Date/Time: Sat, 18 May 2024 09:27:08 +0000
Failure to connect to Rythmic Trader
View Count: 1408
[2020-06-01 01:44:31] |
Chikot - Posts: 21 |
Hello. I have been trading with Sierra Chart for 3 weeks now and there has been no issue connecting to Rhythmic when Rhythmic is off. Suddenly I cannot connect and I receive message: Rithmic Trading / Logon error received from Server. All credentials are same and Rithmic is working fine when I login. |
[2020-06-01 01:45:31] |
Refer to this post here: Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-01 02:01:34] |
Thank you. I moved all those files into Rim folder. Restarted PC. Still cannot login. Same message. Do those files install automatically or I have to do something else after moving them from this site to Rim folder? Still cannot log in.
[2020-06-01 02:34:14] |
It is just a matter of saving the individual files using the same file names as they exist in the support board posting for them, in the Rim subfolder in the Sierra Chart installation folder.
[2020-06-01 06:02:29] |
Ok, I have saved all these files in the Rim folder in Sierra Chart folder, but actually all these files were already there. Then I entered Sierra Chart, , entered DownloadedInstallation files , entered Rim subfolder and moved these files directly from site to that subfolder by moving them with mouse and they were saved. So, I have these files in 2 Rim folders and still cannot log in. I am with Mes capital. No broker. All theese files already were there before I got log in problem. They were there before I contacted them in Sierra Chart , Rim subfolder, but not in Sierra Chart , Downlodded Installation files, Rim subfolder. Now files ar ein both Rim subfolders.
[2020-06-01 07:08:28] |
I completelly deleted Sierra Chart. Downloaded both new and now prep release versions. downloaded files from the board I was told. Created Rim folder both in Sierra Chart and Sierra Chart Downlow installation files folders, saved first all four files to Browser and then moved them to Rim folders. It is not working. I cannot log in. I am with Mess capital. |
[2020-06-01 07:28:49] |
Make sure the certificate files, have no file extension.
[2020-06-01 09:14:21] |
What does it mean file extensions? There were (1) after each file. I deleted all by renaming. Still cannot log in. Now files end like this: cert_auth_params, client_params, client_private_key. DTCBridge looks like colored cubes with no exe extension after it. |
[2020-06-01 09:18:04] |
Reading Internal Order ID file. | 2020-06-01 09:16:45.532 Reading Trade Orders file. | 2020-06-01 09:16:45.672 Reading Trade Positions file. | 2020-06-01 09:16:45.672 Reading Account Balance file. | 2020-06-01 09:16:45.673 UDPListener (1364). Port 22904 | Listening on UDP port 22904. | 2020-06-01 09:16:45.697 Software version: 2115 64-bit | 2020-06-01 09:16:45.697 Primary Thread ID: 7860 | 2020-06-01 09:16:45.697 Usage end date: 2020-06-09 | 2020-06-01 09:16:45.697 Enabled for: Sierra Chart Historical Data Service. | 2020-06-01 09:16:45.697 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-06-01 09:16:45.697 Allow Support for Sierra Chart Data Feeds is enabled. | 2020-06-01 09:16:45.697 Current selected Data/Trading service: Rithmic Trading | 2020-06-01 09:16:45.697 Custom symbol settings values: enabled | 2020-06-01 09:16:45.697 Chart Update Interval: 500 | 2020-06-01 09:16:45.697 Intraday Data Storage Time Unit: 1 | 2020-06-01 09:16:45.697 Time Zone: +00:00:00 (UTC+00) | 2020-06-01 09:16:45.697 2020-06-01 05:16:45 Local computer time | 2020-06-01 09:16:45.697 2020-06-01 09:16:45 Local computer time in UTC | 2020-06-01 09:16:45.697 2020-06-01 09:16:45 Local computer time in SC Time Zone | 2020-06-01 09:16:45.697 2020-06-01 09:16:46 Server time in UTC | 2020-06-01 09:16:45.697 Local computer UTC time and Server UTC time difference: 1 seconds. | 2020-06-01 09:16:45.697 Program path: D:\SierraChart\ | 2020-06-01 09:16:45.697 Data Files path: D:\SierraChart\Data\ | 2020-06-01 09:16:45.697 OS Version Number: 10.0 | 2020-06-01 09:16:45.697 Locale Setting: C | 2020-06-01 09:16:45.697 Allowed protected custom studies: | 2020-06-01 09:16:45.697 Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic.trading. Request ID: 1. | 2020-06-01 09:16:45.715 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 09:16:45.749 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-06-01 09:16:45.854 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-06-01 09:16:45.854 Received 5 login tokens. | 2020-06-01 09:16:46.132 Symbol settings MD5 received. Request ID: 1. | 2020-06-01 09:16:46.290 Symbol settings are up-to-date for rithmic.trading. | 2020-06-01 09:16:46.290 Files to Open on Start up | Opening file: ExampleChartbook.cht | 2020-06-01 09:16:49.192 Rithmic Trading | Port for executable: 57552 | 2020-06-01 09:16:51.195 Listening socket (1008). Port 57552 | Closed. | 2020-06-01 09:16:51.195 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 09:16:51.196 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57552. Current folder: D:\SierraChart\Rim | 2020-06-01 09:16:51.204 Rithmic Trading | Bridge process is running. | 2020-06-01 09:16:53.191 Rithmic Trading | Connecting to the server 127.0.0.1. Port 57552 | 2020-06-01 09:16:53.191 DTC Client socket (1) | Creating socket. | 2020-06-01 09:16:53.191 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 09:16:53.192 Rithmic Trading | Connected to server. | 2020-06-01 09:16:53.193 Rithmic Trading | Starting socket receive thread. | 2020-06-01 09:16:53.193 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 09:16:53.193 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 09:16:53.194 Rithmic Trading | Sending logon request message. | 2020-06-01 09:16:53.194 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 09:16:53.195 Rithmic Trading | Message from server: Logging is enabled. Log file: D:\SierraChart\Rim\Rithmic.log | 2020-06-01 09:16:53.196 Rithmic Trading | Message from server: Connecting to Rithmic MES Capital server. | 2020-06-01 09:16:53.196 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2020-06-01 09:16:53.490 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2020-06-01 09:16:53.508 Rithmic Trading | Received logon response. | 2020-06-01 09:16:53.508 Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 09:16:53.508 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 09:16:53.508 Rithmic Trading | Logon error received from server | 2020-06-01 09:16:53.508 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 09:16:53.508 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 09:16:53.508 DTC Client socket (1) | CloseSocket call. | 2020-06-01 09:16:53.522 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 09:16:53.522 Rithmic Trading | Disconnected. | 2020-06-01 09:16:53.522 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 09:16:53.522 Rithmic Trading | Port for executable: 57563 | 2020-06-01 09:16:55.521 Listening socket (1396). Port 57563 | Closed. | 2020-06-01 09:16:55.521 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 09:16:55.522 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57563. Current folder: D:\SierraChart\Rim | 2020-06-01 09:16:55.530 DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 09:16:56.265 DTC Client socket (1) | Closed. | 2020-06-01 09:16:56.265 Rithmic Trading | Bridge process is not running! | 2020-06-01 09:16:57.521 Rithmic Trading | Connecting to the server 127.0.0.1. Port 57563 | 2020-06-01 09:16:57.521 DTC Client socket (1) | Creating socket. | 2020-06-01 09:16:57.521 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 09:16:57.521 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 09:16:59.525 * DTC Client socket (1) | CloseSocket call. | 2020-06-01 09:16:59.525 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 09:16:59.525 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 09:16:59.525 DTC Client socket (1) | Closed. | 2020-06-01 09:16:59.525 DTC Client socket (0) | CloseSocket call. | 2020-06-01 09:16:59.535 Rithmic Trading | Disconnected. | 2020-06-01 09:16:59.535 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 09:16:59.535 Rithmic Trading | Port for executable: 57565 | 2020-06-01 09:17:01.547 Listening socket (1396). Port 57565 | Closed. | 2020-06-01 09:17:01.547 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 09:17:01.548 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57565. Current folder: D:\SierraChart\Rim | 2020-06-01 09:17:01.556 Rithmic Trading | Bridge process is running. | 2020-06-01 09:17:03.550 Rithmic Trading | Connecting to the server 127.0.0.1. Port 57565 | 2020-06-01 09:17:03.550 DTC Client socket (1) | Creating socket. | 2020-06-01 09:17:03.550 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 09:17:03.551 Rithmic Trading | Connected to server. | 2020-06-01 09:17:03.552 Rithmic Trading | Starting socket receive thread. | 2020-06-01 09:17:03.552 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 09:17:03.552 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 09:17:03.553 Rithmic Trading | Sending logon request message. | 2020-06-01 09:17:03.553 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 09:17:03.554 Rithmic Trading | Message from server: Logging is enabled. Log file: D:\SierraChart\Rim\Rithmic.log | 2020-06-01 09:17:03.555 Rithmic Trading | Message from server: Connecting to Rithmic MES Capital server. | 2020-06-01 09:17:03.555 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2020-06-01 09:17:03.820 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2020-06-01 09:17:03.839 Rithmic Trading | Received logon response. | 2020-06-01 09:17:03.839 Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 09:17:03.839 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 09:17:03.839 Rithmic Trading | Logon error received from server | 2020-06-01 09:17:03.839 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 09:17:03.839 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 09:17:03.839 DTC Client socket (1) | CloseSocket call. | 2020-06-01 09:17:03.865 Rithmic Trading | Disconnected. | 2020-06-01 09:17:03.865 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 09:17:03.865 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 09:17:03.865 Rithmic Trading | Port for executable: 57575 | 2020-06-01 09:17:05.865 Listening socket (1044). Port 57575 | Closed. | 2020-06-01 09:17:05.865 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 09:17:05.866 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57575. Current folder: D:\SierraChart\Rim | 2020-06-01 09:17:05.875 DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 09:17:06.612 DTC Client socket (1) | Closed. | 2020-06-01 09:17:06.612 Rithmic Trading | Bridge process is not running! | 2020-06-01 09:17:07.863 Rithmic Trading | Connecting to the server 127.0.0.1. Port 57575 | 2020-06-01 09:17:07.863 DTC Client socket (1) | Creating socket. | 2020-06-01 09:17:07.863 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 09:17:07.863 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 09:17:09.864 * DTC Client socket (1) | CloseSocket call. | 2020-06-01 09:17:09.864 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 09:17:09.864 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 09:17:09.864 DTC Client socket (1) | Closed. | 2020-06-01 09:17:09.864 DTC Client socket (0) | CloseSocket call. | 2020-06-01 09:17:09.885 Rithmic Trading | Disconnected. | 2020-06-01 09:17:09.885 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 09:17:09.885 Rithmic Trading | Port for executable: 57577 | 2020-06-01 09:17:11.893 Listening socket (1432). Port 57577 | Closed. | 2020-06-01 09:17:11.893 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 09:17:11.894 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57577. Current folder: D:\SierraChart\Rim | 2020-06-01 09:17:11.902 |
[2020-06-01 10:35:48] |
Hello, I have tried many times and did everything I was told to do and it is not working. It was fine just on Saturday when I logged last time. I really need someone from Sierra chart to help me with this issue asap. Thank you. |
[2020-06-01 12:13:20] |
Thank you. it is working now
[2020-06-01 12:57:12] |
User644928 - Posts: 4 |
Im having the same issue.. How did you make it work?
[2020-06-01 13:34:40] |
I completely uninstalled Sierra chart few times, then downloaded the latest version and followed instructions to save 4 files. I did it many times, but it only worked after 7:00 a.m. EST
[2020-06-01 18:19:51] |
Regarding post #9 and post #13 you are getting a permission denied error: Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2020-06-01 09:17:03.839
You need to contact your broker for help with this. I really need someone from Sierra chart to help me with this issue asap. This was never within our control.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-01 18:20:47
[2020-06-07 22:34:09] |
Hello, I am having same issue now. What was the problem last time? I am not with broker but Oneup trader. Is that issue from their side? |
[2020-06-07 22:41:47] |
Looks like rhythmic cannot login either. will have to wait.
[2020-06-08 02:47:00] |
Refer to this thread for the updated files needed: Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-08 09:55:13] |
Are these files new and updated? Are they are different from files available last weekend because last weekend I already downloaded and installed in RIM files with same names?
[2020-06-08 10:33:11] |
No. Therefore we need to see the Message Log to see what the problem is. Instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Select File >> Connect to Data Feed. After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-08 11:28:19] |
Reading Internal Order ID file. | 2020-06-08 11:25:35.280 Reading Trade Orders file. | 2020-06-08 11:25:35.401 Reading Trade Positions file. | 2020-06-08 11:25:35.401 Reading Account Balance file. | 2020-06-08 11:25:35.402 UDPListener (1392). Port 22904 | Listening on UDP port 22904. | 2020-06-08 11:25:35.424 Software version: 2115 64-bit | 2020-06-08 11:25:35.425 Primary Thread ID: 18208 | 2020-06-08 11:25:35.425 Usage end date: 2020-07-09 | 2020-06-08 11:25:35.425 Enabled for: Sierra Chart Historical Data Service. | 2020-06-08 11:25:35.425 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-06-08 11:25:35.425 Allow Support for Sierra Chart Data Feeds is enabled. | 2020-06-08 11:25:35.425 Current selected Data/Trading service: Rithmic Trading | 2020-06-08 11:25:35.425 Custom symbol settings values: enabled | 2020-06-08 11:25:35.425 Chart Update Interval: 500 | 2020-06-08 11:25:35.425 Intraday Data Storage Time Unit: 1 | 2020-06-08 11:25:35.425 Time Zone: +00:00:00 (UTC+00) | 2020-06-08 11:25:35.425 2020-06-08 07:25:35 Local computer time | 2020-06-08 11:25:35.425 2020-06-08 11:25:35 Local computer time in UTC | 2020-06-08 11:25:35.425 2020-06-08 11:25:35 Local computer time in SC Time Zone | 2020-06-08 11:25:35.425 2020-06-08 11:25:35 Server time in UTC | 2020-06-08 11:25:35.425 Local computer UTC time and Server UTC time difference: 0 seconds. | 2020-06-08 11:25:35.425 Program path: D:\SierraChart\ | 2020-06-08 11:25:35.425 Data Files path: D:\SierraChart\Data\ | 2020-06-08 11:25:35.425 OS Version Number: 10.0 | 2020-06-08 11:25:35.425 Locale Setting: C | 2020-06-08 11:25:35.425 Allowed protected custom studies: | 2020-06-08 11:25:35.425 Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic.trading. Request ID: 1. | 2020-06-08 11:25:35.438 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-06-08 11:25:35.497 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-06-08 11:25:35.622 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-06-08 11:25:35.622 Received 5 login tokens. | 2020-06-08 11:25:35.797 Symbol settings MD5 received. Request ID: 1. | 2020-06-08 11:25:35.995 Symbol settings are up-to-date for rithmic.trading. | 2020-06-08 11:25:35.995 Files to Open on Start up | Opening file: ExampleChartbook.cht | 2020-06-08 11:25:38.908 CLN0-NYMEX #1 | Reloading chart. | 2020-06-08 11:25:39.113 CLN0-NYMEX #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-06-08 11:25:39.113 CLN0-NYMEX 5 Min #2 | Reloading chart. | 2020-06-08 11:25:39.150 CLN0-NYMEX 15 Min #3 | Reloading chart. | 2020-06-08 11:25:39.192 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: CLN0-NYMEX | 2020-06-08 11:25:39.611 Starting DelayedDownloadMonitoringTimer | 2020-06-08 11:25:39.611 Starting HDTimeoutTimer | 2020-06-08 11:25:39.611 Added historical Intraday data request for CLN0-NYMEX to the queue. | 2020-06-08 11:25:39.611 Intraday data recording state for symbol CLN0-NYMEX is set to download 'Pending'. | 2020-06-08 11:25:39.611 Triggering next historical data download in queue. | 2020-06-08 11:25:39.611 HD Request # 1 | Downloading Intraday chart data for CLN0-NYMEX to the file CLN0-NYMEX.scid. Service: nymex | 2020-06-08 11:25:39.617 HD Request # 1 | Download start date-time: 2020-06-08 10:00:13.000 | 2020-06-08 11:25:39.617 HD Request # 1 | Using server: ds23.sierracharts.com port 10149 | 2020-06-08 11:25:39.617 Socket (1) | Creating socket. | 2020-06-08 11:25:39.618 Socket (1) | Connecting to IP: 216.1.90.130. | 2020-06-08 11:25:39.618 HD Request # 1 | Setting DTC encoding to Binary VLS | 2020-06-08 11:25:39.665 HD Request # 1 | Sending historical data logon request message. | 2020-06-08 11:25:39.665 HD Request # 1 | Requesting Intraday data. Start date-time: 2020-06-08 10:00:13. Record interval: 1. Symbol: CLN20 | 2020-06-08 11:25:40.132 HD Request # 1 | Decompressing data. | 2020-06-08 11:25:40.151 HD Request # 1 | Receiving Intraday data for CLN0-NYMEX starting at 2020-06-08 10:00:13 | 2020-06-08 11:25:40.182 Socket (1) | CloseSocket call. | 2020-06-08 11:25:40.183 HD Request # 1 | Historical data for CLN0-NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2020-06-08 11:25:40.183 Historical data download thread signaled to stop. | 2020-06-08 11:25:40.183 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-08 11:25:40.183 HD Request # 1 | Timestamp of first Intraday data file record written: 2020-06-08 10:00:13 | 2020-06-08 11:25:40.184 HD Request # 1 | Received 1834 records from 2020-06-08 10:00:13.000 to 2020-06-08 11:15:38.000 (75.4 minutes) and wrote 1834 records for CLN0-NYMEX | 2020-06-08 11:25:40.184 HD Request # 1 | Completion time: 1s | 2020-06-08 11:25:40.184 HD Request # 1 | Intraday data download complete for CLN0-NYMEX. Unique request ID: 1 | 2020-06-08 11:25:40.184 Removing historical data download ID 1. | 2020-06-08 11:25:40.184 HD Request # 1 | Enabling Intraday chart updating for symbol. | 2020-06-08 11:25:40.184 Rithmic Trading | Using primary service for historical data for CLN0-NYMEX | 2020-06-08 11:25:40.184 HD Request # 1 | Download from primary service not started due to error. | 2020-06-08 11:25:40.184 Triggering next historical data download in queue. | 2020-06-08 11:25:40.184 Socket (1) | Socket gracefully closed by remote side. | 2020-06-08 11:25:40.201 Socket (1) | Closed. | 2020-06-08 11:25:40.201 Rithmic Trading | Port for executable: 50137 | 2020-06-08 11:25:41.206 Listening socket (1436). Port 50137 | Closed. | 2020-06-08 11:25:41.206 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-08 11:25:41.207 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50137. Current folder: D:\SierraChart\Rim | 2020-06-08 11:25:41.215 Rithmic Trading | Bridge process is running. | 2020-06-08 11:25:43.203 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50137 | 2020-06-08 11:25:43.203 DTC Client socket (1) | Creating socket. | 2020-06-08 11:25:43.204 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-08 11:25:43.204 Rithmic Trading | Connected to server. | 2020-06-08 11:25:43.205 Rithmic Trading | Starting socket receive thread. | 2020-06-08 11:25:43.205 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-08 11:25:43.205 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-08 11:25:43.206 Rithmic Trading | Sending logon request message. | 2020-06-08 11:25:43.206 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-08 11:25:43.207 Rithmic Trading | Message from server: Logging is enabled. Log file: D:\SierraChart\Rim\Rithmic.log | 2020-06-08 11:25:43.208 Rithmic Trading | Message from server: Connecting to Rithmic MES Capital server. | 2020-06-08 11:25:43.208 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2020-06-08 11:25:48.660 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2020-06-08 11:25:48.680 Rithmic Trading | Received logon response. | 2020-06-08 11:25:48.680 Rithmic Trading | Server Name: DTC Bridge. | 2020-06-08 11:25:48.680 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-08 11:25:48.680 Rithmic Trading | Logon error received from server | 2020-06-08 11:25:48.680 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-08 11:25:48.680 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:25:48.680 DTC Client socket (1) | CloseSocket call. | 2020-06-08 11:25:48.741 Rithmic Trading | Disconnected. | 2020-06-08 11:25:48.741 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:25:48.741 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-08 11:25:48.742 Rithmic Trading | Port for executable: 50147 | 2020-06-08 11:25:50.747 Listening socket (1468). Port 50147 | Closed. | 2020-06-08 11:25:50.747 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-08 11:25:50.747 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50147. Current folder: D:\SierraChart\Rim | 2020-06-08 11:25:50.756 Rithmic Trading | Bridge process is not running! | 2020-06-08 11:25:52.759 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50147 | 2020-06-08 11:25:52.759 DTC Client socket (2) | Creating socket. | 2020-06-08 11:25:52.760 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-08 11:25:52.760 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-08 11:25:54.763 * DTC Client socket (2) | CloseSocket call. | 2020-06-08 11:25:54.763 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-08 11:25:54.763 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:25:54.763 DTC Client socket (2) | Closed. | 2020-06-08 11:25:54.763 DTC Client socket (0) | CloseSocket call. | 2020-06-08 11:25:54.766 Rithmic Trading | Disconnected. | 2020-06-08 11:25:54.767 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:25:54.767 Rithmic Trading | Port for executable: 50151 | 2020-06-08 11:25:56.767 Listening socket (1396). Port 50151 | Closed. | 2020-06-08 11:25:56.767 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-08 11:25:56.768 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50151. Current folder: D:\SierraChart\Rim | 2020-06-08 11:25:56.777 Rithmic Trading | Bridge process is not running! | 2020-06-08 11:25:58.766 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50151 | 2020-06-08 11:25:58.766 DTC Client socket (2) | Creating socket. | 2020-06-08 11:25:58.766 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-08 11:25:58.766 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-08 11:26:00.768 * DTC Client socket (2) | CloseSocket call. | 2020-06-08 11:26:00.768 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-08 11:26:00.768 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:26:00.768 DTC Client socket (2) | Closed. | 2020-06-08 11:26:00.768 DTC Client socket (0) | CloseSocket call. | 2020-06-08 11:26:00.789 Rithmic Trading | Disconnected. | 2020-06-08 11:26:00.789 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:26:00.789 Rithmic Trading | Port for executable: 50153 | 2020-06-08 11:26:03.098 Listening socket (1480). Port 50153 | Closed. | 2020-06-08 11:26:03.098 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-08 11:26:03.099 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50153. Current folder: D:\SierraChart\Rim | 2020-06-08 11:26:03.106 Rithmic Trading | Bridge process is not running! | 2020-06-08 11:26:05.093 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50153 | 2020-06-08 11:26:05.093 DTC Client socket (2) | Creating socket. | 2020-06-08 11:26:05.093 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-08 11:26:05.093 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-08 11:26:07.096 * DTC Client socket (2) | CloseSocket call. | 2020-06-08 11:26:07.096 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-08 11:26:07.096 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:26:07.096 DTC Client socket (2) | Closed. | 2020-06-08 11:26:07.097 DTC Client socket (0) | CloseSocket call. | 2020-06-08 11:26:07.113 Rithmic Trading | Disconnected. | 2020-06-08 11:26:07.114 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:26:07.114 Rithmic Trading | Port for executable: 50155 | 2020-06-08 11:26:09.118 Listening socket (1440). Port 50155 | Closed. | 2020-06-08 11:26:09.118 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-08 11:26:09.119 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50155. Current folder: D:\SierraChart\Rim | 2020-06-08 11:26:09.127 Rithmic Trading | Bridge process is not running! | 2020-06-08 11:26:11.128 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50155 | 2020-06-08 11:26:11.128 DTC Client socket (2) | Creating socket. | 2020-06-08 11:26:11.128 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-08 11:26:11.129 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-08 11:26:11.303 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-08 11:26:11.303 DTC Client socket (1) | Closed. | 2020-06-08 11:26:11.303 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-08 11:26:13.130 * DTC Client socket (2) | CloseSocket call. | 2020-06-08 11:26:13.130 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-08 11:26:13.130 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:26:13.130 DTC Client socket (2) | Closed. | 2020-06-08 11:26:13.130 DTC Client socket (0) | CloseSocket call. | 2020-06-08 11:26:13.140 Rithmic Trading | Disconnected. | 2020-06-08 11:26:13.140 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:26:13.140 Rithmic Trading | Port for executable: 50158 | 2020-06-08 11:26:15.142 Listening socket (1480). Port 50158 | Closed. | 2020-06-08 11:26:15.142 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-08 11:26:15.142 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50158. Current folder: D:\SierraChart\Rim | 2020-06-08 11:26:15.151 Rithmic Trading | Bridge process is running. | 2020-06-08 11:26:17.141 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50158 | 2020-06-08 11:26:17.141 DTC Client socket (1) | Creating socket. | 2020-06-08 11:26:17.141 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-08 11:26:17.141 Rithmic Trading | Connected to server. | 2020-06-08 11:26:17.143 Rithmic Trading | Starting socket receive thread. | 2020-06-08 11:26:17.143 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-08 11:26:17.143 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-08 11:26:17.144 Rithmic Trading | Sending logon request message. | 2020-06-08 11:26:17.144 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-08 11:26:17.145 Rithmic Trading | Message from server: Logging is enabled. Log file: D:\SierraChart\Rim\Rithmic.log | 2020-06-08 11:26:17.146 Rithmic Trading | Message from server: Connecting to Rithmic MES Capital server. | 2020-06-08 11:26:17.146 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2020-06-08 11:26:17.397 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2020-06-08 11:26:17.417 Rithmic Trading | Received logon response. | 2020-06-08 11:26:17.417 Rithmic Trading | Server Name: DTC Bridge. | 2020-06-08 11:26:17.417 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-08 11:26:17.417 Rithmic Trading | Logon error received from server | 2020-06-08 11:26:17.417 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-08 11:26:17.417 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:26:17.417 DTC Client socket (1) | CloseSocket call. | 2020-06-08 11:26:17.437 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-08 11:26:17.437 Rithmic Trading | Disconnected. | 2020-06-08 11:26:17.437 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:26:17.437 Rithmic Trading | Port for executable: 50168 | 2020-06-08 11:26:19.442 Listening socket (1396). Port 50168 | Closed. | 2020-06-08 11:26:19.442 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-08 11:26:19.443 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50168. Current folder: D:\SierraChart\Rim | 2020-06-08 11:26:19.450 DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-08 11:26:20.211 DTC Client socket (1) | Closed. | 2020-06-08 11:26:20.211 Rithmic Trading | Bridge process is not running! | 2020-06-08 11:26:21.448 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50168 | 2020-06-08 11:26:21.448 DTC Client socket (1) | Creating socket. | 2020-06-08 11:26:21.448 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-08 11:26:21.448 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-08 11:26:23.451 * DTC Client socket (1) | CloseSocket call. | 2020-06-08 11:26:23.451 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-08 11:26:23.451 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:26:23.451 DTC Client socket (1) | Closed. | 2020-06-08 11:26:23.451 DTC Client socket (0) | CloseSocket call. | 2020-06-08 11:26:23.455 Rithmic Trading | Disconnected. | 2020-06-08 11:26:23.455 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:26:23.455 Rithmic Trading | Port for executable: 50170 | 2020-06-08 11:26:25.455 Listening socket (1424). Port 50170 | Closed. | 2020-06-08 11:26:25.455 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-08 11:26:25.456 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50170. Current folder: D:\SierraChart\Rim | 2020-06-08 11:26:25.464 Rithmic Trading | Bridge process is running. | 2020-06-08 11:26:27.453 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50170 | 2020-06-08 11:26:27.453 DTC Client socket (1) | Creating socket. | 2020-06-08 11:26:27.453 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-08 11:26:27.453 Rithmic Trading | Connected to server. | 2020-06-08 11:26:27.454 Rithmic Trading | Starting socket receive thread. | 2020-06-08 11:26:27.454 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-08 11:26:27.454 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-08 11:26:27.456 Rithmic Trading | Sending logon request message. | 2020-06-08 11:26:27.456 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-08 11:26:27.457 Rithmic Trading | Message from server: Logging is enabled. Log file: D:\SierraChart\Rim\Rithmic.log | 2020-06-08 11:26:27.458 Rithmic Trading | Message from server: Connecting to Rithmic MES Capital server. | 2020-06-08 11:26:27.458 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2020-06-08 11:26:27.724 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2020-06-08 11:26:27.745 Rithmic Trading | Received logon response. | 2020-06-08 11:26:27.745 Rithmic Trading | Server Name: DTC Bridge. | 2020-06-08 11:26:27.745 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-08 11:26:27.745 Rithmic Trading | Logon error received from server | 2020-06-08 11:26:27.745 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-08 11:26:27.745 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:26:27.745 DTC Client socket (1) | CloseSocket call. | 2020-06-08 11:26:27.751 Rithmic Trading | Disconnected. | 2020-06-08 11:26:27.751 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:26:27.751 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-08 11:26:27.752 Rithmic Trading | Port for executable: 50180 | 2020-06-08 11:26:29.750 Listening socket (1480). Port 50180 | Closed. | 2020-06-08 11:26:29.750 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-08 11:26:29.751 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50180. Current folder: D:\SierraChart\Rim | 2020-06-08 11:26:29.759 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-08 11:26:30.523 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-08 11:26:30.523 DTC Client socket (1) | Closed. | 2020-06-08 11:26:30.523 Rithmic Trading | Bridge process is not running! | 2020-06-08 11:26:31.749 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50180 | 2020-06-08 11:26:31.749 DTC Client socket (1) | Creating socket. | 2020-06-08 11:26:31.749 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-08 11:26:31.749 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-08 11:26:33.754 * DTC Client socket (1) | CloseSocket call. | 2020-06-08 11:26:33.755 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-08 11:26:33.755 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:26:33.755 DTC Client socket (1) | Closed. | 2020-06-08 11:26:33.755 DTC Client socket (0) | CloseSocket call. | 2020-06-08 11:26:33.765 Rithmic Trading | Disconnected. | 2020-06-08 11:26:33.765 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:26:33.765 Rithmic Trading | Port for executable: 50185 | 2020-06-08 11:26:35.769 Listening socket (1504). Port 50185 | Closed. | 2020-06-08 11:26:35.769 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-08 11:26:35.770 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50185. Current folder: D:\SierraChart\Rim | 2020-06-08 11:26:35.778 Rithmic Trading | Bridge process is running. | 2020-06-08 11:26:37.764 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50185 | 2020-06-08 11:26:37.764 DTC Client socket (1) | Creating socket. | 2020-06-08 11:26:37.764 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-08 11:26:37.764 Rithmic Trading | Connected to server. | 2020-06-08 11:26:37.765 Rithmic Trading | Starting socket receive thread. | 2020-06-08 11:26:37.765 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-08 11:26:37.765 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-08 11:26:37.767 Rithmic Trading | Sending logon request message. | 2020-06-08 11:26:37.767 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-08 11:26:37.768 Rithmic Trading | Message from server: Logging is enabled. Log file: D:\SierraChart\Rim\Rithmic.log | 2020-06-08 11:26:37.769 Rithmic Trading | Message from server: Connecting to Rithmic MES Capital server. | 2020-06-08 11:26:37.769 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2020-06-08 11:26:38.016 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2020-06-08 11:26:38.035 Rithmic Trading | Received logon response. | 2020-06-08 11:26:38.035 Rithmic Trading | Server Name: DTC Bridge. | 2020-06-08 11:26:38.035 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-08 11:26:38.035 Rithmic Trading | Logon error received from server | 2020-06-08 11:26:38.035 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-08 11:26:38.035 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:26:38.035 DTC Client socket (1) | CloseSocket call. | 2020-06-08 11:26:38.055 Rithmic Trading | Disconnected. | 2020-06-08 11:26:38.055 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:26:38.055 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-08 11:26:38.055 Rithmic Trading | Port for executable: 50196 | 2020-06-08 11:26:40.053 Listening socket (1508). Port 50196 | Closed. | 2020-06-08 11:26:40.053 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-08 11:26:40.053 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50196. Current folder: D:\SierraChart\Rim | 2020-06-08 11:26:40.062 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-08 11:26:40.843 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-08 11:26:40.843 DTC Client socket (1) | Closed. | 2020-06-08 11:26:40.843 Rithmic Trading | Bridge process is not running! | 2020-06-08 11:26:42.075 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50196 | 2020-06-08 11:26:42.075 DTC Client socket (1) | Creating socket. | 2020-06-08 11:26:42.075 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-08 11:26:42.076 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-08 11:26:44.077 * DTC Client socket (1) | CloseSocket call. | 2020-06-08 11:26:44.077 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-08 11:26:44.077 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:26:44.077 DTC Client socket (1) | Closed. | 2020-06-08 11:26:44.077 DTC Client socket (0) | CloseSocket call. | 2020-06-08 11:26:44.096 Rithmic Trading | Disconnected. | 2020-06-08 11:26:44.096 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:26:44.096 Rithmic Trading | Port for executable: 50198 | 2020-06-08 11:26:46.096 Listening socket (972). Port 50198 | Closed. | 2020-06-08 11:26:46.096 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-08 11:26:46.097 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50198. Current folder: D:\SierraChart\Rim | 2020-06-08 11:26:46.106 Rithmic Trading | Bridge process is running. | 2020-06-08 11:26:48.095 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50198 | 2020-06-08 11:26:48.095 DTC Client socket (1) | Creating socket. | 2020-06-08 11:26:48.095 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-08 11:26:48.096 Rithmic Trading | Connected to server. | 2020-06-08 11:26:48.097 Rithmic Trading | Starting socket receive thread. | 2020-06-08 11:26:48.097 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-08 11:26:48.097 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-08 11:26:48.098 Rithmic Trading | Sending logon request message. | 2020-06-08 11:26:48.098 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-08 11:26:48.098 Rithmic Trading | Message from server: Logging is enabled. Log file: D:\SierraChart\Rim\Rithmic.log | 2020-06-08 11:26:48.100 Rithmic Trading | Message from server: Connecting to Rithmic MES Capital server. | 2020-06-08 11:26:48.100 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2020-06-08 11:26:48.345 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2020-06-08 11:26:48.363 Rithmic Trading | Received logon response. | 2020-06-08 11:26:48.363 Rithmic Trading | Server Name: DTC Bridge. | 2020-06-08 11:26:48.363 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-08 11:26:48.363 Rithmic Trading | Logon error received from server | 2020-06-08 11:26:48.363 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-08 11:26:48.363 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:26:48.363 DTC Client socket (1) | CloseSocket call. | 2020-06-08 11:26:48.374 Rithmic Trading | Disconnected. | 2020-06-08 11:26:48.375 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:26:48.375 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-08 11:26:48.375 Rithmic Trading | Port for executable: 50208 | 2020-06-08 11:26:50.377 Listening socket (1508). Port 50208 | Closed. | 2020-06-08 11:26:50.377 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-08 11:26:50.378 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50208. Current folder: D:\SierraChart\Rim | 2020-06-08 11:26:50.386 DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-08 11:26:51.164 DTC Client socket (1) | Closed. | 2020-06-08 11:26:51.164 Rithmic Trading | Bridge process is not running! | 2020-06-08 11:26:52.375 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50208 | 2020-06-08 11:26:52.375 DTC Client socket (1) | Creating socket. | 2020-06-08 11:26:52.375 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-08 11:26:52.375 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-08 11:26:54.377 * DTC Client socket (1) | CloseSocket call. | 2020-06-08 11:26:54.378 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-08 11:26:54.378 DTC Client socket (1) | Closed. | 2020-06-08 11:26:54.378 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:26:54.378 DTC Client socket (0) | CloseSocket call. | 2020-06-08 11:26:54.391 Rithmic Trading | Disconnected. | 2020-06-08 11:26:54.391 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:26:54.391 Rithmic Trading | Port for executable: 50210 | 2020-06-08 11:26:56.394 Listening socket (972). Port 50210 | Closed. | 2020-06-08 11:26:56.394 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-08 11:26:56.395 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50210. Current folder: D:\SierraChart\Rim | 2020-06-08 11:26:56.406 Rithmic Trading | Bridge process is running. | 2020-06-08 11:26:58.407 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50210 | 2020-06-08 11:26:58.407 DTC Client socket (1) | Creating socket. | 2020-06-08 11:26:58.407 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-08 11:26:58.407 Rithmic Trading | Connected to server. | 2020-06-08 11:26:58.408 Rithmic Trading | Starting socket receive thread. | 2020-06-08 11:26:58.408 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-08 11:26:58.408 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-08 11:26:58.410 Rithmic Trading | Sending logon request message. | 2020-06-08 11:26:58.410 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-08 11:26:58.411 Rithmic Trading | Message from server: Logging is enabled. Log file: D:\SierraChart\Rim\Rithmic.log | 2020-06-08 11:26:58.412 Rithmic Trading | Message from server: Connecting to Rithmic MES Capital server. | 2020-06-08 11:26:58.412 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2020-06-08 11:26:58.651 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2020-06-08 11:26:58.670 Rithmic Trading | Received logon response. | 2020-06-08 11:26:58.670 Rithmic Trading | Server Name: DTC Bridge. | 2020-06-08 11:26:58.670 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-08 11:26:58.670 Rithmic Trading | Logon error received from server | 2020-06-08 11:26:58.670 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-08 11:26:58.670 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:26:58.670 DTC Client socket (1) | CloseSocket call. | 2020-06-08 11:26:58.688 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-08 11:26:58.688 Rithmic Trading | Disconnected. | 2020-06-08 11:26:58.688 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:26:58.688 Rithmic Trading | Port for executable: 50220 | 2020-06-08 11:27:00.692 Listening socket (1464). Port 50220 | Closed. | 2020-06-08 11:27:00.692 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-08 11:27:00.693 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50220. Current folder: D:\SierraChart\Rim | 2020-06-08 11:27:00.701 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-08 11:27:01.468 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-08 11:27:01.468 DTC Client socket (1) | Closed. | 2020-06-08 11:27:01.468 Rithmic Trading | Bridge process is not running! | 2020-06-08 11:27:02.687 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50220 | 2020-06-08 11:27:02.687 DTC Client socket (1) | Creating socket. | 2020-06-08 11:27:02.687 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-08 11:27:02.687 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-08 11:27:04.691 * DTC Client socket (1) | CloseSocket call. | 2020-06-08 11:27:04.691 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-08 11:27:04.691 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:27:04.691 DTC Client socket (1) | Closed. | 2020-06-08 11:27:04.691 DTC Client socket (0) | CloseSocket call. | 2020-06-08 11:27:04.704 Rithmic Trading | Disconnected. | 2020-06-08 11:27:04.704 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:27:04.705 Rithmic Trading | Port for executable: 50222 | 2020-06-08 11:27:06.705 Listening socket (1512). Port 50222 | Closed. | 2020-06-08 11:27:06.705 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-08 11:27:06.706 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50222. Current folder: D:\SierraChart\Rim | 2020-06-08 11:27:06.714 Rithmic Trading | Bridge process is running. | 2020-06-08 11:27:08.702 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50222 | 2020-06-08 11:27:08.702 DTC Client socket (1) | Creating socket. | 2020-06-08 11:27:08.702 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-08 11:27:08.703 Rithmic Trading | Connected to server. | 2020-06-08 11:27:08.704 Rithmic Trading | Starting socket receive thread. | 2020-06-08 11:27:08.704 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-08 11:27:08.704 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-08 11:27:08.705 Rithmic Trading | Sending logon request message. | 2020-06-08 11:27:08.705 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-08 11:27:08.706 Rithmic Trading | Message from server: Logging is enabled. Log file: D:\SierraChart\Rim\Rithmic.log | 2020-06-08 11:27:08.707 Rithmic Trading | Message from server: Connecting to Rithmic MES Capital server. | 2020-06-08 11:27:08.707 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2020-06-08 11:27:08.965 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2020-06-08 11:27:08.987 Rithmic Trading | Received logon response. | 2020-06-08 11:27:08.987 Rithmic Trading | Server Name: DTC Bridge. | 2020-06-08 11:27:08.987 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-08 11:27:08.987 Rithmic Trading | Logon error received from server | 2020-06-08 11:27:08.987 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-08 11:27:08.987 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:27:08.987 DTC Client socket (1) | CloseSocket call. | 2020-06-08 11:27:09.008 Rithmic Trading | Disconnected. | 2020-06-08 11:27:09.008 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:27:09.008 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-08 11:27:09.008 Rithmic Trading | Port for executable: 50232 | 2020-06-08 11:27:11.002 Listening socket (1516). Port 50232 | Closed. | 2020-06-08 11:27:11.003 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-08 11:27:11.003 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50232. Current folder: D:\SierraChart\Rim | 2020-06-08 11:27:11.011 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-08 11:27:11.779 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-08 11:27:11.779 DTC Client socket (1) | Closed. | 2020-06-08 11:27:11.779 Rithmic Trading | Bridge process is not running! | 2020-06-08 11:27:13.002 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50232 | 2020-06-08 11:27:13.002 DTC Client socket (1) | Creating socket. | 2020-06-08 11:27:13.002 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-08 11:27:13.002 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-08 11:27:15.003 * DTC Client socket (1) | CloseSocket call. | 2020-06-08 11:27:15.003 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-08 11:27:15.003 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:27:15.003 DTC Client socket (1) | Closed. | 2020-06-08 11:27:15.003 DTC Client socket (0) | CloseSocket call. | 2020-06-08 11:27:15.014 Rithmic Trading | Disconnected. | 2020-06-08 11:27:15.014 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:27:15.015 Rithmic Trading | Port for executable: 50235 | 2020-06-08 11:27:17.016 Listening socket (1496). Port 50235 | Closed. | 2020-06-08 11:27:17.017 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-08 11:27:17.017 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50235. Current folder: D:\SierraChart\Rim | 2020-06-08 11:27:17.026 Rithmic Trading | Bridge process is running. | 2020-06-08 11:27:19.014 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50235 | 2020-06-08 11:27:19.014 DTC Client socket (1) | Creating socket. | 2020-06-08 11:27:19.014 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-08 11:27:19.014 Rithmic Trading | Connected to server. | 2020-06-08 11:27:19.015 Rithmic Trading | Starting socket receive thread. | 2020-06-08 11:27:19.015 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-08 11:27:19.015 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-08 11:27:19.017 Rithmic Trading | Sending logon request message. | 2020-06-08 11:27:19.017 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-08 11:27:19.018 Rithmic Trading | Message from server: Logging is enabled. Log file: D:\SierraChart\Rim\Rithmic.log | 2020-06-08 11:27:19.019 Rithmic Trading | Message from server: Connecting to Rithmic MES Capital server. | 2020-06-08 11:27:19.019 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2020-06-08 11:27:19.273 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2020-06-08 11:27:19.291 Rithmic Trading | Received logon response. | 2020-06-08 11:27:19.291 Rithmic Trading | Server Name: DTC Bridge. | 2020-06-08 11:27:19.291 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-08 11:27:19.291 Rithmic Trading | Logon error received from server | 2020-06-08 11:27:19.291 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-08 11:27:19.291 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:27:19.291 DTC Client socket (1) | CloseSocket call. | 2020-06-08 11:27:19.302 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-08 11:27:19.302 Rithmic Trading | Disconnected. | 2020-06-08 11:27:19.303 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:27:19.303 Rithmic Trading | Port for executable: 50246 | 2020-06-08 11:27:21.299 Listening socket (1512). Port 50246 | Closed. | 2020-06-08 11:27:21.299 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-08 11:27:21.299 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50246. Current folder: D:\SierraChart\Rim | 2020-06-08 11:27:21.308 DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-08 11:27:22.087 DTC Client socket (1) | Closed. | 2020-06-08 11:27:22.087 Rithmic Trading | Bridge process is not running! | 2020-06-08 11:27:23.295 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50246 | 2020-06-08 11:27:23.295 DTC Client socket (1) | Creating socket. | 2020-06-08 11:27:23.296 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-08 11:27:23.296 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-08 11:27:25.297 * DTC Client socket (1) | CloseSocket call. | 2020-06-08 11:27:25.298 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-08 11:27:25.298 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:27:25.298 DTC Client socket (1) | Closed. | 2020-06-08 11:27:25.298 DTC Client socket (0) | CloseSocket call. | 2020-06-08 11:27:25.318 Rithmic Trading | Disconnected. | 2020-06-08 11:27:25.318 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:27:25.318 Rithmic Trading | Port for executable: 50249 | 2020-06-08 11:27:27.314 Listening socket (1500). Port 50249 | Closed. | 2020-06-08 11:27:27.314 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-08 11:27:27.314 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50249. Current folder: D:\SierraChart\Rim | 2020-06-08 11:27:27.322 Rithmic Trading | Bridge process is running. | 2020-06-08 11:27:29.313 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50249 | 2020-06-08 11:27:29.313 DTC Client socket (1) | Creating socket. | 2020-06-08 11:27:29.313 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-08 11:27:29.313 Rithmic Trading | Connected to server. | 2020-06-08 11:27:29.314 Rithmic Trading | Starting socket receive thread. | 2020-06-08 11:27:29.314 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-08 11:27:29.314 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-08 11:27:29.316 Rithmic Trading | Sending logon request message. | 2020-06-08 11:27:29.316 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-08 11:27:29.316 Rithmic Trading | Message from server: Logging is enabled. Log file: D:\SierraChart\Rim\Rithmic.log | 2020-06-08 11:27:29.318 Rithmic Trading | Message from server: Connecting to Rithmic MES Capital server. | 2020-06-08 11:27:29.318 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2020-06-08 11:27:29.564 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2020-06-08 11:27:29.587 Rithmic Trading | Received logon response. | 2020-06-08 11:27:29.587 Rithmic Trading | Server Name: DTC Bridge. | 2020-06-08 11:27:29.587 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-08 11:27:29.587 Rithmic Trading | Logon error received from server | 2020-06-08 11:27:29.587 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-08 11:27:29.587 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:27:29.587 DTC Client socket (1) | CloseSocket call. | 2020-06-08 11:27:29.598 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-08 11:27:29.598 Rithmic Trading | Disconnected. | 2020-06-08 11:27:29.598 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:27:29.598 Rithmic Trading | Port for executable: 50260 | 2020-06-08 11:27:31.599 Listening socket (972). Port 50260 | Closed. | 2020-06-08 11:27:31.599 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-08 11:27:31.600 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50260. Current folder: D:\SierraChart\Rim | 2020-06-08 11:27:31.608 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-08 11:27:32.385 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-08 11:27:32.385 DTC Client socket (1) | Closed. | 2020-06-08 11:27:32.385 Rithmic Trading | Bridge process is not running! | 2020-06-08 11:27:33.607 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50260 | 2020-06-08 11:27:33.608 DTC Client socket (1) | Creating socket. | 2020-06-08 11:27:33.608 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-08 11:27:33.608 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-08 11:27:35.609 * DTC Client socket (1) | CloseSocket call. | 2020-06-08 11:27:35.609 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-08 11:27:35.609 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:27:35.609 DTC Client socket (1) | Closed. | 2020-06-08 11:27:35.609 DTC Client socket (0) | CloseSocket call. | 2020-06-08 11:27:35.627 Rithmic Trading | Disconnected. | 2020-06-08 11:27:35.627 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-08 11:27:35.627 Rithmic Trading | Port for executable: 50263 | 2020-06-08 11:27:37.630 Listening socket (1416). Port 50263 | Closed. | 2020-06-08 11:27:37.631 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-08 11:27:37.631 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50263. Current folder: D:\SierraChart\Rim | 2020-06-08 11:27:37.639 |
[2020-06-08 11:47:34] |
This is the relevant message: Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2020-06-08 11:26:58.670 You need to contact your broker about this. And also please be aware we are working on a replacement, for these trading evaluator/funding companies. Support for all of those is fully terminated at the end of this year. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-08 11:50:14] |
Chikot - Posts: 21 |
Thank you. I already did contact MES capital. Rhythmic won't connect.
[2020-06-08 11:54:49] |
"And also please be aware we are working on a replacement, for these trading evaluator/funding companies. Support for all of those is fully terminated at the end of this year. " Doe sit mean that at the end of the year I will not be able to use Sierra Chart while trading with MES capital? |
[2020-06-08 19:24:53] |
You will still be able to with an older version of Sierra Chart at that time but that is not going to be indefinite.
