Date/Time: Sat, 11 May 2024 09:46:58 +0000
Numbers column too wide
View Count: 602
[2020-05-15 17:23:50] |
user2837 - Posts: 76 |
You can see that the numbers column is too wide (see attachment). A screenshot is attached. The link through the Edit menu is not working. I have consulted your documentation here (Graphics Settings: Chart Bar Widths) and here (Getting Started, Opening Charts and Basic Trading: Additional Steps)(items 8 and 9) and was unable to fix the issue. Date Time Of Last Edit: 2020-05-15 18:01:35
Screenshot (13).png / V - Attached On 2020-05-15 17:25:10 UTC - Size: 86.8 KB - 245 views |
[2020-05-15 19:11:50] |
That is just due to the number of bars that are drawn in the chart. You need to reduce the bar spacing in the chart. Refer to the information here: Working With Charts: Changing Bar Spacing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-15 19:26:18] |
I have tried that and it does not quite fix the problem. ssFST.png is as far as I can get and the columns are still too fat. If I adjust the bar spacing lower (using anyone of the three methods) the numbers become crushed vertically as in ssSND.png (even with the columns being quite wide). If I then try to zoom out vertically (using interactive scaling), the columns zoom out horizontally again and become fat.
[2020-05-15 19:30:22] |
You also need to decrease the vertical price range with Interactive Scale Range: Chart Scale and Scale Adjusting: Scale Range (Scale Settings) And make sure you are not using a X and Y constant relationship scale: Chart Scale and Scale Adjusting: X & Y Constant Relationship Scaling It sounds like you might be. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-15 19:31:12
[2020-05-15 19:50:35] |
Thank you! Having an x and y constant relationship was the issue and it is now fixed.
