Date/Time: Sun, 26 May 2024 13:41:05 +0000
inconsistencies of data
View Count: 477
[2020-05-19 13:17:04] |
User996274 - Posts: 80 |
I have 2 SC charts running 1 with IB data 1 with rithmic for some reason they become out of whack with one another once i reload the charts the realign is there a fix for this? I am using a vol per bar charts my vol bars are not consistent but should be when i reload the charts the vol becomes consistent on both data platforms Ive run into the same problem with cqg to further add to the mystery I have rithmic data on a "funded" sim account that has consistent vol candles or is there a method to periodically auto reload and recalculate (as that seems to fix the problem temporarily) Date Time Of Last Edit: 2020-05-19 18:15:54
[2020-05-19 18:57:58] |
You need to use the Denali Exchange Data Feed with Interactive Brokers instead of Rithmic: Denali Exchange Data Feed Refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services Sierra Chart does not provide support for Rithmic. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-19 18:58:46
