Date/Time: Sun, 05 May 2024 10:51:22 +0000
Cme data delayed
View Count: 629
[2020-06-01 20:13:39] |
User483148 - Posts: 3 |
Tried that several times, live trading account with rithmic. I have logged in once or twice prior to this month with no problems. For some reason was unable to connect to rithmic server. I will try again.
[2020-06-02 05:00:21] |
Refer to: Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward You really need to use this solution: Easy Solution to CME Funded Trading Account Requirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
