Date/Time: Mon, 13 May 2024 06:38:53 +0000
TIME SCALE NOT MATCHING UP WITH SESSION TIMES
View Count: 659
[2020-05-20 14:46:13] |
bluejune - Posts: 34 |
Hi, I have a candlestick set to 1 day with the session times from 09:30:00 to 16:00:00 ... The chart time when the market opens, today on 5/20, is showing 13:30:00. Any idea on why my 1 day chart is not being displayed as 9:30-16:00? http://www.sierrachart.com/image.php?Image=1589985864774.png (posted 5/20 at 10:45am) |
sierra #2.jpg / V - Attached On 2020-05-20 14:31:44 UTC - Size: 630.26 KB - 235 views Attachment Deleted. |
[2020-05-20 19:45:28] |
Your session times are not what you are stating. Take a look again at them, and be sure to consider the Evening Session times as well. Refer to the information here on Session Times: Chart Session Times If you think there is still an issue, then we will need to see the Chart Settings Window to see how you have your Session times setup. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-20 20:25:00] |
I've read the directions but still can not figure out why there is a problem. When I open Sierra Charts for the first time, the cart will have a time displaying 09:30:00-16:00:00 but as soon as a change the symbol then the starting time on the chart still shows 13:00:00. I've attached a picture of my settings. |
CHART SETTINGS.jpg / V - Attached On 2020-05-20 20:24:50 UTC - Size: 417.77 KB - 273 views Attachment Deleted. |
[2020-05-20 22:22:24] |
What is the time zone of that chart set to? Refer to this page for instructions: Time Zone Setting You can set a time zone individually on the chart and also globally. The chart can have its own time zone or use the global time zone. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-21 14:45:09] |
Changing the time zone fixed it. Thank you |
