Date/Time: Sat, 11 May 2024 21:48:01 +0000
It is possible to invert the ratio study?
View Count: 605
[2020-05-31 18:35:22] |
skelcap - Posts: 139 |
I want to be able to invert the ratio study, so that Chart 1 is the denominator and Chart 2 the numerator.
[2020-06-01 06:12:07] |
In this case, you just add the Ratio study on Chart 2 and reference Chart 1 from the study.
[2020-06-02 01:36:12] |
Yes but I want the ratio study overlaid on Chart 1.
[2020-06-04 06:38:21] |
Here are other methods to accomplish this: Using the Basic Arithmetic Studies Custom Calculated Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
