Date/Time: Wed, 15 May 2024 16:15:02 +0000
Converted to SC data from CQG no live data
View Count: 490
[2020-04-06 20:30:57] |
User240418 - Posts: 5 |
No live data. Just signed up for SC data. I had CQG before. ADM says it is all set. Please tell me how to connect or what else i need
pastedImagefile.png / V - Attached On 2020-04-06 20:30:38 UTC - Size: 20.55 KB - 155 views |
[2020-04-07 07:17:32] |
The reason you are not getting real-time data from the CME group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees. Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees If you do not have a funded trading account or one with a supported trading service, then refer to this solution: Easy Solution to CME Funded Trading Account Requirement We recommend using the above solution in any case to avoid this problem in the future. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
