Date/Time: Sat, 18 May 2024 15:56:52 +0000
Problem with orders placement and cancellation against TRansact
View Count: 525
[2020-04-13 07:23:53] |
Meklon - Posts: 218 |
Hello Support, I just upgraded Sierra from version 2066 to 2083 and now experiencing issues with order cancellation placed from the chart. When order is canceled (regardless if this is a single order or an attached order, the main order remains on the chart for at least 90 seconds before disappearing and also generate errors in the Trade log (see below). This was not happening in the version 2066. I am using Denali data feed and connecting to a Transact Sim account. Requesting order status for non-responsive order. | Symbol: ESM0 | TradeAccount: [Sim]40557 | InternalOrderID: 62855 | Current Status: Order Sent | 2020-04-13 03:15:37.508 * Requesting order status for non-responsive order. | Symbol: ESM0 | TradeAccount: [Sim]40557 | InternalOrderID: 62858 | Current Status: Order Sent | 2020-04-13 03:15:37.508 * Requesting order status for non-responsive order. | Symbol: ESM0 | TradeAccount: [Sim]40557 | InternalOrderID: 62861 | Current Status: Order Sent | 2020-04-13 03:15:37.508 * Trading server did not acknowledge new order | Symbol: ESM0 | TradeAccount: [Sim]40557 | InternalOrderID: 62855 | Current Status: Order Sent | 2020-04-13 03:15:39.442 * Trading server did not acknowledge new order | Symbol: ESM0 | TradeAccount: [Sim]40557 | InternalOrderID: 62858 | Current Status: Order Sent | 2020-04-13 03:15:39.442 * Trading server did not acknowledge new order | Symbol: ESM0 | TradeAccount: [Sim]40557 | InternalOrderID: 62861 | Current Status: Order Sent | 2020-04-13 03:15:39.442 * Order cancellation failed | Still awaiting acknowledgment of new order. Unable to cancel order. Internal Order ID: 62867. Service Order ID: (none). Symbol: ESM0. Account: [Sim]40557 | 2020-04-13 03:16:33.643 * Order cancellation failed | Still awaiting acknowledgment of new order. Unable to cancel order. Internal Order ID: 62870. Service Order ID: (none). Symbol: ESM0. Account: [Sim]40557 | 2020-04-13 03:16:33.643 * Order cancellation failed | Still awaiting acknowledgment of new order. Unable to cancel order. Internal Order ID: 62873. Service Order ID: (none). Symbol: ESM0. Account: [Sim]40557 | 2020-04-13 03:16:33.644 * Requesting order status for non-responsive order. | Symbol: ESM0 | TradeAccount: [Sim]40557 | InternalOrderID: 62867 | Current Status: Order Sent | 2020-04-13 03:17:37.413 * Requesting order status for non-responsive order. | Symbol: ESM0 | TradeAccount: [Sim]40557 | InternalOrderID: 62870 | Current Status: Order Sent | 2020-04-13 03:17:37.413 * Requesting order status for non-responsive order. | Symbol: ESM0 | TradeAccount: [Sim]40557 | InternalOrderID: 62873 | Current Status: Order Sent | 2020-04-13 03:17:37.413 * Trading server did not acknowledge new order | Symbol: ESM0 | TradeAccount: [Sim]40557 | InternalOrderID: 62867 | Current Status: Order Sent | 2020-04-13 03:17:38.954 * Trading server did not acknowledge new order | Symbol: ESM0 | TradeAccount: [Sim]40557 | InternalOrderID: 62870 | Current Status: Order Sent | 2020-04-13 03:17:38.954 * Trading server did not acknowledge new order | Symbol: ESM0 | TradeAccount: [Sim]40557 | InternalOrderID: 62873 | Current Status: Order Sent | 2020-04-13 03:17:38.954 * |
[2020-04-13 07:32:08] |
We are looking into this issue now. We have had a few reports of this but when we tested last week we could not reproduce but we do see it now.
[2020-04-13 09:14:05] |
We now have determined the reason for the problem. We are putting out a new release to resolve this. The problem is that the client-side identifier for the order is overflowing the size of a 32-bit integer which Transact uses for this value. We have started to use a larger value which is not a problem when the client identifier is a string but it creates a problem when there is a limit of a 32-bit integer. This issue is not going to affect everyone. We would expect a smaller number of users. Please allow about an hour for the new release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-13 13:43:17] |
Thank you Support, one other issue related to this I have noticed is that when Attached orders are placed from Sierra they are reflected properly on the Sierra side but NOT showing up on the Transact DOM, only the main order is shown on the DOM and when it gets filled, the child orders are not reflected. So while the Sierra manages the target child orders and trailing stop order correctly they are no longer reflected on Transact DOM as they were in version 2066.
[2020-04-13 16:40:01] |
Update: I have downloaded pre-release 2084 and the problem is now fixed. Thank you Support for your prompt reaction and resolution! |
[2020-04-13 18:09:59] |
and when it gets filled, the child orders are not reflected. Is this still an issue after the update?It should not be. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-13 18:10:17
[2020-04-13 18:25:36] |
No, the issue is now resolved, this why I wanted to post the update. 2084 have fixed it. Thanks again! |
