in queue. | 2020-06-09 04:01:35.984 Rithmic Trading | Starting real-time market data updates for: SIN0-COMEX. ID: 9 Service code: rithmic.trading | 2020-06-09 04:01:35.984 Rithmic Trading | Requesting security definition data for: SIN0-COMEX. ID: 9 | 2020-06-09 04:01:35.984 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: SIN0-COMEX | 2020-06-09 04:01:35.984 Added historical Intraday data request for SIN0-COMEX to the queue. | 2020-06-09 04:01:35.984 Intraday data recording state for symbol SIN0-COMEX is set to download 'Pending'. | 2020-06-09 04:01:35.984 Triggering next historical data download in queue. | 2020-06-09 04:01:35.984 DTC Client socket (2) | Creating socket. | 2020-06-09 04:01:35.984 DTC Client socket (2) | Connecting to IP: 192.81.56.146. | 2020-06-09 04:01:35.984 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ESM0-CME | 2020-06-09 04:01:35.984 Added historical Intraday data request for ESM0-CME to the queue. | 2020-06-09 04:01:35.984 Intraday data recording state for symbol ESM0-CME is set to download 'Pending'. | 2020-06-09 04:01:35.984 Triggering next historical data download in queue. | 2020-06-09 04:01:35.984 Requesting market depth updates for: ESM0-CME if supported. | 2020-06-09 04:01:36.034 SC DTC Data with Market Depth | Connected to server. | 2020-06-09 04:01:36.255 SC DTC Data with Market Depth | Starting socket receive thread. | 2020-06-09 04:01:36.255 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2020-06-09 04:01:36.255 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2020-06-09 04:01:36.546 SC DTC Data with Market Depth | Sending logon request message. | 2020-06-09 04:01:36.546 Rithmic Trading | Message from server: Server Alert: get_order_book error : 13. Result text: "permission denied". Related symbol: ESM0-CME | 2020-06-09 04:01:36.572 Rithmic Trading | Market Depth data has been rejected for symbol: ESM0-CME. get_order_book error : 13. Result text: "permission denied" | 2020-06-09 04:01:36.572 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESM0-CME.2020-06-09.depth | 2020-06-09 04:01:36.572 Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied". Related symbol: YMM0-CBOT | 2020-06-09 04:01:36.748 Symbol Error - YMM0-CBOT is unknown, unavailable, or improperly formatted. | 2020-06-09 04:01:36.748 Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied". Related symbol: ZBU0-CBOT | 2020-06-09 04:01:36.813 Symbol Error - ZBU0-CBOT is unknown, unavailable, or improperly formatted. | 2020-06-09 04:01:36.814 SC DTC Data with Market Depth | Received logon response. | 2020-06-09 04:01:37.321 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2020-06-09 04:01:37.321 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2020-06-09 04:01:37.321 SC DTC Data with Market Depth | Successfully connected. | 2020-06-09 04:01:37.321 SC DTC Data with Market Depth | Trading is not supported. | 2020-06-09 04:01:37.321 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDX | 2020-06-09 04:01:37.321 SC DTC Data with Market Depth | Received security definition for symbol USDX | 2020-06-09 04:01:37.602 Requesting market depth updates for: 6JM0-CME if supported. | 2020-06-09 04:01:40.875 Requesting market depth updates for: GCJ1-COMEX if supported. | 2020-06-09 04:01:40.875 Requesting market depth updates for: NQM0-CME if supported. | 2020-06-09 04:01:40.875 Requesting market depth updates for: RTYM0-CME if supported. | 2020-06-09 04:01:40.875 Requesting market depth updates for: SIN0-COMEX if supported. | 2020-06-09 04:01:40.875 Requesting market depth updates for: USDX if supported. | 2020-06-09 04:01:40.875 Separate subscription for market depth updates not supported. USDX | 2020-06-09 04:01:40.875 Requesting market depth updates for: YMM0-CBOT if supported. | 2020-06-09 04:01:40.875 Requesting market depth updates for: ZBU0-CBOT if supported. | 2020-06-09 04:01:40.875 Rithmic Trading | Message from server: Server Alert: get_order_book error : 13. Result text: "permission denied". Related symbol: 6JM0-CME | 2020-06-09 04:01:41.183 Rithmic Trading | Market Depth data has been rejected for symbol: 6JM0-CME. get_order_book error : 13. Result text: "permission denied" | 2020-06-09 04:01:41.188 HD Request # 48 | Downloading Intraday chart data for NQM0-CME to the file NQM0-CME.scid. Service: cme | 2020-06-09 04:01:41.328 HD Request # 48 | Download start date-time: 2020-06-09 04:00:57.000 | 2020-06-09 04:01:41.329 HD Request # 48 | Using server: ds23.sierracharts.com port 10149 | 2020-06-09 04:01:41.330 Socket (3) | Creating socket. | 2020-06-09 04:01:41.331 Socket (3) | Connecting to IP: 216.1.90.130. | 2020-06-09 04:01:41.331 Rithmic Trading | Message from server: Server Alert: get_order_book error : 13. Result text: "permission denied". Related symbol: RTYM0-CME | 2020-06-09 04:01:41.341 Rithmic Trading | Market Depth data has been rejected for symbol: RTYM0-CME. get_order_book error : 13. Result text: "permission denied" | 2020-06-09 04:01:41.342 Rithmic Trading | Message from server: Server Alert: get_order_book error : 13. Result text: "permission denied". Related symbol: SIN0-COMEX | 2020-06-09 04:01:41.343 Rithmic Trading | Market Depth data has been rejected for symbol: SIN0-COMEX. get_order_book error : 13. Result text: "permission denied" | 2020-06-09 04:01:41.343 Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied". Related symbol: YMM0-CBOT | 2020-06-09 04:01:41.344 Rithmic Trading | Message from server: Server Alert: get_order_book error : 13. Result text: "permission denied". Related symbol: YMM0-CBOT | 2020-06-09 04:01:41.344 Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied". Related symbol: ZBU0-CBOT | 2020-06-09 04:01:41.344 Rithmic Trading | Message from server: Server Alert: get_order_book error : 13. Result text: "permission denied". Related symbol: ZBU0-CBOT | 2020-06-09 04:01:41.344 Symbol Error - YMM0-CBOT is unknown, unavailable, or improperly formatted. | 2020-06-09 04:01:41.345 Rithmic Trading | Market Depth data has been rejected for symbol: YMM0-CBOT. get_order_book error : 13. Result text: "permission denied" | 2020-06-09 04:01:41.345 Symbol Error - ZBU0-CBOT is unknown, unavailable, or improperly formatted. | 2020-06-09 04:01:41.345 Rithmic Trading | Market Depth data has been rejected for symbol: ZBU0-CBOT. get_order_book error : 13. Result text: "permission denied" | 2020-06-09 04:01:41.345 HD Request # 48 | Setting DTC encoding to Binary VLS | 2020-06-09 04:01:41.913 HD Request # 48 | Sending historical data logon request message. | 2020-06-09 04:01:41.913 HD Request # 48 | Requesting Intraday data. Start date-time: 2020-06-09 04:00:57. Record interval: 0. Symbol: NQM20 | 2020-06-09 04:01:42.654 HD Request # 48 | Decompressing data. | 2020-06-09 04:01:42.951 HD Request # 48 | Receiving Intraday data for NQM0-CME starting at 2020-06-09 04:00:57 | 2020-06-09 04:01:42.952 Socket (3) | CloseSocket call. | 2020-06-09 04:01:42.955 Socket (3) | Shutdown started. Waiting for graceful close. | 2020-06-09 04:01:42.955 Historical data download thread signaled to stop. | 2020-06-09 04:01:42.956 HD Request # 48 | Timestamp of first Intraday data file record written: 2020-06-09 04:00:58 | 2020-06-09 04:01:42.956 HD Request # 48 | Received 135 records from 2020-06-09 04:00:57.000 to 2020-06-09 04:01:39.002 (42.0 seconds) and wrote 134 records for NQM0-CME | 2020-06-09 04:01:42.956 HD Request # 48 | Completion time: 1s | 2020-06-09 04:01:42.957 HD Request # 48 | Intraday data download complete for NQM0-CME. Unique request ID: 48 | 2020-06-09 04:01:42.957 Removing historical data download ID 48. | 2020-06-09 04:01:42.957 Real-time Intraday chart data file updates started for NQM0-CME | 2020-06-09 04:01:42.957 Intraday chart data file opened for NQM0-CME | 2020-06-09 04:01:42.957 HD Request # 48 | Enabling Intraday chart updating for symbol. | 2020-06-09 04:01:42.957 Rithmic Trading | Using primary service for historical data for NQM0-CME | 2020-06-09 04:01:42.957 Added historical Intraday data request for NQM0-CME to the queue. | 2020-06-09 04:01:42.957 Intraday data recording state for symbol NQM0-CME is set to download 'Pending'. | 2020-06-09 04:01:42.957 Triggering next historical data download in queue. | 2020-06-09 04:01:42.957 Triggering next historical data download in queue. | 2020-06-09 04:01:42.957 HD Request # 49 | Downloading Intraday chart data for NQM0-CME to the file NQM0-CME.scid. Service: rithmic.trading | 2020-06-09 04:01:42.957 HD Request # 49 | Download start date-time: 2020-06-09 04:01:39.000 | 2020-06-09 04:01:42.958 HD Request # 49 | Sending historical data request. Start date-time: 2020-06-09 04:01:39. Record interval: 0. Symbol: NQM0-CME | 2020-06-09 04:01:42.958 HD Request # 50 | Downloading Intraday chart data for YMM0-CBOT to the file YMM0-CBOT.scid. Service: cbot | 2020-06-09 04:01:42.958 HD Request # 50 | Download start date-time: 2020-06-09 02:47:42.000 | 2020-06-09 04:01:42.959 HD Request # 50 | Using server: ds21.sierracharts.com port 10150 | 2020-06-09 04:01:42.959 Rithmic Trading | Message from server: Requesting historical Tick data. | 2020-06-09 04:01:42.960 Socket (4) | Creating socket. | 2020-06-09 04:01:42.960 Socket (4) | Connecting to IP: 216.1.90.129. | 2020-06-09 04:01:42.961 Chart #4 has tagged chart #3 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:42.972 ESM0-CME 5 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:43.174 Socket (3) | Socket gracefully closed by remote side. | 2020-06-09 04:01:43.255 Socket (3) | Closed. | 2020-06-09 04:01:43.255 HD Request # 49 | Receiving Intraday data for NQM0-CME starting at 2020-06-09 04:01:39 | 2020-06-09 04:01:43.284 HD Request # 49 | Timestamp of first Intraday data file record written: 2020-06-09 04:01:40 | 2020-06-09 04:01:43.286 HD Request # 49 | Received 15 records from 2020-06-09 04:01:39.000 to 2020-06-09 04:01:41.010 (2.0 seconds) and wrote 12 records for NQM0-CME | 2020-06-09 04:01:43.287 HD Request # 49 | Completion time: 1s | 2020-06-09 04:01:43.287 HD Request # 49 | Intraday data download complete for NQM0-CME. Unique request ID: 57 | 2020-06-09 04:01:43.288 Removing historical data download ID 57. | 2020-06-09 04:01:43.288 Real-time Intraday chart data file updates started for NQM0-CME | 2020-06-09 04:01:43.288 Intraday chart data file opened for NQM0-CME | 2020-06-09 04:01:43.288 HD Request # 49 | Enabling Intraday chart updating for symbol. | 2020-06-09 04:01:43.288 Triggering next historical data download in queue. | 2020-06-09 04:01:43.288 Chart #4 has tagged chart #3 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:43.472 HD Request # 50 | Setting DTC encoding to Binary VLS | 2020-06-09 04:01:43.551 HD Request # 50 | Sending historical data logon request message. | 2020-06-09 04:01:43.551 ESM0-CME 5 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:43.677 HD Request # 50 | Requesting Intraday data. Start date-time: 2020-06-09 02:47:42. Record interval: 0. Symbol: YMM20 | 2020-06-09 04:01:44.301 HD Request # 50 | Decompressing data. | 2020-06-09 04:01:44.591 Opened cached Intraday file: C:\SierraChart\Data\NQM0-CME.scid. Thread ID: 18844 | 2020-06-09 04:01:44.908 HD Request # 50 | Receiving Intraday data for YMM0-CBOT starting at 2020-06-09 02:47:42 | 2020-06-09 04:01:45.193 Socket (4) | CloseSocket call. | 2020-06-09 04:01:45.236 Socket (4) | Shutdown started. Waiting for graceful close. | 2020-06-09 04:01:45.236 Historical data download thread signaled to stop. | 2020-06-09 04:01:45.236 HD Request # 50 | Timestamp of first Intraday data file record written: 2020-06-09 02:47:44 | 2020-06-09 04:01:45.237 HD Request # 50 | Received 8247 records from 2020-06-09 02:47:42.000 to 2020-06-09 03:51:42.001 (64.0 minutes) and wrote 8244 records for YMM0-CBOT | 2020-06-09 04:01:45.237 HD Request # 50 | Completion time: 3s | 2020-06-09 04:01:45.237 HD Request # 50 | Intraday data download complete for YMM0-CBOT. Unique request ID: 49 | 2020-06-09 04:01:45.237 Removing historical data download ID 49. | 2020-06-09 04:01:45.237 Real-time Intraday chart data file updates started for YMM0-CBOT | 2020-06-09 04:01:45.237 Intraday chart data file opened for YMM0-CBOT | 2020-06-09 04:01:45.237 HD Request # 50 | Enabling Intraday chart updating for symbol. | 2020-06-09 04:01:45.237 Rithmic Trading | Using primary service for historical data for YMM0-CBOT | 2020-06-09 04:01:45.237 Added historical Intraday data request for YMM0-CBOT to the queue. | 2020-06-09 04:01:45.237 Intraday data recording state for symbol YMM0-CBOT is set to download 'Pending'. | 2020-06-09 04:01:45.237 Triggering next historical data download in queue. | 2020-06-09 04:01:45.237 Triggering next historical data download in queue. | 2020-06-09 04:01:45.237 HD Request # 51 | Downloading Intraday chart data for YMM0-CBOT to the file YMM0-CBOT.scid. Service: rithmic.trading | 2020-06-09 04:01:45.237 HD Request # 51 | Download start date-time: 2020-06-09 03:51:42.000 | 2020-06-09 04:01:45.237 HD Request # 51 | Sending historical data request. Start date-time: 2020-06-09 03:51:42. Record interval: 0. Symbol: YMM0-CBOT | 2020-06-09 04:01:45.237 HD Request # 52 | Downloading Intraday chart data for RTYM0-CME to the file RTYM0-CME.scid. Service: cme | 2020-06-09 04:01:45.237 HD Request # 52 | Download start date-time: 2020-06-09 04:00:46.000 | 2020-06-09 04:01:45.238 HD Request # 52 | Using server: ds23.sierracharts.com port 10149 | 2020-06-09 04:01:45.238 Socket (3) | Creating socket. | 2020-06-09 04:01:45.238 Socket (3) | Connecting to IP: 216.1.90.130. | 2020-06-09 04:01:45.238 Rithmic Trading | Message from server: Requesting historical Tick data. | 2020-06-09 04:01:45.239 Chart #7 has tagged chart #3 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:45.478 HD Request # 51 | Error downloading historical Intraday data for YMM0-CBOT. Error downloading historical Tick data. Error: permission denied | 2020-06-09 04:01:45.503 HD Request # 51 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for YMM0-CBOT | 2020-06-09 04:01:45.503 HD Request # 51 | Completion time: 0s | 2020-06-09 04:01:45.503 HD Request # 51 | Intraday data download complete for YMM0-CBOT. Unique request ID: 58 | 2020-06-09 04:01:45.504 Removing historical data download ID 58. | 2020-06-09 04:01:45.504 Real-time Intraday chart data file updates started for YMM0-CBOT | 2020-06-09 04:01:45.504 Intraday chart data file opened for YMM0-CBOT | 2020-06-09 04:01:45.504 HD Request # 51 | Enabling Intraday chart updating for symbol. | 2020-06-09 04:01:45.504 Triggering next historical data download in queue. | 2020-06-09 04:01:45.504 Socket (4) | Socket gracefully closed by remote side. | 2020-06-09 04:01:45.521 Socket (4) | Closed. | 2020-06-09 04:01:45.521 ESM0-CME 5 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:45.676 HD Request # 52 | Setting DTC encoding to Binary VLS | 2020-06-09 04:01:45.801 HD Request # 52 | Sending historical data logon request message. | 2020-06-09 04:01:45.801 Chart #7 has tagged chart #3 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:45.971 HD Request # 52 | Requesting Intraday data. Start date-time: 2020-06-09 04:00:46. Record interval: 0. Symbol: RTYM20 | 2020-06-09 04:01:46.092 ESM0-CME 5 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:46.205 HD Request # 52 | Decompressing data. | 2020-06-09 04:01:46.362 HD Request # 52 | Receiving Intraday data for RTYM0-CME starting at 2020-06-09 04:00:46 | 2020-06-09 04:01:46.363 Socket (3) | CloseSocket call. | 2020-06-09 04:01:46.365 Socket (3) | Shutdown started. Waiting for graceful close. | 2020-06-09 04:01:46.365 Historical data download thread signaled to stop. | 2020-06-09 04:01:46.365 HD Request # 52 | Timestamp of first Intraday data file record written: 2020-06-09 04:01:01 | 2020-06-09 04:01:46.365 HD Request # 52 | Received 34 records from 2020-06-09 04:00:46.000 to 2020-06-09 04:01:38.000 (52.0 seconds) and wrote 32 records for RTYM0-CME | 2020-06-09 04:01:46.366 HD Request # 52 | Completion time: 1s | 2020-06-09 04:01:46.366 HD Request # 52 | Intraday data download complete for RTYM0-CME. Unique request ID: 50 | 2020-06-09 04:01:46.366 Removing historical data download ID 50. | 2020-06-09 04:01:46.366 Real-time Intraday chart data file updates started for RTYM0-CME | 2020-06-09 04:01:46.366 Intraday chart data file opened for RTYM0-CME | 2020-06-09 04:01:46.366 HD Request # 52 | Enabling Intraday chart updating for symbol. | 2020-06-09 04:01:46.366 Rithmic Trading | Using primary service for historical data for RTYM0-CME | 2020-06-09 04:01:46.366 Added historical Intraday data request for RTYM0-CME to the queue. | 2020-06-09 04:01:46.366 Intraday data recording state for symbol RTYM0-CME is set to download 'Pending'. | 2020-06-09 04:01:46.366 Triggering next historical data download in queue. | 2020-06-09 04:01:46.366 Triggering next historical data download in queue. | 2020-06-09 04:01:46.366 HD Request # 53 | Downloading Intraday chart data for RTYM0-CME to the file RTYM0-CME.scid. Service: rithmic.trading | 2020-06-09 04:01:46.366 HD Request # 53 | Download start date-time: 2020-06-09 04:01:38.000 | 2020-06-09 04:01:46.368 HD Request # 53 | Sending historical data request. Start date-time: 2020-06-09 04:01:38. Record interval: 0. Symbol: RTYM0-CME | 2020-06-09 04:01:46.368 HD Request # 54 | Downloading Intraday chart data for GCJ1-COMEX to the file GCJ1-COMEX.scid. Service: comex | 2020-06-09 04:01:46.368 HD Request # 54 | Download start date-time: 2020-06-08 13:29:55.000 | 2020-06-09 04:01:46.369 HD Request # 54 | Using server: ds21.sierracharts.com port 10150 | 2020-06-09 04:01:46.369 Rithmic Trading | Message from server: Requesting historical Tick data. | 2020-06-09 04:01:46.369 Socket (4) | Creating socket. | 2020-06-09 04:01:46.369 Socket (4) | Connecting to IP: 216.1.90.129. | 2020-06-09 04:01:46.369 Chart #5 has tagged chart #3 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:46.477 Socket (3) | Socket gracefully closed by remote side. | 2020-06-09 04:01:46.636 Socket (3) | Closed. | 2020-06-09 04:01:46.636 HD Request # 53 | Receiving Intraday data for RTYM0-CME starting at 2020-06-09 04:01:38 | 2020-06-09 04:01:46.677 HD Request # 53 | Received 1 record from 2020-06-09 04:01:38.000 to 2020-06-09 04:01:38.000 (0.0 seconds) and wrote 0 records for RTYM0-CME | 2020-06-09 04:01:46.677 HD Request # 53 | Completion time: 0s | 2020-06-09 04:01:46.677 HD Request # 53 | Intraday data download complete for RTYM0-CME. Unique request ID: 59 | 2020-06-09 04:01:46.677 Removing historical data download ID 59. | 2020-06-09 04:01:46.677 Real-time Intraday chart data file updates started for RTYM0-CME | 2020-06-09 04:01:46.677 Intraday chart data file opened for RTYM0-CME | 2020-06-09 04:01:46.677 HD Request # 53 | Enabling Intraday chart updating for symbol. | 2020-06-09 04:01:46.677 Triggering next historical data download in queue. | 2020-06-09 04:01:46.677 ESM0-CME 5 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:46.690 HD Request # 54 | Setting DTC encoding to Binary VLS | 2020-06-09 04:01:46.928 HD Request # 54 | Sending historical data logon request message. | 2020-06-09 04:01:46.928 Chart #5 has tagged chart #3 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:46.987 ESM0-CME 5 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:47.187 HD Request # 54 | Requesting Intraday data. Start date-time: 2020-06-08 13:29:55. Record interval: 0. Symbol: GCJ21 | 2020-06-09 04:01:47.201 HD Request # 54 | Decompressing data. | 2020-06-09 04:01:47.487 HD Request # 54 | Receiving Intraday data for GCJ1-COMEX starting at 2020-06-08 13:29:55 | 2020-06-09 04:01:47.487 Socket (4) | CloseSocket call. | 2020-06-09 04:01:47.487 Socket (4) | Shutdown started. Waiting for graceful close. | 2020-06-09 04:01:47.487 Historical data download thread signaled to stop. | 2020-06-09 04:01:47.488 HD Request # 54 | Received 1 record from 2020-06-08 13:29:55.000 to 2020-06-08 13:29:55.000 (0.0 seconds) and wrote 0 records for GCJ1-COMEX | 2020-06-09 04:01:47.488 HD Request # 54 | Completion time: 1s | 2020-06-09 04:01:47.488 HD Request # 54 | Intraday data download complete for GCJ1-COMEX. Unique request ID: 51 | 2020-06-09 04:01:47.488 Removing historical data download ID 51. | 2020-06-09 04:01:47.488 Real-time Intraday chart data file updates started for GCJ1-COMEX | 2020-06-09 04:01:47.488 Intraday chart data file opened for GCJ1-COMEX | 2020-06-09 04:01:47.488 HD Request # 54 | Enabling Intraday chart updating for symbol. | 2020-06-09 04:01:47.488 Rithmic Trading | Using primary service for historical data for GCJ1-COMEX | 2020-06-09 04:01:47.488 Added historical Intraday data request for GCJ1-COMEX to the queue. | 2020-06-09 04:01:47.488 Intraday data recording state for symbol GCJ1-COMEX is set to download 'Pending'. | 2020-06-09 04:01:47.488 Triggering next historical data download in queue. | 2020-06-09 04:01:47.488 Triggering next historical data download in queue. | 2020-06-09 04:01:47.488 HD Request # 55 | Downloading Intraday chart data for GCJ1-COMEX to the file GCJ1-COMEX.scid. Service: rithmic.trading | 2020-06-09 04:01:47.488 HD Request # 55 | Download start date-time: 2020-06-08 13:29:55.000 | 2020-06-09 04:01:47.488 HD Request # 55 | Sending historical data request. Start date-time: 2020-06-08 13:29:55. Record interval: 0. Symbol: GCJ1-COMEX | 2020-06-09 04:01:47.488 HD Request # 56 | Downloading Intraday chart data for ZBU0-CBOT to the file ZBU0-CBOT.scid. Service: cbot | 2020-06-09 04:01:47.488 HD Request # 56 | Download start date-time: 2020-06-09 02:47:39.000 | 2020-06-09 04:01:47.489 HD Request # 56 | Using server: ds23.sierracharts.com port 10149 | 2020-06-09 04:01:47.489 Socket (3) | Creating socket. | 2020-06-09 04:01:47.489 Socket (3) | Connecting to IP: 216.1.90.130. | 2020-06-09 04:01:47.489 Rithmic Trading | Message from server: Requesting historical Tick data. | 2020-06-09 04:01:47.491 Chart #11 has tagged chart #16 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:47.491 Socket (4) | Socket gracefully closed by remote side. | 2020-06-09 04:01:47.762 Socket (4) | Closed. | 2020-06-09 04:01:47.762 HD Request # 55 | Error downloading historical Intraday data for GCJ1-COMEX. Error downloading historical Tick data. Error: no data | 2020-06-09 04:01:47.763 HD Request # 55 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for GCJ1-COMEX | 2020-06-09 04:01:47.763 HD Request # 55 | Completion time: 0s | 2020-06-09 04:01:47.763 HD Request # 55 | Intraday data download complete for GCJ1-COMEX. Unique request ID: 60 | 2020-06-09 04:01:47.763 Removing historical data download ID 60. | 2020-06-09 04:01:47.763 Real-time Intraday chart data file updates started for GCJ1-COMEX | 2020-06-09 04:01:47.763 Intraday chart data file opened for GCJ1-COMEX | 2020-06-09 04:01:47.763 HD Request # 55 | Enabling Intraday chart updating for symbol. | 2020-06-09 04:01:47.763 Triggering next historical data download in queue. | 2020-06-09 04:01:47.763 GCJ1-COMEX 5 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:47.986 Chart #11 has tagged chart #16 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:47.988 HD Request # 56 | Setting DTC encoding to Binary VLS | 2020-06-09 04:01:48.096 HD Request # 56 | Sending historical data logon request message. | 2020-06-09 04:01:48.096 HD Request # 56 | Requesting Intraday data. Start date-time: 2020-06-09 02:47:39. Record interval: 0. Symbol: ZBU20 | 2020-06-09 04:01:48.392 GCJ1-COMEX 5 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:48.477 HD Request # 56 | Decompressing data. | 2020-06-09 04:01:48.682 HD Request # 56 | Receiving Intraday data for ZBU0-CBOT starting at 2020-06-09 02:47:39 | 2020-06-09 04:01:49.265 Socket (3) | CloseSocket call. | 2020-06-09 04:01:49.266 Socket (3) | Shutdown started. Waiting for graceful close. | 2020-06-09 04:01:49.266 Historical data download thread signaled to stop. | 2020-06-09 04:01:49.266 HD Request # 56 | Timestamp of first Intraday data file record written: 2020-06-09 02:47:46 | 2020-06-09 04:01:49.266 HD Request # 56 | Received 6196 records from 2020-06-09 02:47:39.000 to 2020-06-09 03:51:38.000 (64.0 minutes) and wrote 6194 records for ZBU0-CBOT | 2020-06-09 04:01:49.266 HD Request # 56 | Completion time: 2s | 2020-06-09 04:01:49.267 HD Request # 56 | Intraday data download complete for ZBU0-CBOT. Unique request ID: 52 | 2020-06-09 04:01:49.267 Removing historical data download ID 52. | 2020-06-09 04:01:49.267 Real-time Intraday chart data file updates started for ZBU0-CBOT | 2020-06-09 04:01:49.267 Intraday chart data file opened for ZBU0-CBOT | 2020-06-09 04:01:49.267 HD Request # 56 | Enabling Intraday chart updating for symbol. | 2020-06-09 04:01:49.267 Rithmic Trading | Using primary service for historical data for ZBU0-CBOT | 2020-06-09 04:01:49.267 Added historical Intraday data request for ZBU0-CBOT to the queue. | 2020-06-09 04:01:49.267 Intraday data recording state for symbol ZBU0-CBOT is set to download 'Pending'. | 2020-06-09 04:01:49.267 Triggering next historical data download in queue. | 2020-06-09 04:01:49.267 Triggering next historical data download in queue. | 2020-06-09 04:01:49.267 HD Request # 57 | Downloading Intraday chart data for ZBU0-CBOT to the file ZBU0-CBOT.scid. Service: rithmic.trading | 2020-06-09 04:01:49.267 HD Request # 57 | Download start date-time: 2020-06-09 03:51:38.000 | 2020-06-09 04:01:49.267 HD Request # 57 | Sending historical data request. Start date-time: 2020-06-09 03:51:38. Record interval: 0. Symbol: ZBU0-CBOT | 2020-06-09 04:01:49.267 HD Request # 58 | Downloading Intraday chart data for 6JM0-CME to the file 6JM0-CME.scid. Service: cme | 2020-06-09 04:01:49.267 HD Request # 58 | Download start date-time: 2020-06-09 04:00:55.000 | 2020-06-09 04:01:49.267 HD Request # 58 | Using server: ds21.sierracharts.com port 10150 | 2020-06-09 04:01:49.267 Socket (4) | Creating socket. | 2020-06-09 04:01:49.268 Socket (4) | Connecting to IP: 216.1.90.129. | 2020-06-09 04:01:49.268 Rithmic Trading | Message from server: Requesting historical Tick data. | 2020-06-09 04:01:49.268 Chart #8 has tagged chart #16 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:49.482 HD Request # 57 | Error downloading historical Intraday data for ZBU0-CBOT. Error downloading historical Tick data. Error: permission denied | 2020-06-09 04:01:49.552 HD Request # 57 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ZBU0-CBOT | 2020-06-09 04:01:49.552 HD Request # 57 | Completion time: 0s | 2020-06-09 04:01:49.552 HD Request # 57 | Intraday data download complete for ZBU0-CBOT. Unique request ID: 61 | 2020-06-09 04:01:49.552 Removing historical data download ID 61. | 2020-06-09 04:01:49.552 Real-time Intraday chart data file updates started for ZBU0-CBOT | 2020-06-09 04:01:49.552 Intraday chart data file opened for ZBU0-CBOT | 2020-06-09 04:01:49.552 HD Request # 57 | Enabling Intraday chart updating for symbol. | 2020-06-09 04:01:49.552 Triggering next historical data download in queue. | 2020-06-09 04:01:49.552 Socket (3) | Socket gracefully closed by remote side. | 2020-06-09 04:01:49.559 Socket (3) | Closed. | 2020-06-09 04:01:49.559 HD Request # 58 | Setting DTC encoding to Binary VLS | 2020-06-09 04:01:49.846 HD Request # 58 | Sending historical data logon request message. | 2020-06-09 04:01:49.847 Opened cached Intraday file: C:\SierraChart\Data\RTYM0-CME.scid. Thread ID: 18844 | 2020-06-09 04:01:49.959 GCJ1-COMEX 5 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:49.979 Chart #8 has tagged chart #16 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:49.984 HD Request # 58 | Requesting Intraday data. Start date-time: 2020-06-09 04:00:55. Record interval: 0. Symbol: 6JM20 | 2020-06-09 04:01:50.132 HD Request # 58 | Decompressing data. | 2020-06-09 04:01:50.412 HD Request # 58 | Receiving Intraday data for 6JM0-CME starting at 2020-06-09 04:00:55 | 2020-06-09 04:01:50.413 Socket (4) | CloseSocket call. | 2020-06-09 04:01:50.415 Socket (4) | Shutdown started. Waiting for graceful close. | 2020-06-09 04:01:50.415 Historical data download thread signaled to stop. | 2020-06-09 04:01:50.415 HD Request # 58 | Timestamp of first Intraday data file record written: 2020-06-09 04:00:58 | 2020-06-09 04:01:50.415 HD Request # 58 | Received 42 records from 2020-06-09 04:00:55.000 to 2020-06-09 04:01:46.001 (51.0 seconds) and wrote 39 records for 6JM0-CME | 2020-06-09 04:01:50.416 HD Request # 58 | Completion time: 1s | 2020-06-09 04:01:50.416 HD Request # 58 | Intraday data download complete for 6JM0-CME. Unique request ID: 53 | 2020-06-09 04:01:50.416 Removing historical data download ID 53. | 2020-06-09 04:01:50.416 Real-time Intraday chart data file updates started for 6JM0-CME | 2020-06-09 04:01:50.416 Intraday chart data file opened for 6JM0-CME | 2020-06-09 04:01:50.416 HD Request # 58 | Enabling Intraday chart updating for symbol. | 2020-06-09 04:01:50.416 Rithmic Trading | Using primary service for historical data for 6JM0-CME | 2020-06-09 04:01:50.416 Added historical Intraday data request for 6JM0-CME to the queue. | 2020-06-09 04:01:50.416 Intraday data recording state for symbol 6JM0-CME is set to download 'Pending'. | 2020-06-09 04:01:50.416 Triggering next historical data download in queue. | 2020-06-09 04:01:50.416 Triggering next historical data download in queue. | 2020-06-09 04:01:50.416 HD Request # 59 | Downloading Intraday chart data for 6JM0-CME to the file 6JM0-CME.scid. Service: rithmic.trading | 2020-06-09 04:01:50.416 HD Request # 59 | Download start date-time: 2020-06-09 04:01:46.000 | 2020-06-09 04:01:50.417 HD Request # 59 | Sending historical data request. Start date-time: 2020-06-09 04:01:46. Record interval: 0. Symbol: 6JM0-CME | 2020-06-09 04:01:50.417 HD Request # 60 | Downloading Intraday chart data for USDX to the file USDX.scid. Service: fxstatscalc | 2020-06-09 04:01:50.417 HD Request # 60 | Download start date-time: 2020-06-09 04:00:57.000 | 2020-06-09 04:01:50.418 HD Request # 60 | Using server: ds4.sierracharts.com port 10149 | 2020-06-09 04:01:50.419 Socket (3) | Creating socket. | 2020-06-09 04:01:50.419 Socket (3) | Connecting to IP: 192.81.56.146. | 2020-06-09 04:01:50.419 Rithmic Trading | Message from server: Requesting historical Tick data. | 2020-06-09 04:01:50.419 GCJ1-COMEX 5 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:50.483 Chart #9 has tagged chart #16 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:50.487 Socket (4) | Socket gracefully closed by remote side. | 2020-06-09 04:01:50.699 Socket (4) | Closed. | 2020-06-09 04:01:50.699 HD Request # 59 | Receiving Intraday data for 6JM0-CME starting at 2020-06-09 04:01:46 | 2020-06-09 04:01:50.748 HD Request # 59 | Received 2 records from 2020-06-09 04:01:46.000 to 2020-06-09 04:01:46.001 (0.0 seconds) and wrote 0 records for 6JM0-CME | 2020-06-09 04:01:50.748 HD Request # 59 | Completion time: 0s | 2020-06-09 04:01:50.749 HD Request # 59 | Intraday data download complete for 6JM0-CME. Unique request ID: 62 | 2020-06-09 04:01:50.749 Removing historical data download ID 62. | 2020-06-09 04:01:50.749 Real-time Intraday chart data file updates started for 6JM0-CME | 2020-06-09 04:01:50.749 Intraday chart data file opened for 6JM0-CME | 2020-06-09 04:01:50.749 HD Request # 59 | Enabling Intraday chart updating for symbol. | 2020-06-09 04:01:50.749 Triggering next historical data download in queue. | 2020-06-09 04:01:50.749 HD Request # 60 | Setting DTC encoding to Binary VLS | 2020-06-09 04:01:50.972 HD Request # 60 | Sending historical data logon request message. | 2020-06-09 04:01:50.972 GCJ1-COMEX 5 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:50.987 Chart #9 has tagged chart #16 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:50.997 GCJ1-COMEX 5 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:51.471 HD Request # 60 | Requesting Intraday data. Start date-time: 2020-06-09 04:00:57. Record interval: 0. Symbol: USDX | 2020-06-09 04:01:51.741 HD Request # 60 | Decompressing data. | 2020-06-09 04:01:52.032 HD Request # 60 | Receiving Intraday data for USDX starting at 2020-06-09 04:00:57 | 2020-06-09 04:01:52.032 Socket (3) | CloseSocket call. | 2020-06-09 04:01:52.032 Socket (3) | Shutdown started. Waiting for graceful close. | 2020-06-09 04:01:52.032 Historical data download thread signaled to stop. | 2020-06-09 04:01:52.032 HD Request # 60 | Timestamp of first Intraday data file record written: 2020-06-09 04:00:58 | 2020-06-09 04:01:52.032 HD Request # 60 | Received 55 records from 2020-06-09 04:00:57.000 to 2020-06-09 04:01:51.000 (54.0 seconds) and wrote 54 records for USDX | 2020-06-09 04:01:52.032 Added 3 Time and Sales records to Intraday data file for USDX after download. | 2020-06-09 04:01:52.033 HD Request # 60 | Completion time: 2s | 2020-06-09 04:01:52.033 HD Request # 60 | Intraday data download complete for USDX. Unique request ID: 54 | 2020-06-09 04:01:52.033 Removing historical data download ID 54. | 2020-06-09 04:01:52.033 Real-time Intraday chart data file updates started for USDX | 2020-06-09 04:01:52.033 Intraday chart data file opened for USDX | 2020-06-09 04:01:52.033 HD Request # 60 | Enabling Intraday chart updating for symbol. | 2020-06-09 04:01:52.033 Triggering next historical data download in queue. | 2020-06-09 04:01:52.033 HD Request # 61 | Downloading Intraday chart data for SIN0-COMEX to the file SIN0-COMEX.scid. Service: comex | 2020-06-09 04:01:52.033 HD Request # 61 | Download start date-time: 2020-06-09 04:00:56.000 | 2020-06-09 04:01:52.033 HD Request # 61 | Using server: ds23.sierracharts.com port 10150 | 2020-06-09 04:01:52.033 Socket (4) | Creating socket. | 2020-06-09 04:01:52.033 Socket (4) | Connecting to IP: 216.1.90.130. | 2020-06-09 04:01:52.033 Socket (3) | Socket gracefully closed by remote side. | 2020-06-09 04:01:52.303 Socket (3) | Closed. | 2020-06-09 04:01:52.304 Chart #12 has tagged chart #16 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:52.476 HD Request # 61 | Setting DTC encoding to Binary VLS | 2020-06-09 04:01:52.623 HD Request # 61 | Sending historical data logon request message. | 2020-06-09 04:01:52.623 GCJ1-COMEX 5 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:52.974 HD Request # 61 | Requesting Intraday data. Start date-time: 2020-06-09 04:00:56. Record interval: 0. Symbol: SIN20 | 2020-06-09 04:01:53.374 HD Request # 61 | Decompressing data. | 2020-06-09 04:01:53.663 Socket (4) | CloseSocket call. | 2020-06-09 04:01:53.663 Socket (4) | Shutdown started. Waiting for graceful close. | 2020-06-09 04:01:53.664 Historical data download thread signaled to stop. | 2020-06-09 04:01:53.676 HD Request # 61 | Received 1 record from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for SIN0-COMEX | 2020-06-09 04:01:53.676 HD Request # 61 | Completion time: 1s | 2020-06-09 04:01:53.676 HD Request # 61 | Intraday data download complete for SIN0-COMEX. Unique request ID: 55 | 2020-06-09 04:01:53.676 Removing historical data download ID 55. | 2020-06-09 04:01:53.676 Real-time Intraday chart data file updates started for SIN0-COMEX | 2020-06-09 04:01:53.676 Intraday chart data file opened for SIN0-COMEX | 2020-06-09 04:01:53.676 HD Request # 61 | Enabling Intraday chart updating for symbol. | 2020-06-09 04:01:53.676 Rithmic Trading | Using primary service for historical data for SIN0-COMEX | 2020-06-09 04:01:53.676 Added historical Intraday data request for SIN0-COMEX to the queue. | 2020-06-09 04:01:53.676 Intraday data recording state for symbol SIN0-COMEX is set to download 'Pending'. | 2020-06-09 04:01:53.676 Triggering next historical data download in queue. | 2020-06-09 04:01:53.676 Triggering next historical data download in queue. | 2020-06-09 04:01:53.676 HD Request # 62 | Downloading Intraday chart data for SIN0-COMEX to the file SIN0-COMEX.scid. Service: rithmic.trading | 2020-06-09 04:01:53.676 HD Request # 62 | Download start date-time: 2020-06-09 04:00:56.000 | 2020-06-09 04:01:53.676 HD Request # 62 | Sending historical data request. Start date-time: 2020-06-09 04:00:56. Record interval: 0. Symbol: SIN0-COMEX | 2020-06-09 04:01:53.676 HD Request # 63 | Downloading Intraday chart data for ESM0-CME to the file ESM0-CME.scid. Service: cme | 2020-06-09 04:01:53.676 HD Request # 63 | Download start date-time: 2020-06-09 04:00:57.000 | 2020-06-09 04:01:53.676 HD Request # 63 | Using server: ds21.sierracharts.com port 10149 | 2020-06-09 04:01:53.676 Socket (3) | Creating socket. | 2020-06-09 04:01:53.677 Socket (3) | Connecting to IP: 216.1.90.129. | 2020-06-09 04:01:53.677 Rithmic Trading | Message from server: Requesting historical Tick data. | 2020-06-09 04:01:53.678 Socket (4) | Socket gracefully closed by remote side. | 2020-06-09 04:01:53.967 Socket (4) | Closed. | 2020-06-09 04:01:53.967 HD Request # 62 | Receiving Intraday data for SIN0-COMEX starting at 2020-06-09 04:00:56 | 2020-06-09 04:01:53.996 HD Request # 62 | Timestamp of first Intraday data file record written: 2020-06-09 04:01:07 | 2020-06-09 04:01:53.997 HD Request # 62 | Received 5 records from 2020-06-09 04:00:56.000 to 2020-06-09 04:01:47.000 (51.0 seconds) and wrote 4 records for SIN0-COMEX | 2020-06-09 04:01:53.997 HD Request # 62 | Completion time: 0s | 2020-06-09 04:01:53.997 HD Request # 62 | Intraday data download complete for SIN0-COMEX. Unique request ID: 63 | 2020-06-09 04:01:53.997 Removing historical data download ID 63. | 2020-06-09 04:01:53.997 Real-time Intraday chart data file updates started for SIN0-COMEX | 2020-06-09 04:01:53.997 Intraday chart data file opened for SIN0-COMEX | 2020-06-09 04:01:53.997 HD Request # 62 | Enabling Intraday chart updating for symbol. | 2020-06-09 04:01:53.997 Triggering next historical data download in queue. | 2020-06-09 04:01:53.997 HD Request # 63 | Setting DTC encoding to Binary VLS | 2020-06-09 04:01:54.273 HD Request # 63 | Sending historical data logon request message. | 2020-06-09 04:01:54.273 Opened cached Intraday file: C:\SierraChart\Data\6JM0-CME.scid. Thread ID: 18844 | 2020-06-09 04:01:54.989 Opened cached Intraday file: C:\SierraChart\Data\USDX.scid. Thread ID: 18844 | 2020-06-09 04:01:54.989 HD Request # 63 | Requesting Intraday data. Start date-time: 2020-06-09 04:00:57. Record interval: 0. Symbol: ESM20 | 2020-06-09 04:01:55.002 HD Request # 63 | Decompressing data. | 2020-06-09 04:01:55.282 HD Request # 63 | Receiving Intraday data for ESM0-CME starting at 2020-06-09 04:00:57 | 2020-06-09 04:01:55.282 Socket (3) | CloseSocket call. | 2020-06-09 04:01:55.285 Socket (3) | Shutdown started. Waiting for graceful close. | 2020-06-09 04:01:55.285 Historical data download thread signaled to stop. | 2020-06-09 04:01:55.285 HD Request # 63 | Timestamp of first Intraday data file record written: 2020-06-09 04:00:58 | 2020-06-09 04:01:55.285 HD Request # 63 | Received 394 records from 2020-06-09 04:00:57.000 to 2020-06-09 04:01:52.027 (55.0 seconds) and wrote 392 records for ESM0-CME | 2020-06-09 04:01:55.286 HD Request # 63 | Completion time: 2s | 2020-06-09 04:01:55.286 HD Request # 63 | Intraday data download complete for ESM0-CME. Unique request ID: 56 | 2020-06-09 04:01:55.286 Removing historical data download ID 56. | 2020-06-09 04:01:55.286 Real-time Intraday chart data file updates started for ESM0-CME | 2020-06-09 04:01:55.286 Intraday chart data file opened for ESM0-CME | 2020-06-09 04:01:55.286 HD Request # 63 | Enabling Intraday chart updating for symbol. | 2020-06-09 04:01:55.286 Rithmic Trading | Using primary service for historical data for ESM0-CME | 2020-06-09 04:01:55.286 Added historical Intraday data request for ESM0-CME to the queue. | 2020-06-09 04:01:55.286 Intraday data recording state for symbol ESM0-CME is set to download 'Pending'. | 2020-06-09 04:01:55.286 Triggering next historical data download in queue. | 2020-06-09 04:01:55.287 Triggering next historical data download in queue. | 2020-06-09 04:01:55.287 HD Request # 64 | Downloading Intraday chart data for ESM0-CME to the file ESM0-CME.scid. Service: rithmic.trading | 2020-06-09 04:01:55.287 HD Request # 64 | Download start date-time: 2020-06-09 04:01:52.000 | 2020-06-09 04:01:55.288 HD Request # 64 | Sending historical data request. Start date-time: 2020-06-09 04:01:52. Record interval: 0. Symbol: ESM0-CME | 2020-06-09 04:01:55.288 Rithmic Trading | Message from server: Requesting historical Tick data. | 2020-06-09 04:01:55.293 Chart #33 has tagged chart #1 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:55.487 Chart #33 has tagged chart #2 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:55.487 Chart #33 has tagged chart #36 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:55.487 Socket (3) | Socket gracefully closed by remote side. | 2020-06-09 04:01:55.589 Socket (3) | Closed. | 2020-06-09 04:01:55.589 ESM0-CME 2.50 Range #2 | Performing a full recalculation because it has been tagged. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:55.631 Chart #2 has tagged chart #17 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:55.701 Chart #2 has tagged chart #6 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:55.701 ESM0-CME 1.25 Range #36 | Performing a full recalculation because it has been tagged. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:55.719 Chart #36 has tagged chart #1 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:55.799 ESM0-CME Rev. 5t #1 | Performing a full recalculation because it has been tagged. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:55.816 Chart #41 has tagged chart #1 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:55.916 HD Request # 64 | Receiving Intraday data for ESM0-CME starting at 2020-06-09 04:01:52 | 2020-06-09 04:01:55.921 HD Request # 64 | Received 28 records from 2020-06-09 04:01:52.000 to 2020-06-09 04:01:52.027 (0.0 seconds) and wrote 0 records for ESM0-CME | 2020-06-09 04:01:55.921 HD Request # 64 | Completion time: 0s | 2020-06-09 04:01:55.921 HD Request # 64 | Intraday data download complete for ESM0-CME. Unique request ID: 64 | 2020-06-09 04:01:55.921 Removing historical data download ID 64. | 2020-06-09 04:01:55.921 Real-time Intraday chart data file updates started for ESM0-CME | 2020-06-09 04:01:55.921 Intraday chart data file opened for ESM0-CME | 2020-06-09 04:01:55.921 HD Request # 64 | Enabling Intraday chart updating for symbol. | 2020-06-09 04:01:55.921 Triggering next historical data download in queue. | 2020-06-09 04:01:55.921 Chart #33 has tagged chart #1 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:55.987 Chart #33 has tagged chart #2 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:55.987 Chart #33 has tagged chart #36 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:55.987 ESM0-CME 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:55.987 ESM0-CME #6 | Performing a full recalculation because it has been tagged. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:55.992 ESM0-CME 2.50 Range #2 | Performing a full recalculation because it has been tagged. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:56.127 Chart #2 has tagged chart #17 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:56.204 Chart #2 has tagged chart #6 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:56.204 ESM0-CME 1.25 Range #36 | Performing a full recalculation because it has been tagged. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:56.223 Chart #36 has tagged chart #1 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:56.302 ESM0-CME Rev. 5t #1 | Performing a full recalculation because it has been tagged. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:56.318 Chart #41 has tagged chart #1 for full recalculation. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:56.415 ESM0-CME 1 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:56.473 ESM0-CME #6 | Performing a full recalculation because it has been tagged. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:56.477 ESM0-CME Rev. 5t #1 | Performing a full recalculation because it has been tagged. Chartbook: gauntlet ES Template1.Cht | 2020-06-09 04:01:56.704 Opened cached Intraday file: C:\SierraChart\Data\ESM0-CME.scid. Thread ID: 18844 | 2020-06-09 04:02:00.041 Opened cached Intraday file: C:\SierraChart\Data\SIN0-COMEX.scid. Thread ID: 18844 | 2020-06-09 04:02:00.042 |
[2020-06-09 08:17:56] |
You are already paying for the Denali data feed so you should use it for at least for this month. The problem is this: Allow Support for Sierra Chart Data Feeds is disabled. | 2020-06-09 04:01:08.310 You need to enable: "Global Settings >> Data/Trade Service Settings >> Allow Support for Sierra Chart Data Feeds" And then reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-09 08:18:32
[2020-06-09 08:27:05] |
User888645 - Posts: 11 |
thank you thank you thank you ....you are a STAR awesome sorted When my denali feed expires should i renew or will the rithmic feed support this market depth |
